[PATCH 08/18] posix: Remove <rtems/posix/ptimer.h>
Sebastian Huber
Fri Feb 14 16:02:33 UTC 2020
This file contained duplicate prototypes for standard POSIX functions
declared in <time.h>.
cpukit/headers.am | 1 -
cpukit/include/rtems/posix/ptimer.h | 88 -------------------------------------
cpukit/posix/src/timersettime.c | 1 -
3 files changed, 90 deletions(-)
delete mode 100644 cpukit/include/rtems/posix/ptimer.h
diff --git a/cpukit/headers.am b/cpukit/headers.am
index aa2db5771a..6f44b833e1 100644
--- a/cpukit/headers.am
+++ b/cpukit/headers.am
@@ -203,7 +203,6 @@ include_rtems_posix_HEADERS += include/rtems/posix/psignalimpl.h
include_rtems_posix_HEADERS += include/rtems/posix/pthread.h
include_rtems_posix_HEADERS += include/rtems/posix/pthreadattrimpl.h
include_rtems_posix_HEADERS += include/rtems/posix/pthreadimpl.h
-include_rtems_posix_HEADERS += include/rtems/posix/ptimer.h
include_rtems_posix_HEADERS += include/rtems/posix/rwlockimpl.h
include_rtems_posix_HEADERS += include/rtems/posix/semaphore.h
include_rtems_posix_HEADERS += include/rtems/posix/semaphoreimpl.h
diff --git a/cpukit/include/rtems/posix/ptimer.h b/cpukit/include/rtems/posix/ptimer.h
deleted file mode 100644
index f6de4ccb57..0000000000
--- a/cpukit/include/rtems/posix/ptimer.h
+++ /dev/null
@@ -1,88 +0,0 @@
- * @file
- * @brief POSIX Timers Private Support
- * This include file contains all the private support information for
- * POSIX timers.
- * Initial Implementation:
- * COPYRIGHT (c) 1998. Alfonso Escalera Piña
- * Largely rewritten by Joel Sherrill (1999).
- * COPYRIGHT (c) 1999-2013.
- * On-Line Applications Research Corporation (OAR).
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
-#ifndef _RTEMS_POSIX_PTIMER_H
-#define _RTEMS_POSIX_PTIMER_H
- * @defgroup POSIX_PRIV_TIMERS POSIX Timers
- * @ingroup POSIXAPI
-#ifdef __cplusplus
-extern "C" {
-#endif
-#include <rtems/posix/config.h>
- * @brief Create a Per-Process Timer
-int timer_create(
- clockid_t clock_id,
- struct sigevent *evp,
- timer_t *timerid
- * @brief Delete a Per-Process Timer
-int timer_delete(
- timer_t timerid
- * @brief Set a Per-Process Timer
-int timer_settime(
- timer_t timerid,
- int flags,
- const struct itimerspec *value,
- struct itimerspec *ovalue
-int timer_gettime(
- timer_t timerid,
- struct itimerspec *value
- * @brief Get overrun count for a Per-Process Timer
- * The expiration of a timer must increase by one a counter.
- * After the signal handler associated to the timer finishes
- * its execution, _POSIX_Timer_TSR will have to set this counter to 0.
-int timer_getoverrun(
- timer_t timerid
-#ifdef __cplusplus
-#endif
-#endif /* _RTEMS_POSIX_PTIMER_H */
diff --git a/cpukit/posix/src/timersettime.c b/cpukit/posix/src/timersettime.c
index 9212e49740..eb89029e29 100644
--- a/cpukit/posix/src/timersettime.c
+++ b/cpukit/posix/src/timersettime.c
@@ -23,7 +23,6 @@
#include <time.h>
-#include <rtems/posix/ptimer.h>
#include <rtems/posix/timerimpl.h>
2.16.4
