Enabling Buildbot 'responsible user' emails.
Fri Feb 7 08:02:27 UTC 2020
On 07/02/2020 08:51, Sebastian Huber wrote:
> On 06/02/2020 00:11, Chris Johns wrote:
>> On 6/2/20 10:00 am, Amar Takhar wrote:
>>> On 2020-02-06 08:31 +1100, Chris Johns wrote:
>>>> Can we enable this for one BSP from each tier 1 architectures?
>>> Yes, can you provide a list?
>> The master list is here ...
>> https://git.rtems.org/rtems-tools/tree/config/rtems-bsps-tiers.ini
> I would use different criteria to select BSPs for buildbot runs. They
> should at least cover the maintained architectures (arm, powerpc,
> riscv, and sparc). Using simulator BSPs has the benefit that you can
> run also the test suite without having access to the hardware. This
> helps to debug issues. I think the current selection is already quite
> good. Maybe we should just add riscv/rv64imafdc_medany as 64-bit BSP
> to the list.
Currently, the build buildbot just build the BSPs with the tests. A next
step could be to add test suite runs as well. It is a lot more easy to
debug failures on one of the simulator BSPs even though they are not tier 1.
