[PATCH 2/4] config: Simplify initialization task config
Fri Feb 14 09:08:07 UTC 2020
With the removal of the CONFIGURE_HAS_OWN_INIT_TASK_TABLE configuration
option at most one Classic API user initialization task can be
configured.
Provide an RTEMS API configuration table for backward compatibility.
Update #3873.
 cpukit/Makefile.am                     |   2 +
 cpukit/include/rtems/confdefs.h        |  59 ++++---------------
 cpukit/include/rtems/config.h          |   3 -
 cpukit/include/rtems/rtems/config.h    |  13 ++---
 cpukit/include/rtems/rtems/tasksdata.h |  19 +++----
 cpukit/libmisc/monitor/mon-config.c    |   4 +-
 cpukit/libmisc/monitor/mon-itask.c     |   8 ++-
 cpukit/rtems/src/getapiconfig.c        |  46 +++++++++++++++
 cpukit/rtems/src/taskinitdefault.c     |  34 +++++++++++
 cpukit/rtems/src/taskinitusers.c       | 101 +++++++++++----------------------
 10 files changed, 147 insertions(+), 142 deletions(-)
 create mode 100644 cpukit/rtems/src/getapiconfig.c
 create mode 100644 cpukit/rtems/src/taskinitdefault.c
diff --git a/cpukit/Makefile.am b/cpukit/Makefile.am
index 44a0868cd5..1d3935776b 100644
--- a/cpukit/Makefile.am
+++ b/cpukit/Makefile.am
@@ -697,6 +697,7 @@ librtemscpu_a_SOURCES += rtems/src/eventreceive.c
 librtemscpu_a_SOURCES += rtems/src/eventseize.c
 librtemscpu_a_SOURCES += rtems/src/eventsend.c
 librtemscpu_a_SOURCES += rtems/src/eventsurrender.c
+librtemscpu_a_SOURCES += rtems/src/getapiconfig.c
 librtemscpu_a_SOURCES += rtems/src/getcurrentprocessor.c
 librtemscpu_a_SOURCES += rtems/src/getprocessorcount.c
 librtemscpu_a_SOURCES += rtems/src/intrbody.c
@@ -789,6 +790,7 @@ librtemscpu_a_SOURCES += rtems/src/taskgetaffinity.c
 librtemscpu_a_SOURCES += rtems/src/taskgetpriority.c
 librtemscpu_a_SOURCES += rtems/src/taskgetscheduler.c
 librtemscpu_a_SOURCES += rtems/src/taskident.c
+librtemscpu_a_SOURCES += rtems/src/taskinitdefault.c
 librtemscpu_a_SOURCES += rtems/src/taskinitusers.c
 librtemscpu_a_SOURCES += rtems/src/taskissuspended.c
 librtemscpu_a_SOURCES += rtems/src/taskiterate.c
diff --git a/cpukit/include/rtems/confdefs.h b/cpukit/include/rtems/confdefs.h
index 355b434fdf..d73087d1df 100644
--- a/cpukit/include/rtems/confdefs.h
+++ b/cpukit/include/rtems/confdefs.h
@@ -103,11 +103,6 @@ extern "C" {
  *        used remarkably reliably by most applications.
- * This is the Classic API initialization tasks table.
-extern rtems_initialization_tasks_table Initialization_tasks[];
 #if defined(RTEMS_MULTIPROCESSING)
    * This it the distributed multiprocessing configuration table.
@@ -1384,42 +1379,8 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
   #define CONFIGURE_INIT_TASK_ARGUMENTS     0
 #endif
-#ifdef CONFIGURE_INIT
-  rtems_initialization_tasks_table Initialization_tasks[] = {
-    { CONFIGURE_INIT_TASK_NAME,
-      CONFIGURE_INIT_TASK_STACK_SIZE,
-      CONFIGURE_INIT_TASK_PRIORITY,
-      CONFIGURE_INIT_TASK_ATTRIBUTES,
-      CONFIGURE_INIT_TASK_ENTRY_POINT,
-      CONFIGURE_INIT_TASK_INITIAL_MODES,
-      CONFIGURE_INIT_TASK_ARGUMENTS
-#endif
- * This is the name of the Initialization Tasks Table generated.
