[PATCH 09/18] config: Remove CONFIGURE_POSIX_HAS_OWN_INIT_THREAD_TABLE
Fri Feb 14 16:02:34 UTC 2020
The CONFIGURE_HAS_OWN_INIT_TASK_TABLE and
CONFIGURE_POSIX_HAS_OWN_INIT_THREAD_TABLE are the last *_HAS_OWN_*
configuration options.  These two options are probably unused, see also:
* https://lists.rtems.org/pipermail/users/2019-April/033129.html
* https://lists.rtems.org/pipermail/users/2019-April/033130.html
Removing them simplifies the configuration. If there is a real user need
which shows up after the removal, we can resurrect them on demand.
Using CONFIGURE_POSIX_HAS_OWN_INIT_THREAD_TABLE would have required the
use of the undocumented CONFIGURE_POSIX_INIT_THREAD_TABLE_NAME and
CONFIGURE_POSIX_INIT_THREAD_TABLE_SIZE configuration options.
Update #3873.
 cpukit/headers.am                        |  1 -
 cpukit/include/rtems/confdefs.h          | 51 ++++++++--------------
 cpukit/include/rtems/config.h            |  1 -
 cpukit/include/rtems/posix/config.h      | 60 -------------------------
 cpukit/include/rtems/posix/pthread.h     | 25 +++++++++--
 cpukit/include/rtems/posix/pthreadimpl.h |  1 -
 cpukit/posix/src/pthreadinitthreads.c    | 75 +++++++++++++-------------------
 testsuites/psxtests/psxfatal01/init.c    | 22 +---------
 testsuites/psxtests/psxfatal02/init.c    | 40 ++++++-----------
 9 files changed, 83 insertions(+), 193 deletions(-)
 delete mode 100644 cpukit/include/rtems/posix/config.h
diff --git a/cpukit/headers.am b/cpukit/headers.am
index 6f44b833e1..244e435c62 100644
--- a/cpukit/headers.am
+++ b/cpukit/headers.am
@@ -189,7 +189,6 @@ include_rtems_debugger_HEADERS += include/rtems/debugger/rtems-debugger-server.h
 include_rtems_posix_HEADERS += include/rtems/posix/aio_misc.h
 include_rtems_posix_HEADERS += include/rtems/posix/barrierimpl.h
 include_rtems_posix_HEADERS += include/rtems/posix/condimpl.h
-include_rtems_posix_HEADERS += include/rtems/posix/config.h
 include_rtems_posix_HEADERS += include/rtems/posix/key.h
 include_rtems_posix_HEADERS += include/rtems/posix/keyimpl.h
 include_rtems_posix_HEADERS += include/rtems/posix/mmanimpl.h
diff --git a/cpukit/include/rtems/confdefs.h b/cpukit/include/rtems/confdefs.h
index bb00cffee7..0181af356a 100644
--- a/cpukit/include/rtems/confdefs.h
+++ b/cpukit/include/rtems/confdefs.h
@@ -2177,32 +2177,14 @@ struct _reent *__getreent(void)
 #endif
 #ifdef CONFIGURE_POSIX_INIT_THREAD_TABLE
-  #ifndef CONFIGURE_POSIX_HAS_OWN_INIT_THREAD_TABLE
-    #ifndef CONFIGURE_POSIX_INIT_THREAD_ENTRY_POINT
-      #define CONFIGURE_POSIX_INIT_THREAD_ENTRY_POINT   POSIX_Init
-    #endif
-    #ifndef CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE
-      #define CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE \
-        CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE
-    #endif
-    #ifdef CONFIGURE_INIT
-      posix_initialization_threads_table POSIX_Initialization_threads[] = {
-        { CONFIGURE_POSIX_INIT_THREAD_ENTRY_POINT,
-          CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE }
-    #endif
-    #define CONFIGURE_POSIX_INIT_THREAD_TABLE_NAME \
-      POSIX_Initialization_threads
+  #ifndef CONFIGURE_POSIX_INIT_THREAD_ENTRY_POINT
+    #define CONFIGURE_POSIX_INIT_THREAD_ENTRY_POINT   POSIX_Init
+  #endif
-    #define CONFIGURE_POSIX_INIT_THREAD_TABLE_SIZE \
-      RTEMS_ARRAY_SIZE(CONFIGURE_POSIX_INIT_THREAD_TABLE_NAME)
-  #endif /* !CONFIGURE_POSIX_HAS_OWN_INIT_TASK_TABLE */
-#else /* !CONFIGURE_POSIX_INIT_THREAD_TABLE */
-  #define CONFIGURE_POSIX_INIT_THREAD_TABLE_NAME NULL
-  #define CONFIGURE_POSIX_INIT_THREAD_TABLE_SIZE 0
+  #ifndef CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE
+    #define CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE \
+      CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE
+  #endif
 #endif /* CONFIGURE_POSIX_INIT_THREAD_TABLE */
@@ -2777,17 +2759,14 @@ struct _reent *__getreent(void)
  *  then we need to install the code that runs that loop.
