[PATCH 15/18] config: Add _Workspace_Is_unified
Fri Feb 14 16:02:40 UTC 2020
Move the unified workspace configuration constant out of the
configuration table.
Provide a default definition of the unified workspace constant.
Update #3875.
 cpukit/Makefile.am                         |  1 +
 cpukit/include/rtems/confdefs.h            |  9 ++++----
 cpukit/include/rtems/config.h              | 10 +--------
 cpukit/include/rtems/score/wkspacedata.h   |  8 +++++++
 cpukit/score/src/wkspaceisunifieddefault.c | 34 ++++++++++++++++++++++++++++++
 5 files changed, 48 insertions(+), 14 deletions(-)
 create mode 100644 cpukit/score/src/wkspaceisunifieddefault.c
diff --git a/cpukit/Makefile.am b/cpukit/Makefile.am
index 33cb9e843e..76267c3aeb 100644
--- a/cpukit/Makefile.am
+++ b/cpukit/Makefile.am
@@ -1016,6 +1016,7 @@ librtemscpu_a_SOURCES += score/src/debugisthreaddispatchingallowed.c
 librtemscpu_a_SOURCES += score/src/interr.c
 librtemscpu_a_SOURCES += score/src/isr.c
 librtemscpu_a_SOURCES += score/src/wkspace.c
+librtemscpu_a_SOURCES += score/src/wkspaceisunifieddefault.c
 librtemscpu_a_SOURCES += score/src/wkstringduplicate.c
 librtemscpu_a_SOURCES += score/src/ioprintf.c
 librtemscpu_a_SOURCES += score/src/iovprintf.c
diff --git a/cpukit/include/rtems/confdefs.h b/cpukit/include/rtems/confdefs.h
index ba1545782a..07478eb299 100644
--- a/cpukit/include/rtems/confdefs.h
+++ b/cpukit/include/rtems/confdefs.h
@@ -2660,11 +2660,6 @@ struct _reent *__getreent(void)
    * This is the primary Configuration Table for this application.
   const rtems_configuration_table Configuration = {
-    #ifdef CONFIGURE_UNIFIED_WORK_AREAS       /* true for unified work areas */
-      true,
-    #else
-      false,
-    #endif
     #ifdef RTEMS_SMP
       #ifdef _CONFIGURE_SMP_APPLICATION
         true,
@@ -2679,6 +2674,10 @@ struct _reent *__getreent(void)
   const uintptr_t _Workspace_Size = CONFIGURE_EXECUTIVE_RAM_SIZE;
+  #ifdef CONFIGURE_UNIFIED_WORK_AREAS
+    const bool _Workspace_Is_unified = true;
+  #endif
   #ifdef CONFIGURE_DIRTY_MEMORY
     RTEMS_SYSINIT_ITEM(
       _Memory_Dirty_free_areas,
diff --git a/cpukit/include/rtems/config.h b/cpukit/include/rtems/config.h
index 0b5527c76d..6489e4e4e8 100644
--- a/cpukit/include/rtems/config.h
+++ b/cpukit/include/rtems/config.h
@@ -83,14 +83,6 @@ typedef Stack_Allocator_free rtems_stack_free_hook;
  *     + required number of each object type for each API configured
 typedef struct {
-   * @brief Specifies if a unified work area is used or not.
-   * If this element is @a true, then the RTEMS Workspace and the C Program
-   * Heap use the same heap, otherwise they use separate heaps.
-  bool                           unified_work_area;
   #ifdef RTEMS_SMP
     bool                         smp_enabled;
   #endif
@@ -111,7 +103,7 @@ extern const rtems_configuration_table Configuration;
 #define rtems_configuration_get_unified_work_area() \
-        (Configuration.unified_work_area)
+        (_Workspace_Is_unified)
  * @brief Return if the stack allocator avoids the work space.
diff --git a/cpukit/include/rtems/score/wkspacedata.h b/cpukit/include/rtems/score/wkspacedata.h
index 6a5a9bc0b6..26a7e61201 100644
--- a/cpukit/include/rtems/score/wkspacedata.h
+++ b/cpukit/include/rtems/score/wkspacedata.h
@@ -56,6 +56,14 @@ extern "C" {
 extern const uintptr_t _Workspace_Size;
+ * @brief Indicates if the workspace and C program heap are unified.
+ * This constant is defined by the application configuration via
+ * <rtems/confdefs.h>.
+extern const bool _Workspace_Is_unified;
 #ifdef __cplusplus
diff --git a/cpukit/score/src/wkspaceisunifieddefault.c b/cpukit/score/src/wkspaceisunifieddefault.c
new file mode 100644
index 0000000000..caf5c129c8
--- /dev/null
+++ b/cpukit/score/src/wkspaceisunifieddefault.c
@@ -0,0 +1,34 @@
+ * SPDX-License-Identifier: BSD-2-Clause
+ * Copyright (C) 2020 embedded brains GmbH
+ * are met:
+#if HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems/score/wkspacedata.h>
+const bool _Workspace_Is_unified = false;
2.16.4