-#define CONFIGURE_INIT_TASK_TABLE Initialization_tasks
- * This is the size of the Initialization Tasks Table generated.
-#define CONFIGURE_INIT_TASK_TABLE_SIZE \
-  RTEMS_ARRAY_SIZE(CONFIGURE_INIT_TASK_TABLE)
 #else     /* CONFIGURE_RTEMS_INIT_TASKS_TABLE */
- * This is the name of the Initialization Task when none is configured.
-#define CONFIGURE_INIT_TASK_TABLE      NULL
- * This is the size of the Initialization Task when none is configured.
-#define CONFIGURE_INIT_TASK_TABLE_SIZE 0
  * This is the stack size of the Initialization Task when none is configured.
@@ -2605,14 +2566,6 @@ struct _reent *__getreent(void)
     EXTENSION_INFORMATION_DEFINE( CONFIGURE_MAXIMUM_USER_EXTENSIONS );
   #endif
-   * This is the Classic API Configuration Table.
-  rtems_api_configuration_table Configuration_RTEMS_API = {
-    CONFIGURE_INIT_TASK_TABLE_SIZE,
   #if CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS > 0
     POSIX_Keys_Key_value_pair _POSIX_Keys_Key_value_pairs[
       rtems_resource_maximum_per_allocation(
@@ -2803,8 +2756,18 @@ struct _reent *__getreent(void)
   #if defined(CONFIGURE_RTEMS_INIT_TASKS_TABLE)
+    const rtems_initialization_tasks_table _RTEMS_tasks_User_task_table = {
+      CONFIGURE_INIT_TASK_NAME,
+      CONFIGURE_INIT_TASK_STACK_SIZE,
+      CONFIGURE_INIT_TASK_PRIORITY,
+      CONFIGURE_INIT_TASK_ATTRIBUTES,
+      CONFIGURE_INIT_TASK_ENTRY_POINT,
+      CONFIGURE_INIT_TASK_INITIAL_MODES,
+      CONFIGURE_INIT_TASK_ARGUMENTS
     RTEMS_SYSINIT_ITEM(
-      _RTEMS_tasks_Initialize_user_tasks_body,
+      _RTEMS_tasks_Initialize_user_task,
       RTEMS_SYSINIT_CLASSIC_USER_TASKS,
       RTEMS_SYSINIT_ORDER_MIDDLE
diff --git a/cpukit/include/rtems/config.h b/cpukit/include/rtems/config.h
index b9f62cd061..6f9389c295 100644
--- a/cpukit/include/rtems/config.h
+++ b/cpukit/include/rtems/config.h
@@ -242,9 +242,6 @@ uint32_t rtems_configuration_get_maximum_extensions( void );
         1
 #endif
-#define rtems_configuration_get_rtems_api_configuration() \
-        (&Configuration_RTEMS_API)
 #ifdef __cplusplus
 #endif
diff --git a/cpukit/include/rtems/rtems/config.h b/cpukit/include/rtems/rtems/config.h
index 63449be922..a5078f6bb6 100644
--- a/cpukit/include/rtems/rtems/config.h
+++ b/cpukit/include/rtems/rtems/config.h
@@ -55,17 +55,9 @@ typedef struct {
    * This field is the set of Classic API Initialization
    * Tasks which are configured for this application.
-  rtems_initialization_tasks_table *User_initialization_tasks_table;
+  const rtems_initialization_tasks_table *User_initialization_tasks_table;
 } rtems_api_configuration_table;
- *  @brief RTEMS API Configuration Table
- *  This is the RTEMS API Configuration Table expected to be generated
- *  by confdefs.h.
