[PATCH 1/4] config: Remove CONFIGURE_HAS_OWN_INIT_TASK_TABLE
Sebastian Huber
Fri Feb 14 09:08:06 UTC 2020
The CONFIGURE_HAS_OWN_INIT_TASK_TABLE and
CONFIGURE_POSIX_HAS_OWN_INIT_THREAD_TABLE are the last *_HAS_OWN_*
configuration options. These two options are probably unused, see also:
* https://lists.rtems.org/pipermail/users/2019-April/033129.html
* https://lists.rtems.org/pipermail/users/2019-April/033130.html
Removing them simplifies the configuration. If there is a real user need
which shows up after the removal, we can resurrect them on demand.
Using CONFIGURE_HAS_OWN_INIT_TASK_TABLE would have required the use of
the undocumented CONFIGURE_INIT_TASK_TABLE and
CONFIGURE_INIT_TASK_TABLE_SIZE configuration options.
Update #3873.
cpukit/include/rtems/confdefs.h | 19 ++-----------------
testsuites/sptests/sp54/init.c | 26 ++++++++------------------
testsuites/sptests/spfatal01/init.c | 33 +++++++++++++--------------------
testsuites/sptests/spfatal02/init.c | 20 +-------------------
testsuites/sptests/spfatal04/init.c | 20 --------------------
testsuites/sptests/spfatal05/init.c | 20 --------------------
testsuites/sptests/spfatal06/init.c | 24 +-----------------------
7 files changed, 25 insertions(+), 137 deletions(-)
diff --git a/cpukit/include/rtems/confdefs.h b/cpukit/include/rtems/confdefs.h
index c7031cba19..355b434fdf 100644
--- a/cpukit/include/rtems/confdefs.h
+++ b/cpukit/include/rtems/confdefs.h
@@ -1312,13 +1312,8 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
* Default User Initialization Task Table. This table guarantees that
* one user initialization table is defined.
- * WHEN CONFIGURE_HAS_OWN_INIT_TASK_TABLE is defined, the user is
- * responsible for defining their own table information and setting the
- * appropriate variables.
-#if defined(CONFIGURE_RTEMS_INIT_TASKS_TABLE) && \
- !defined(CONFIGURE_HAS_OWN_INIT_TASK_TABLE)
+#if defined(CONFIGURE_RTEMS_INIT_TASKS_TABLE)
* When using the default Classic API Initialization Tasks Table, this is
@@ -1414,13 +1409,6 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
RTEMS_ARRAY_SIZE(CONFIGURE_INIT_TASK_TABLE)
#else /* CONFIGURE_RTEMS_INIT_TASKS_TABLE */
-#ifdef CONFIGURE_HAS_OWN_INIT_TASK_TABLE
- * The user application is responsible for defining everything
- * when CONFIGURE_HAS_OWN_INIT_TABLE is defined.
-#else /* not using standard or providing own Init Task Table */
* This is the name of the Initialization Task when none is configured.
@@ -1437,8 +1425,6 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
#define CONFIGURE_INIT_TASK_STACK_SIZE 0
-#endif /* CONFIGURE_HAS_OWN_INIT_TASK_TABLE */
#endif
/**@}*/ /* end of Classic API Initialization Tasks Table */
@@ -2816,8 +2802,7 @@ struct _reent *__getreent(void)
* then we need to install the code that runs that loop.
#ifdef CONFIGURE_INIT
- #if defined(CONFIGURE_RTEMS_INIT_TASKS_TABLE) || \
- defined(CONFIGURE_HAS_OWN_INIT_TASK_TABLE)
+ #if defined(CONFIGURE_RTEMS_INIT_TASKS_TABLE)
RTEMS_SYSINIT_ITEM(
_RTEMS_tasks_Initialize_user_tasks_body,
RTEMS_SYSINIT_CLASSIC_USER_TASKS,
diff --git a/testsuites/sptests/sp54/init.c b/testsuites/sptests/sp54/init.c
index 07001e1e5e..71437fac8e 100644
--- a/testsuites/sptests/sp54/init.c
+++ b/testsuites/sptests/sp54/init.c
@@ -24,9 +24,10 @@ const char rtems_test_name[] = "SP 54";
static void *Init( uintptr_t ignored )
- rtems_status_code status;
- rtems_task_priority pri;
- rtems_id id;
+ rtems_status_code status;
+ rtems_task_priority pri;
+ rtems_id id;
+ const rtems_api_configuration_table *config;
* It is possible that since this thread prints and there is no idle
@@ -52,6 +53,10 @@ static void *Init( uintptr_t ignored )
rtems_test_assert( rtems_configuration_get_do_zero_of_workspace() );
+ config = rtems_configuration_get_rtems_api_configuration();
+ rtems_test_assert( config->number_of_initialization_tasks == 0 );
+ rtems_test_assert( config->User_initialization_tasks_table == NULL );
TEST_END();
rtems_test_exit(0);
@@ -68,21 +73,6 @@ static void *Init( uintptr_t ignored )
#define CONFIGURE_IDLE_TASK_BODY Init
#define CONFIGURE_IDLE_TASK_INITIALIZES_APPLICATION
- * Another odd case to hit. Since we use the Init task is Idle task
- * configuration, we can dummy up the initialization task configuration
- * to have a non-NULL pointer and 0 tasks.
