[PATCH 03/18] monitor: Use proper API for all config constants
Sebastian Huber
Fri Feb 14 16:02:28 UTC 2020
cpukit/libmisc/monitor/mon-config.c | 11 ++++-------
1 file changed, 4 insertions(+), 7 deletions(-)
diff --git a/cpukit/libmisc/monitor/mon-config.c b/cpukit/libmisc/monitor/mon-config.c
index 852e780d04..95b7798173 100644
--- a/cpukit/libmisc/monitor/mon-config.c
+++ b/cpukit/libmisc/monitor/mon-config.c
@@ -29,11 +29,9 @@ rtems_monitor_config_canonical(
const void *config_void
- const rtems_configuration_table *c =
- (const rtems_configuration_table *) config_void;
rtems_api_configuration_table *r = &Configuration_RTEMS_API;
- canonical_config->work_space_size = c->work_space_size;
+ canonical_config->work_space_size = rtems_configuration_get_work_space_size();
canonical_config->maximum_tasks = rtems_configuration_get_maximum_tasks();
canonical_config->maximum_timers = rtems_configuration_get_maximum_timers();
canonical_config->maximum_semaphores = rtems_configuration_get_maximum_semaphores();
@@ -43,8 +41,8 @@ rtems_monitor_config_canonical(
canonical_config->maximum_ports = rtems_configuration_get_maximum_ports();
canonical_config->maximum_periods = rtems_configuration_get_maximum_periods();
canonical_config->maximum_extensions = rtems_configuration_get_maximum_extensions();
- canonical_config->microseconds_per_tick = c->microseconds_per_tick;
- canonical_config->ticks_per_timeslice = c->ticks_per_timeslice;
+ canonical_config->microseconds_per_tick = rtems_configuration_get_microseconds_per_tick();
+ canonical_config->ticks_per_timeslice = rtems_configuration_get_ticks_per_timeslice();
canonical_config->number_of_initialization_tasks = r->number_of_initialization_tasks;
@@ -60,7 +58,6 @@ rtems_monitor_config_next(
rtems_id *next_id
- const rtems_configuration_table *c = &Configuration;
int n = rtems_object_id_get_index(*next_id);
if (n >= 1)
@@ -69,7 +66,7 @@ rtems_monitor_config_next(
_Objects_Allocator_lock();
*next_id += 1;
- return (const void *) c;
+ return (const void *) (uintptr_t) 1;
failed:
*next_id = RTEMS_OBJECT_ID_FINAL;
2.16.4