-extern rtems_api_configuration_table Configuration_RTEMS_API;
 uint32_t rtems_configuration_get_maximum_barriers( void );
@@ -86,6 +78,9 @@ uint32_t rtems_configuration_get_maximum_timers( void );
 uint32_t rtems_configuration_get_maximum_tasks( void );
+const rtems_api_configuration_table *
+rtems_configuration_get_rtems_api_configuration( void );
 #ifdef __cplusplus
 #endif
diff --git a/cpukit/include/rtems/rtems/tasksdata.h b/cpukit/include/rtems/rtems/tasksdata.h
index 19e6a8a618..55090f71b0 100644
--- a/cpukit/include/rtems/rtems/tasksdata.h
+++ b/cpukit/include/rtems/rtems/tasksdata.h
@@ -53,19 +53,18 @@ typedef struct {
 }  RTEMS_API_Control;
- *  @brief _RTEMS_tasks_Initialize_user_tasks_body
+ * @brief Initialization table for the first user task.
- *  This routine creates and starts all configured user
- *  initialization threads.
- *  Input parameters: NONE
- *  Output parameters:  NONE
- *  RTEMS Task Manager
+ * This table is used by _RTEMS_tasks_Initialize_user_task() and initialized
+ * via <rtems/confdefs.h>.
+extern const rtems_initialization_tasks_table _RTEMS_tasks_User_task_table;
-extern void _RTEMS_tasks_Initialize_user_tasks_body( void );
+ * @brief System initialization handler to create and start the first user
+ * task.
+extern void _RTEMS_tasks_Initialize_user_task( void );
  *  The following instantiates the information control block used to
diff --git a/cpukit/libmisc/monitor/mon-config.c b/cpukit/libmisc/monitor/mon-config.c
index 95b7798173..d7728de33a 100644
--- a/cpukit/libmisc/monitor/mon-config.c
+++ b/cpukit/libmisc/monitor/mon-config.c
@@ -29,7 +29,9 @@ rtems_monitor_config_canonical(
     const void             *config_void
-    rtems_api_configuration_table *r = &Configuration_RTEMS_API;
+    const rtems_api_configuration_table *r;
+    r = rtems_configuration_get_rtems_api_configuration();
     canonical_config->work_space_size = rtems_configuration_get_work_space_size();
     canonical_config->maximum_tasks = rtems_configuration_get_maximum_tasks();
diff --git a/cpukit/libmisc/monitor/mon-itask.c b/cpukit/libmisc/monitor/mon-itask.c
index 39103320ab..f4d3aea170 100644
--- a/cpukit/libmisc/monitor/mon-itask.c
+++ b/cpukit/libmisc/monitor/mon-itask.c
@@ -40,15 +40,17 @@ rtems_monitor_init_task_next(
     rtems_id              *next_id
-    rtems_initialization_tasks_table *itask;
+    const rtems_api_configuration_table *config;
+    const rtems_initialization_tasks_table *itask;
     uint32_t   n = rtems_object_id_get_index(*next_id);
-    if (n >= Configuration_RTEMS_API.number_of_initialization_tasks)
+    config = rtems_configuration_get_rtems_api_configuration();
+    if (n >= config->number_of_initialization_tasks)
         goto failed;
     _Objects_Allocator_lock();
-    itask = Configuration_RTEMS_API.User_initialization_tasks_table + n;
+    itask = config->User_initialization_tasks_table + n;
      * dummy up a fake id and name for this item
diff --git a/cpukit/rtems/src/getapiconfig.c b/cpukit/rtems/src/getapiconfig.c
new file mode 100644
index 0000000000..b69629504b
--- /dev/null
+++ b/cpukit/rtems/src/getapiconfig.c
@@ -0,0 +1,46 @@
+ * SPDX-License-Identifier: BSD-2-Clause
+ * Copyright (C) 2020 embedded brains GmbH
+ * are met:
+#if HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems/rtems/config.h>
+#include <rtems/rtems/tasksdata.h>
+static rtems_api_configuration_table config;
+  if ( _RTEMS_tasks_User_task_table.entry_point != NULL ) {
+    config.number_of_initialization_tasks = 1;
+    config.User_initialization_tasks_table = &_RTEMS_tasks_User_task_table;