-  #if defined(CONFIGURE_POSIX_INIT_THREAD_TABLE) || \
-      defined(CONFIGURE_POSIX_HAS_OWN_INIT_THREAD_TABLE)
-    posix_initialization_threads_table * const
-      _Configuration_POSIX_Initialization_threads =
-        CONFIGURE_POSIX_INIT_THREAD_TABLE_NAME;
-    const size_t _Configuration_POSIX_Initialization_thread_count =
-      CONFIGURE_POSIX_INIT_THREAD_TABLE_SIZE;
+  #if defined(CONFIGURE_POSIX_INIT_THREAD_TABLE)
+    const posix_initialization_threads_table _POSIX_Threads_User_thread_table = {
+      CONFIGURE_POSIX_INIT_THREAD_ENTRY_POINT,
+      CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE
     RTEMS_SYSINIT_ITEM(
-      _POSIX_Threads_Initialize_user_threads_body,
+      _POSIX_Threads_Initialize_user_thread,
       RTEMS_SYSINIT_POSIX_USER_THREADS,
       RTEMS_SYSINIT_ORDER_MIDDLE
@@ -3012,6 +2991,10 @@ struct _reent *__getreent(void)
   #warning "The CONFIGURE_MAXIMUM_PTYS configuration option is obsolete since RTEMS 5.1"
 #endif
+#ifdef CONFIGURE_POSIX_HAS_OWN_INIT_THREAD_TABLE
+  #warning "The CONFIGURE_POSIX_HAS_OWN_INIT_THREAD_TABLE configuration option is obsolete since RTEMS 5.1"
+#endif
 #ifdef CONFIGURE_TERMIOS_DISABLED
   #warning "The CONFIGURE_TERMIOS_DISABLED configuration option is obsolete since RTEMS 5.1"
 #endif
diff --git a/cpukit/include/rtems/config.h b/cpukit/include/rtems/config.h
index 24a654e39c..d9f91db741 100644
--- a/cpukit/include/rtems/config.h
+++ b/cpukit/include/rtems/config.h
@@ -34,7 +34,6 @@
 #include <rtems/score/userextdata.h>
 #include <rtems/score/watchdogticks.h>
 #include <rtems/rtems/config.h>
-#include <rtems/posix/config.h>
 #include <rtems/extension.h>
 #if defined(RTEMS_MULTIPROCESSING)
diff --git a/cpukit/include/rtems/posix/config.h b/cpukit/include/rtems/posix/config.h
deleted file mode 100644
index a7e60c2fee..0000000000
--- a/cpukit/include/rtems/posix/config.h
+++ /dev/null
@@ -1,60 +0,0 @@
- * @file
- * @brief User Defined Configuration Parameters Specific For The POSIX API
- * This include file contains the table of user defined configuration
- * parameters specific for the POSIX API.
- *  COPYRIGHT (c) 1989-2014.
- *  On-Line Applications Research Corporation (OAR).
- *  The license and distribution terms for this file may be
- *  found in the file LICENSE in this distribution or at
- *  http://www.rtems.org/license/LICENSE.
-#ifndef _RTEMS_POSIX_CONFIG_H
-#define _RTEMS_POSIX_CONFIG_H
-#include <stdint.h>
-#ifdef __cplusplus
-extern "C" {
-#endif
- *  @defgroup PosixConfig Configuration
- *  @ingroup POSIXAPI
- *  This encapsulates functionality related to the application's configuration
- *  of the Classic API including the maximum number of each class of objects.
