Description of rtems-libbsd testsuite applications
Sebastian Huber
Fri Feb 14 08:58:47 UTC 2020
Hello Jan,
On 14/02/2020 09:46, Jan.Sommer at dlr.de wrote:
> is there already somewhere a file which gives some short description what the different test applications in the testsuite directory (are supposed to) do?
> If not, would you accept patches with some short descriptions and maybe an example output?
there is no such documentation available. Thanks for your offer to fix
this. If you have time, it would be nice to use the rtems_test_begin()
and rtems_test_end() functions to print the begin/end messages. Using
the test state RTEMS_TEST_STATE_USER_INPUT for tests which need user
input or a network should allow test runs by the RTEMS Tester.
With respect to the description, maybe the first step would be to add it
to the top of the files?
Using the new test framework would be nice:
https://docs.rtems.org/branches/master/eng/test-framework.html#the-rtems-test-framework
However, this is a labor intensive and boring task.
