[PATCH 14/18] config: Add _Workspace_Size
Fri Feb 14 16:02:39 UTC 2020
Move the workspace size configuration constant out of the configuration
table.
Update #3875.
 cpukit/headers.am                        |  1 +
 cpukit/include/rtems/confdefs.h          |  3 +-
 cpukit/include/rtems/config.h            |  8 +---
 cpukit/include/rtems/score/wkspacedata.h | 65 ++++++++++++++++++++++++++++++++
 4 files changed, 70 insertions(+), 7 deletions(-)
 create mode 100644 cpukit/include/rtems/score/wkspacedata.h
diff --git a/cpukit/headers.am b/cpukit/headers.am
index 351e942cea..6e1ab4ccd0 100644
--- a/cpukit/headers.am
+++ b/cpukit/headers.am
@@ -408,6 +408,7 @@ include_rtems_score_HEADERS += include/rtems/score/watchdog.h
 include_rtems_score_HEADERS += include/rtems/score/watchdogimpl.h
 include_rtems_score_HEADERS += include/rtems/score/watchdogticks.h
 include_rtems_score_HEADERS += include/rtems/score/wkspace.h
+include_rtems_score_HEADERS += include/rtems/score/wkspacedata.h
 include_rtems_trace_HEADERS += include/rtems/trace/rtems-trace-buffer-vars.h
 include_sys_HEADERS += include/sys/_ffcounter.h
 include_sys_HEADERS += include/sys/cdefs_elf.h
diff --git a/cpukit/include/rtems/confdefs.h b/cpukit/include/rtems/confdefs.h
index 1dfc06e158..ba1545782a 100644
--- a/cpukit/include/rtems/confdefs.h
+++ b/cpukit/include/rtems/confdefs.h
@@ -2660,7 +2660,6 @@ struct _reent *__getreent(void)
    * This is the primary Configuration Table for this application.
   const rtems_configuration_table Configuration = {
-    CONFIGURE_EXECUTIVE_RAM_SIZE,             /* required RTEMS workspace */
     #ifdef CONFIGURE_UNIFIED_WORK_AREAS       /* true for unified work areas */
       true,
     #else
@@ -2678,6 +2677,8 @@ struct _reent *__getreent(void)
     #endif
+  const uintptr_t _Workspace_Size = CONFIGURE_EXECUTIVE_RAM_SIZE;
   #ifdef CONFIGURE_DIRTY_MEMORY
     RTEMS_SYSINIT_ITEM(
       _Memory_Dirty_free_areas,
diff --git a/cpukit/include/rtems/config.h b/cpukit/include/rtems/config.h
index 017b4ed476..0b5527c76d 100644
--- a/cpukit/include/rtems/config.h
+++ b/cpukit/include/rtems/config.h
@@ -34,6 +34,7 @@
 #include <rtems/score/userextdata.h>
 #include <rtems/score/threadidledata.h>
 #include <rtems/score/watchdogticks.h>
+#include <rtems/score/wkspacedata.h>
 #include <rtems/rtems/config.h>
 #include <rtems/extension.h>
 #if defined(RTEMS_MULTIPROCESSING)
@@ -82,11 +83,6 @@ typedef Stack_Allocator_free rtems_stack_free_hook;
  *     + required number of each object type for each API configured
 typedef struct {
-   * This field specifies the size in bytes of the RTEMS Workspace.
-  uintptr_t                      work_space_size;
    * @brief Specifies if a unified work area is used or not.
@@ -132,7 +128,7 @@ extern const rtems_configuration_table Configuration;
 uintptr_t rtems_configuration_get_stack_space_size( void );
 #define rtems_configuration_get_work_space_size() \
-        (Configuration.work_space_size + \
+        (_Workspace_Size + \
           (rtems_configuration_get_stack_allocator_avoids_work_space() ? \
             0 : rtems_configuration_get_stack_space_size()))
diff --git a/cpukit/include/rtems/score/wkspacedata.h b/cpukit/include/rtems/score/wkspacedata.h
new file mode 100644
index 0000000000..6a5a9bc0b6
--- /dev/null
+++ b/cpukit/include/rtems/score/wkspacedata.h
@@ -0,0 +1,65 @@
+ * @file
+ * @ingroup RTEMSScoreWorkspace
+ * @brief Constants for the idle threads.
+ * SPDX-License-Identifier: BSD-2-Clause
+ * Copyright (C) 2020 embedded brains GmbH
+ * are met:
+#ifndef _RTEMS_SCORE_WKSPACEDATA_H
+#define _RTEMS_SCORE_WKSPACEDATA_H
+#include <rtems/score/basedefs.h>
+#ifdef __cplusplus
+extern "C" {
+#endif
+ * @addtogroup RTEMSScoreWorkspace
+ * @brief The workspace size in bytes.
+ * This constant is defined by the application configuration via
+ * <rtems/confdefs.h>.
+extern const uintptr_t _Workspace_Size;
+#ifdef __cplusplus
+#endif
+#endif /* _RTEMS_SCORE_WKSPACEDATA_H */
2.16.4
