[PATCH 10/18] config: Add _Watchdog_Microseconds_per_tick
Fri Feb 14 16:02:35 UTC 2020
Move the microseconds per tick configuration constant out of the
configuration table.
Add WATCHDOG_MICROSECONDS_PER_TICK_DEFAULT and use it to provide a
default definition of the watchdog ticks constants.
Update #3875.
 cpukit/Makefile.am                         |  1 +
 cpukit/include/rtems/confdefs.h            | 25 ++++++++++--------
 cpukit/include/rtems/config.h              | 10 ++------
 cpukit/include/rtems/score/watchdogticks.h | 13 ++++++++++
 cpukit/score/src/watchdogticksdefault.c    | 41 ++++++++++++++++++++++++++++++
 5 files changed, 71 insertions(+), 19 deletions(-)
 create mode 100644 cpukit/score/src/watchdogticksdefault.c
diff --git a/cpukit/Makefile.am b/cpukit/Makefile.am
index 1d3935776b..c3bdd284cd 100644
--- a/cpukit/Makefile.am
+++ b/cpukit/Makefile.am
@@ -1001,6 +1001,7 @@ librtemscpu_a_SOURCES += score/src/coretodhookrun.c
 librtemscpu_a_SOURCES += score/src/coretodhookunregister.c
 librtemscpu_a_SOURCES += score/src/watchdogremove.c
 librtemscpu_a_SOURCES += score/src/watchdogtick.c
+librtemscpu_a_SOURCES += score/src/watchdogticksdefault.c
 librtemscpu_a_SOURCES += score/src/watchdogtickssinceboot.c
 librtemscpu_a_SOURCES += score/src/userextaddset.c
 librtemscpu_a_SOURCES += score/src/userext.c
diff --git a/cpukit/include/rtems/confdefs.h b/cpukit/include/rtems/confdefs.h
index 0181af356a..4c2c80b2a9 100644
--- a/cpukit/include/rtems/confdefs.h
+++ b/cpukit/include/rtems/confdefs.h
@@ -1964,10 +1964,8 @@ extern "C" {
 /** The configures the number of microseconds per clock tick. */
-#ifndef CONFIGURE_MICROSECONDS_PER_TICK
-  #define CONFIGURE_MICROSECONDS_PER_TICK \
-          RTEMS_MILLISECONDS_TO_MICROSECONDS(10)
-#endif
+#if defined(CONFIGURE_MICROSECONDS_PER_TICK) && \
+  CONFIGURE_MICROSECONDS_PER_TICK != WATCHDOG_MICROSECONDS_PER_TICK_DEFAULT
 #if 1000000 % CONFIGURE_MICROSECONDS_PER_TICK != 0
   #warning "The clock ticks per second is not an integer"
@@ -1977,7 +1975,18 @@ extern "C" {
   #error "The CONFIGURE_MICROSECONDS_PER_TICK must be positive"
 #endif
-#define _CONFIGURE_TICKS_PER_SECOND (1000000 / CONFIGURE_MICROSECONDS_PER_TICK)
+#ifdef CONFIGURE_INIT
+  const uint32_t _Watchdog_Microseconds_per_tick =
+    CONFIGURE_MICROSECONDS_PER_TICK;
+  const uint32_t _Watchdog_Nanoseconds_per_tick =
+    (uint32_t) 1000 * CONFIGURE_MICROSECONDS_PER_TICK;
+  const uint32_t _Watchdog_Ticks_per_second =
+    1000000 / CONFIGURE_MICROSECONDS_PER_TICK;
+#endif
+#endif /* CONFIGURE_MICROSECONDS_PER_TICK */
 /** The configures the number of clock ticks per timeslice. */
 #ifndef CONFIGURE_TICKS_PER_TIMESLICE
@@ -2474,11 +2483,6 @@ struct _reent *__getreent(void)
       sizeof( Thread_queue_Configured_heads );
   #endif
-  const uint32_t _Watchdog_Nanoseconds_per_tick =
-    (uint32_t) 1000 * CONFIGURE_MICROSECONDS_PER_TICK;
-  const uint32_t _Watchdog_Ticks_per_second = _CONFIGURE_TICKS_PER_SECOND;
   const size_t _Thread_Initial_thread_count =
     rtems_resource_maximum_per_allocation( _CONFIGURE_TASKS ) +
     rtems_resource_maximum_per_allocation( CONFIGURE_MAXIMUM_POSIX_THREADS );