+  return &config;
diff --git a/cpukit/rtems/src/taskinitdefault.c b/cpukit/rtems/src/taskinitdefault.c
index 0000000000..6b9a6135fd
--- /dev/null
+++ b/cpukit/rtems/src/taskinitdefault.c
@@ -0,0 +1,34 @@
+ * are met:
+#if HAVE_CONFIG_H
+#endif
+#include <rtems/rtems/tasks.h>
+const rtems_initialization_tasks_table _RTEMS_tasks_User_task_table;
diff --git a/cpukit/rtems/src/taskinitusers.c b/cpukit/rtems/src/taskinitusers.c
index f72428d77c..a4f948afc9 100644
--- a/cpukit/rtems/src/taskinitusers.c
+++ b/cpukit/rtems/src/taskinitusers.c
@@ -18,79 +18,44 @@
 #include "config.h"
 #endif
-#include <rtems/config.h>
-#include <rtems/rtems/status.h>
-#include <rtems/rtems/support.h>
-#include <rtems/rtems/modes.h>
-#include <rtems/score/assert.h>
-#include <rtems/score/stack.h>
-#include <rtems/score/thread.h>
-#include <rtems/score/wkspace.h>
- *  _RTEMS_tasks_Initialize_user_tasks_body
+#include <rtems/score/assert.h>
+#include <rtems/score/interr.h>
-void _RTEMS_tasks_Initialize_user_tasks_body( void )
+void _RTEMS_tasks_Initialize_user_task( void )
-  uint32_t                          index;
-  uint32_t                          maximum;
-  rtems_id                          id;
-  rtems_status_code                 return_value;
-  rtems_initialization_tasks_table *user_tasks;
-  rtems_task_entry                  entry_point;
-   *  Move information into local variables
-  user_tasks = Configuration_RTEMS_API.User_initialization_tasks_table;
-  maximum    = Configuration_RTEMS_API.number_of_initialization_tasks;
-   *  Verify that we have a set of user tasks to iterate
-  if ( !user_tasks )
-    return;
-   *  Now iterate over the initialization tasks and create/start them.
-  for ( index=0 ; index < maximum ; index++ ) {
-    return_value = rtems_task_create(
-      user_tasks[ index ].name,
-      user_tasks[ index ].initial_priority,
-      user_tasks[ index ].stack_size,
-      user_tasks[ index ].mode_set,
-      user_tasks[ index ].attribute_set,
-      &id
-    if ( !rtems_is_status_successful( return_value ) ) {
-      _Internal_error( INTERNAL_ERROR_RTEMS_INIT_TASK_CREATE_FAILED );
+  rtems_id                                id;
+  rtems_status_code                       return_value;
+  const rtems_initialization_tasks_table *user_task;
+  rtems_task_entry                        entry_point;
+  user_task = &_RTEMS_tasks_User_task_table;
+  return_value = rtems_task_create(
+    user_task->name,
+    user_task->initial_priority,
+    user_task->stack_size,
+    user_task->mode_set,
+    user_task->attribute_set,
+    &id
+  if ( !rtems_is_status_successful( return_value ) ) {
+    _Internal_error( INTERNAL_ERROR_RTEMS_INIT_TASK_CREATE_FAILED );
-    entry_point = user_tasks[ index ].entry_point;
-    if ( entry_point == NULL ) {
-      _Internal_error( INTERNAL_ERROR_RTEMS_INIT_TASK_ENTRY_IS_NULL );
+  entry_point = user_task->entry_point;
+  if ( entry_point == NULL ) {
+    _Internal_error( INTERNAL_ERROR_RTEMS_INIT_TASK_ENTRY_IS_NULL );
-    return_value = rtems_task_start(
-      id,
-      entry_point,
-      user_tasks[ index ].argument
-    _Assert( rtems_is_status_successful( return_value ) );
-    (void) return_value;
+  return_value = rtems_task_start(
+    id,
+    entry_point,
+    user_task->argument
+  _Assert( rtems_is_status_successful( return_value ) );
+  (void) return_value;
-    if ( _Thread_Global_constructor == 0 ) {
-      _Thread_Global_constructor = id;
+  if ( _Thread_Global_constructor == 0 ) {
+    _Thread_Global_constructor = id;
2.16.4
