[PATCH] c-user: Document CONFIGURE_DIRTY_MEMORY
Chris Johns
chrisj at rtems.org
Tue Feb 11 06:12:15 UTC 2020
On 11/2/20 4:57 pm, Sebastian Huber wrote:
> On 10/02/2020 22:30, Gedare Bloom wrote:
>> On Mon, Feb 10, 2020 at 2:14 PM Chris Johns <chrisj at rtems.org> wrote:
>>> On 10/2/20 8:32 pm, Sebastian Huber wrote:
>>>> Close #3843.
>>>> c-user/configuring_a_system.rst | 36 +++++++++++++++++++++++++++++++++++-
>>>> 1 file changed, 35 insertions(+), 1 deletion(-)
>>>> diff --git a/c-user/configuring_a_system.rst b/c-user/configuring_a_system.rst
>>>> index 81bc9bb..00584c1 100644
>>>> --- a/c-user/configuring_a_system.rst
>>>> +++ b/c-user/configuring_a_system.rst
>>>> @@ -425,6 +425,38 @@ General System Configuration
>>>> This section defines the general system configuration options supported by
>>>> ``<rtems/confdefs.h>``.
>>>> +.. index:: CONFIGURE_DIRTY_MEMORY
>>>> +.. _CONFIGURE_DIRTY_MEMORY:
>>>> +CONFIGURE_DIRTY_MEMORY
>>>> +CONSTANT:
>>>> + ``CONFIGURE_DIRTY_MEMORY``
>>>> +DATA TYPE:
>>>> + Boolean feature macro.
>>>> +RANGE:
>>>> + Defined or undefined.
>>>> +DEFAULT VALUE:
>>>> + By default, the memory used by the RTEMS Workspace and the C Program Heap
>>>> + is uninitialized memory.
>>>> +DESCRIPTION:
>>>> + This macro indicates whether RTEMS should dirty the memory used by the
>>>> + RTEMS Workspace and the C Program Heap as part of its initialization. If
>>>> + defined, the memory areas are dirtied with a ``0xCF`` byte pattern.
>>>> + Otherwise, they are not.
>>>> +NOTES:
>>>> + Dirtying memory can add significantly to system boot time. It may assist
>>>> + in finding code that assumes memory starts set to zero. In case
>>> .. "assumes memory starts set to zero" does not look right to me?
>> At first I disagreed, but then it does seem ambiguous, whether it
>> means the starting address is 0 or the value is 0.
>> It should be clarified, "memory values start set to zero" or "set to
>> all zeroes" to make it clear memory is meant in the plural sense.
> The FreeBSD man page uses "The memory is set to zero." Should I change it to:
> "It may assist in finding code that assumes the content of free memory areas is
> cleared to zero during system initialization."
Nice. A minor tweak ...
... incorrectly assumes the contents ... ?
