[PATCH] c-user: Document CONFIGURE_DIRTY_MEMORY
Sebastian Huber
Tue Feb 11 05:57:51 UTC 2020
On 10/02/2020 22:30, Gedare Bloom wrote:
> On Mon, Feb 10, 2020 at 2:14 PM Chris Johns <chrisj at rtems.org> wrote:
>> On 10/2/20 8:32 pm, Sebastian Huber wrote:
>>> Close #3843.
>>> c-user/configuring_a_system.rst | 36 +++++++++++++++++++++++++++++++++++-
>>> 1 file changed, 35 insertions(+), 1 deletion(-)
>>> diff --git a/c-user/configuring_a_system.rst b/c-user/configuring_a_system.rst
>>> index 81bc9bb..00584c1 100644
>>> --- a/c-user/configuring_a_system.rst
>>> +++ b/c-user/configuring_a_system.rst
>>> @@ -425,6 +425,38 @@ General System Configuration
>>> This section defines the general system configuration options supported by
>>> ``<rtems/confdefs.h>``.
>>> +.. index:: CONFIGURE_DIRTY_MEMORY
>>> +.. _CONFIGURE_DIRTY_MEMORY:
>>> +CONFIGURE_DIRTY_MEMORY
>>> +CONSTANT:
>>> + ``CONFIGURE_DIRTY_MEMORY``
>>> +DATA TYPE:
>>> + Boolean feature macro.
>>> +RANGE:
>>> + Defined or undefined.
>>> +DEFAULT VALUE:
>>> + By default, the memory used by the RTEMS Workspace and the C Program Heap
>>> + is uninitialized memory.
>>> +DESCRIPTION:
>>> + This macro indicates whether RTEMS should dirty the memory used by the
>>> + RTEMS Workspace and the C Program Heap as part of its initialization. If
>>> + defined, the memory areas are dirtied with a ``0xCF`` byte pattern.
>>> + Otherwise, they are not.
>>> +NOTES:
>>> + Dirtying memory can add significantly to system boot time. It may assist
>>> + in finding code that assumes memory starts set to zero. In case
>> .. "assumes memory starts set to zero" does not look right to me?
> At first I disagreed, but then it does seem ambiguous, whether it
> means the starting address is 0 or the value is 0.
> It should be clarified, "memory values start set to zero" or "set to
> all zeroes" to make it clear memory is meant in the plural sense.
The FreeBSD man page uses "The memory is set to zero." Should I change
it to:
"It may assist in finding code that assumes the content of free memory
areas is cleared to zero during system initialization."
