[PATCH 02/18] config: Remove unused configuration constant
Fri Feb 14 16:02:27 UTC 2020
 cpukit/include/rtems/confdefs.h |  1 -
 cpukit/include/rtems/config.h   | 10 ----------
 2 files changed, 11 deletions(-)
diff --git a/cpukit/include/rtems/confdefs.h b/cpukit/include/rtems/confdefs.h
index f39172cffb..137a9edb5c 100644
--- a/cpukit/include/rtems/confdefs.h
+++ b/cpukit/include/rtems/confdefs.h
@@ -2723,7 +2723,6 @@ struct _reent *__getreent(void)
   const rtems_configuration_table Configuration = {
     CONFIGURE_EXECUTIVE_RAM_SIZE,             /* required RTEMS workspace */
-    CONFIGURE_MAXIMUM_USER_EXTENSIONS,        /* maximum dynamic extensions */
     CONFIGURE_MICROSECONDS_PER_TICK,          /* microseconds per clock tick */
     CONFIGURE_TICKS_PER_TIMESLICE,            /* ticks per timeslice quantum */
     CONFIGURE_IDLE_TASK_BODY,                 /* user's IDLE task */
diff --git a/cpukit/include/rtems/config.h b/cpukit/include/rtems/config.h
index 1c9b35da87..51e437f48a 100644
--- a/cpukit/include/rtems/config.h
+++ b/cpukit/include/rtems/config.h
@@ -87,16 +87,6 @@ typedef struct {
   uintptr_t                      work_space_size;
-   * This field contains the maximum number of POSIX API
-   * key value pairs which are configured for this application.
-   * @note There can be potentially be a key/value pair for
-   *       every thread to use every key. But normally this
-   *       many are not needed in a system.
-  uint32_t                            maximum_key_value_pairs;
    * This field specifies the number of microseconds which elapse
    * between clock ticks.  This is the basis for RTEMS timing.
2.16.4