-#define CONFIGURE_HAS_OWN_INIT_TASK_TABLE 1
-rtems_initialization_tasks_table Initialization_tasks[1] =
- { { 0, }};
-#define CONFIGURE_INIT_TASK_TABLE Initialization_tasks
-#define CONFIGURE_INIT_TASK_TABLE_SIZE 0
-#define CONFIGURE_INIT_TASK_STACK_SIZE 0
#define CONFIGURE_DIRTY_MEMORY
diff --git a/testsuites/sptests/spfatal01/init.c b/testsuites/sptests/spfatal01/init.c
index 95067e74c6..4f0c008855 100644
--- a/testsuites/sptests/spfatal01/init.c
+++ b/testsuites/sptests/spfatal01/init.c
@@ -8,31 +8,24 @@
* Classic API Init task create failure
- * Way too much stack space. Should generate a fatal error
- * on the init task create.
-rtems_initialization_tasks_table Initialization_tasks[] = {
- { rtems_build_name('I', 'N', 'I', ' '),
- 32UL * 1024UL,
- 1,
- RTEMS_DEFAULT_ATTRIBUTES,
- Init,
- RTEMS_DEFAULT_MODES,
- 0
-#define CONFIGURE_INIT_TASK_TABLE_SIZE \
- sizeof(CONFIGURE_INIT_TASK_TABLE) / sizeof(rtems_initialization_tasks_table)
#define FATAL_ERROR_TEST_NAME "1"
#define FATAL_ERROR_DESCRIPTION "Classic API Init task create failure"
#define FATAL_ERROR_EXPECTED_SOURCE INTERNAL_ERROR_CORE
#define FATAL_ERROR_EXPECTED_ERROR INTERNAL_ERROR_RTEMS_INIT_TASK_CREATE_FAILED
+static void *stack_allocator(size_t unused)
+ return NULL;
+static void stack_deallocator(void *unused)
+#define CONFIGURE_TASK_STACK_ALLOCATOR stack_allocator
+#define CONFIGURE_TASK_STACK_DEALLOCATOR stack_deallocator
static void force_error(void)
diff --git a/testsuites/sptests/spfatal02/init.c b/testsuites/sptests/spfatal02/init.c
index e0f6a978fc..2700b4dd50 100644
--- a/testsuites/sptests/spfatal02/init.c
+++ b/testsuites/sptests/spfatal02/init.c
@@ -8,25 +8,7 @@
-#define CONFIGURE_INIT_TASK_STACK_SIZE RTEMS_MINIMUM_STACK_SIZE
- RTEMS_MINIMUM_STACK_SIZE,
- 1,
- NULL,
- 0
+#define CONFIGURE_INIT_TASK_ENTRY_POINT NULL
#define FATAL_ERROR_TEST_NAME "2"
#define FATAL_ERROR_DESCRIPTION "Classic API Init task start failure"
diff --git a/testsuites/sptests/spfatal04/init.c b/testsuites/sptests/spfatal04/init.c
index cfbad5d409..89a4be88ad 100644
--- a/testsuites/sptests/spfatal04/init.c
+++ b/testsuites/sptests/spfatal04/init.c
@@ -8,26 +8,6 @@
- 1,
- Init,
- 0
#define FATAL_ERROR_TEST_NAME "4"
#define FATAL_ERROR_DESCRIPTION \
"Classic API call rtems_fatal_error_occurred"
diff --git a/testsuites/sptests/spfatal05/init.c b/testsuites/sptests/spfatal05/init.c
index b0411162f2..d17077c401 100644
--- a/testsuites/sptests/spfatal05/init.c
+++ b/testsuites/sptests/spfatal05/init.c
@@ -15,26 +15,6 @@
* http://www.rtems.org/license/LICENSE.
- 1,
- Init,
- 0
#define SPFATAL_TEST_CASE_EXTRA_TASKS 1
#define FATAL_ERROR_TEST_NAME "5"
diff --git a/testsuites/sptests/spfatal06/init.c b/testsuites/sptests/spfatal06/init.c
index 842931a336..cef38f5fe2 100644
--- a/testsuites/sptests/spfatal06/init.c
+++ b/testsuites/sptests/spfatal06/init.c
@@ -15,39 +15,17 @@
- 1,
- Init,
- 0
#define FATAL_ERROR_TEST_NAME "6"
"Core initialize with invalid stack hook"
#define FATAL_ERROR_EXPECTED_ERROR INTERNAL_ERROR_BAD_STACK_HOOK
-void *New_stack_allocate_hook(size_t unused);
#define CONFIGURE_TASK_STACK_ALLOCATOR New_stack_allocate_hook
#define CONFIGURE_TASK_STACK_DEALLOCATOR NULL
+static void *New_stack_allocate_hook(size_t unused)
return NULL;
2.16.4
