Enabling Buildbot 'responsible user' emails.
Fri Feb 7 07:51:38 UTC 2020
On 06/02/2020 00:11, Chris Johns wrote:
> On 6/2/20 10:00 am, Amar Takhar wrote:
>> On 2020-02-06 08:31 +1100, Chris Johns wrote:
>>> Can we enable this for one BSP from each tier 1 architectures?
>> Yes, can you provide a list?
> The master list is here ...
> https://git.rtems.org/rtems-tools/tree/config/rtems-bsps-tiers.ini
I would use different criteria to select BSPs for buildbot runs. They
should at least cover the maintained architectures (arm, powerpc, riscv,
and sparc). Using simulator BSPs has the benefit that you can run also
the test suite without having access to the hardware. This helps to
debug issues. I think the current selection is already quite good. Maybe
we should just add riscv/rv64imafdc_medany as 64-bit BSP to the list.