- *  For now, we are only allowing the user to specify the entry point
- *  and stack size for POSIX initialization threads.
-typedef struct {
-  /** This is the entry point for a POSIX initialization thread. */
-  void       *(*thread_entry)(void *);
-  /** This is the stack size for a POSIX initialization thread. */
-  int       stack_size;
-} posix_initialization_threads_table;
-extern posix_initialization_threads_table * const
-  _Configuration_POSIX_Initialization_threads;
-extern const size_t _Configuration_POSIX_Initialization_thread_count;
-#ifdef __cplusplus
-#endif
-#endif
-/* end of include file */
diff --git a/cpukit/include/rtems/posix/pthread.h b/cpukit/include/rtems/posix/pthread.h
index 5df938e0b9..8aa11c53fe 100644
--- a/cpukit/include/rtems/posix/pthread.h
+++ b/cpukit/include/rtems/posix/pthread.h
@@ -36,15 +36,32 @@ extern "C" {
+ *  For now, we are only allowing the user to specify the entry point
+ *  and stack size for POSIX initialization threads.
+typedef struct {
+  /** This is the entry point for a POSIX initialization thread. */
+  void       *(*thread_entry)(void *);
+  /** This is the stack size for a POSIX initialization thread. */
+  int       stack_size;
+} posix_initialization_threads_table;
 extern const size_t _POSIX_Threads_Minimum_stack_size;
- * @brief POSIX threads initialize user threads body.
+ * @brief Initialization table for the first user POSIX thread.
- * This routine creates and starts all configured user
- * initialization threads.
+ * This table is used by _POSIX_Threads_Initialize_user_thread() and
+ * initialized via <rtems/confdefs.h>.
+extern const posix_initialization_threads_table
+  _POSIX_Threads_User_thread_table;
+ * @brief System initialization handler to create the first user POSIX thread.
-extern void _POSIX_Threads_Initialize_user_threads_body(void);
+extern void _POSIX_Threads_Initialize_user_thread( void );
  * The following defines the information control block used to manage
diff --git a/cpukit/include/rtems/posix/pthreadimpl.h b/cpukit/include/rtems/posix/pthreadimpl.h
index fd263c2761..74e46e4d92 100644
--- a/cpukit/include/rtems/posix/pthreadimpl.h
+++ b/cpukit/include/rtems/posix/pthreadimpl.h
@@ -20,7 +20,6 @@
 #define _RTEMS_POSIX_PTHREADIMPL_H
 #include <rtems/posix/pthread.h>
 #include <rtems/posix/threadsup.h>
diff --git a/cpukit/posix/src/pthreadinitthreads.c b/cpukit/posix/src/pthreadinitthreads.c
index 89163f43ab..3adaa8b7ab 100644
--- a/cpukit/posix/src/pthreadinitthreads.c
+++ b/cpukit/posix/src/pthreadinitthreads.c
@@ -18,33 +18,22 @@
 #include "config.h"
 #endif
-#include <errno.h>
+#include <rtems/posix/pthread.h>
 #include <pthread.h>
-#include <limits.h>
-#include <rtems/config.h>
-#include <rtems/score/stack.h>
-#include <rtems/score/thread.h>
-#include <rtems/score/wkspace.h>
-#include <rtems/posix/posixapi.h>
-#include <rtems/posix/pthreadimpl.h>
-#include <rtems/posix/priorityimpl.h>
+#include <rtems/score/assert.h>
+#include <rtems/score/threadimpl.h>
+#include <rtems/score/interr.h>
-void _POSIX_Threads_Initialize_user_threads_body(void)
+void _POSIX_Threads_Initialize_user_thread( void )
-  int                                 eno;
-  uint32_t                            index;
-  uint32_t                            maximum;
-  posix_initialization_threads_table *user_threads;
-  pthread_t                           thread_id;
-  pthread_attr_t                      attr;
-  user_threads = _Configuration_POSIX_Initialization_threads;
-  maximum      = _Configuration_POSIX_Initialization_thread_count;
+  int                                       eno;
+  const posix_initialization_threads_table *user_thread;
+  pthread_t                                 thread_id;
+  pthread_attr_t                            attr;
-  if ( !user_threads )
-    return;
+  user_thread = &_POSIX_Threads_User_thread_table;
    *  Be careful .. if the default attribute set changes, this may need to.