@@ -2644,7 +2648,6 @@ struct _reent *__getreent(void)
   const rtems_configuration_table Configuration = {
     CONFIGURE_EXECUTIVE_RAM_SIZE,             /* required RTEMS workspace */
-    CONFIGURE_MICROSECONDS_PER_TICK,          /* microseconds per clock tick */
     CONFIGURE_TICKS_PER_TIMESLICE,            /* ticks per timeslice quantum */
     CONFIGURE_IDLE_TASK_BODY,                 /* user's IDLE task */
     CONFIGURE_IDLE_TASK_STACK_SIZE,           /* IDLE task stack size */
diff --git a/cpukit/include/rtems/config.h b/cpukit/include/rtems/config.h
index d9f91db741..84917366f3 100644
--- a/cpukit/include/rtems/config.h
+++ b/cpukit/include/rtems/config.h
@@ -86,12 +86,6 @@ typedef struct {
   uintptr_t                      work_space_size;
-   * This field specifies the number of microseconds which elapse
-   * between clock ticks.  This is the basis for RTEMS timing.
-  uint32_t                       microseconds_per_tick;
    * This field specifies the number of ticks in each task's timeslice.
@@ -162,9 +156,9 @@ uintptr_t rtems_configuration_get_stack_space_size( void );
 uint32_t rtems_configuration_get_maximum_extensions( void );
 #define rtems_configuration_get_microseconds_per_tick() \
-        (Configuration.microseconds_per_tick)
+        (_Watchdog_Microseconds_per_tick)
 #define rtems_configuration_get_milliseconds_per_tick() \
-        (Configuration.microseconds_per_tick / 1000)
+        (_Watchdog_Microseconds_per_tick / 1000)
 #define rtems_configuration_get_nanoseconds_per_tick() \
         (_Watchdog_Nanoseconds_per_tick)
diff --git a/cpukit/include/rtems/score/watchdogticks.h b/cpukit/include/rtems/score/watchdogticks.h
index e7cf3f3ea3..eaeddb5e6b 100644
--- a/cpukit/include/rtems/score/watchdogticks.h
+++ b/cpukit/include/rtems/score/watchdogticks.h
@@ -42,6 +42,11 @@ typedef uint32_t   Watchdog_Interval;
 #define WATCHDOG_NO_TIMEOUT 0
+ * @brief Default value for the watchdog tick interval in microseconds.
+#define WATCHDOG_MICROSECONDS_PER_TICK_DEFAULT 10000
  * @brief The watchdog ticks counter.
@@ -49,6 +54,14 @@ typedef uint32_t   Watchdog_Interval;
 extern volatile Watchdog_Interval _Watchdog_Ticks_since_boot;
+ * @brief The watchdog microseconds per tick.
+ * This constant is defined by the application configuration via
+ * <rtems/confdefs.h>.
+extern const uint32_t _Watchdog_Microseconds_per_tick;
  * @brief The watchdog nanoseconds per tick.
diff --git a/cpukit/score/src/watchdogticksdefault.c b/cpukit/score/src/watchdogticksdefault.c
new file mode 100644
index 0000000000..412de71c77
--- /dev/null
+++ b/cpukit/score/src/watchdogticksdefault.c
@@ -0,0 +1,41 @@
+ * SPDX-License-Identifier: BSD-2-Clause
+ * Copyright (C) 2020 embedded brains GmbH
+ * are met:
+#if HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems/score/watchdogticks.h>
+const uint32_t _Watchdog_Microseconds_per_tick =
+  WATCHDOG_MICROSECONDS_PER_TICK_DEFAULT;
+const uint32_t _Watchdog_Nanoseconds_per_tick =
+  WATCHDOG_MICROSECONDS_PER_TICK_DEFAULT * 1000;
+const uint32_t _Watchdog_Ticks_per_second =
+  1000000 / WATCHDOG_MICROSECONDS_PER_TICK_DEFAULT;
2.16.4
