[PATCH] c-user: Document CONFIGURE_DIRTY_MEMORY
Tue Feb 11 06:37:23 UTC 2020
On 11/02/2020 07:12, Chris Johns wrote:
>>>>> +NOTES:
>>>>> +    Dirtying memory can add significantly to system boot time.  It may assist
>>>>> +    in finding code that assumes memory starts set to zero.  In case
>>>> .. "assumes memory starts set to zero" does not look right to me?
>>> At first I disagreed, but then it does seem ambiguous, whether it
>>> means the starting address is 0 or the value is 0.
>>> It should be clarified, "memory values start set to zero" or "set to
>>> all zeroes" to make it clear memory is meant in the plural sense.
>> The FreeBSD man page uses "The memory is set to zero." Should I change it to:
>> "It may assist in finding code that assumes the content of free memory areas is
>> cleared to zero during system initialization."
> Nice. A minor tweak ...
> ... incorrectly assumes the contents ... ?
Ok, I fixed it in two steps like this:
https://git.rtems.org/rtems-docs/commit/?id=0cdd4823fc05429ae834a18d8fca67594b249775
https://git.rtems.org/rtems-docs/commit/?id=c95724b793297994685804fcdaeb324a23cf1fd7
|NOTES: Dirtying memory can add significantly to system boot time. It
may assist in finding code that incorrectly assumes the contents of free
memory areas is cleared to zero during system initialization. In case
:ref:`CONFIGURE_ZERO_WORKSPACE_AUTOMATICALLY` is also defined, then the
memory is first dirtied and then zeroed. Hm, should this be now: |
||the contents of free memory areas ARE cleared to zero I probably
should have sent this stuff for review first.| |
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200211/bce4c2a6/attachment-0001.html>