@@ -53,29 +42,27 @@ void _POSIX_Threads_Initialize_user_threads_body(void)
    *  to inherit the idle tasks attributes.
-  for ( index=0 ; index < maximum ; index++ ) {
-     * There is no way for these calls to fail in this situation.
-    eno = pthread_attr_init( &attr );
-    _Assert( eno == 0 );
-    eno = pthread_attr_setinheritsched( &attr, PTHREAD_EXPLICIT_SCHED );
-    eno = pthread_attr_setstacksize(&attr, user_threads[ index ].stack_size);
+   * There is no way for these calls to fail in this situation.
+  eno = pthread_attr_init( &attr );
+  _Assert( eno == 0 );
+  eno = pthread_attr_setinheritsched( &attr, PTHREAD_EXPLICIT_SCHED );
+  eno = pthread_attr_setstacksize( &attr, user_thread->stack_size );
-    eno = pthread_create(
-      &thread_id,
-      &attr,
-      user_threads[ index ].thread_entry,
-      NULL
-    if ( eno != 0 ) {
-      _Internal_error( INTERNAL_ERROR_POSIX_INIT_THREAD_CREATE_FAILED );
+  eno = pthread_create(
+    &thread_id,
+    &attr,
+    user_thread->thread_entry,
+    NULL
+  if ( eno != 0 ) {
+    _Internal_error( INTERNAL_ERROR_POSIX_INIT_THREAD_CREATE_FAILED );
-    if ( _Thread_Global_constructor == 0 ) {
-      _Thread_Global_constructor = thread_id;
+  if ( _Thread_Global_constructor == 0 ) {
+    _Thread_Global_constructor = thread_id;
diff --git a/testsuites/psxtests/psxfatal01/init.c b/testsuites/psxtests/psxfatal01/init.c
index fb0e2b24ed..ffc5b35b12 100644
--- a/testsuites/psxtests/psxfatal01/init.c
+++ b/testsuites/psxtests/psxfatal01/init.c
@@ -8,27 +8,7 @@
  * Classic API Init task create failure
-#include <errno.h>
- *  Way too much stack space.  Should generate a fatal error
- *  on the init task create.
-#define CONFIGURE_POSIX_HAS_OWN_INIT_THREAD_TABLE
-#define CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE 0
-posix_initialization_threads_table POSIX_Initialization_threads[] = {
-  { NULL,   /* bad thread entry */
-    0
-#define CONFIGURE_POSIX_INIT_THREAD_TABLE_NAME POSIX_Initialization_threads
-#define CONFIGURE_POSIX_INIT_THREAD_TABLE_SIZE \
-  sizeof(CONFIGURE_POSIX_INIT_THREAD_TABLE_NAME) / \
-      sizeof(posix_initialization_threads_table)
+#define CONFIGURE_POSIX_INIT_THREAD_ENTRY_POINT NULL
 #define FATAL_ERROR_TEST_NAME            "1"
 #define FATAL_ERROR_DESCRIPTION \
diff --git a/testsuites/psxtests/psxfatal02/init.c b/testsuites/psxtests/psxfatal02/init.c
index 260c0aea0d..eaf933092d 100644
--- a/testsuites/psxtests/psxfatal02/init.c
+++ b/testsuites/psxtests/psxfatal02/init.c
@@ -8,39 +8,25 @@
-#include <errno.h>
-  { POSIX_Init,
-#if INT_MAX < (12 * 1024 * 1024)
-    INT_MAX
-#else
-    12 * 1024 * 1024 /* too much stack */
-#endif
 #define FATAL_ERROR_TEST_NAME            "2"
         "POSIX API Init thread create failure -- no memory for stack"
 #define FATAL_ERROR_EXPECTED_SOURCE      INTERNAL_ERROR_CORE
 #define FATAL_ERROR_EXPECTED_ERROR       INTERNAL_ERROR_POSIX_INIT_THREAD_CREATE_FAILED
+static void *stack_allocator(size_t unused)
+  return NULL;
+static void stack_deallocator(void *unused)
+#define CONFIGURE_TASK_STACK_ALLOCATOR stack_allocator
+#define CONFIGURE_TASK_STACK_DEALLOCATOR stack_deallocator
 static void force_error(void)
   /* we will not run this far */
2.16.4
