[PATCH 6/6] config: Remove CONFIGURE_DISABLE_SMP_CONFIGURATION
Sat Feb 15 12:36:23 UTC 2020
The CONFIGURE_DISABLE_SMP_CONFIGURATION configuration option and
rtems_configuration_is_smp_enabled() were added during the SMP support
development cycle as a workaround to fix some testsuite failures in SMP
configurations.  All use cases were replaced with tests for specific
conditions.  The configuration option and test macro were undocumented.
Close #3876.
 cpukit/include/rtems/confdefs.h                       | 19 -------------------
 cpukit/include/rtems/config.h                         | 13 -------------
 cpukit/include/rtems/score/smp.h                      | 13 -------------
 testsuites/ada/support/initimpl.h                     |  2 --
 testsuites/libtests/block08/system.h                  |  2 --
 testsuites/libtests/cpuuse/system.h                   |  2 --
 testsuites/libtests/rtmonuse/system.h                 |  1 -
 testsuites/libtests/termios05/init.c                  |  2 --
 testsuites/smptests/smpunsupported01/init.c           |  2 --
 testsuites/sptests/sp01/system.h                      |  2 --
 testsuites/sptests/sp04/system.h                      |  2 --
 testsuites/sptests/sp07/system.h                      |  2 --
 testsuites/sptests/sp08/init.c                        |  2 --
 testsuites/sptests/sp12/system.h                      |  2 --
 testsuites/sptests/sp13/system.h                      |  2 --
 testsuites/sptests/sp14/system.h                      |  2 --
 testsuites/sptests/sp16/system.h                      |  2 --
 testsuites/sptests/sp20/system.h                      |  2 --
 testsuites/sptests/sp37/system.h                      |  2 --
 testsuites/sptests/sp65/sp65impl.h                    |  2 --
 testsuites/sptests/spcbssched01/system.h              |  2 --
 testsuites/sptests/spcbssched02/system.h              |  2 --
 testsuites/sptests/spcbssched03/system.h              |  2 --
 testsuites/sptests/spedfsched01/system.h              |  2 --
 testsuites/sptests/spedfsched02/system.h              |  2 --
 testsuites/sptests/spedfsched03/system.h              |  2 --
 testsuites/sptests/spfatal29/init.c                   |  2 --
 testsuites/sptests/spfifo03/init.c                    |  2 --
 testsuites/sptests/spfifo05/init.c                    |  2 --
 .../sptests/spintrcritical06/spintrcritical06impl.h   |  2 --
 testsuites/sptests/spintrcritical15/init.c            |  2 --
 testsuites/sptests/spmrsp01/init.c                    |  2 --
 testsuites/sptests/spsimplesched02/init.c             |  2 --
 testsuites/tmtests/tm04/system.h                      |  2 --
 testsuites/tmtests/tm08/system.h                      |  2 --
 testsuites/tmtests/tm15/system.h                      |  2 --
 testsuites/tmtests/tm20/system.h                      |  2 --
 testsuites/tmtests/tm22/system.h                      |  2 --
 testsuites/tmtests/tm24/system.h                      |  2 --
 39 files changed, 116 deletions(-)
diff --git a/cpukit/include/rtems/confdefs.h b/cpukit/include/rtems/confdefs.h
index eb837fd389..d45287591e 100644
--- a/cpukit/include/rtems/confdefs.h
+++ b/cpukit/include/rtems/confdefs.h
@@ -159,18 +159,6 @@ extern "C" {
   #define _CONFIGURE_MAXIMUM_PROCESSORS 1
 #endif
- * An internal define to indicate that this is an SMP application
- * configuration.
-#ifdef RTEMS_SMP
-  #if !defined(CONFIGURE_DISABLE_SMP_CONFIGURATION)
-    #define _CONFIGURE_SMP_APPLICATION
-  #elif _CONFIGURE_MAXIMUM_PROCESSORS > 1
-    #error "CONFIGURE_DISABLE_SMP_CONFIGURATION and CONFIGURE_MAXIMUM_PROCESSORS > 1 makes no sense"
-  #endif
-#endif
  * This sets up the resources for the FIFOs/pipes.
@@ -2576,13 +2564,6 @@ struct _reent *__getreent(void)
   #endif
   #ifdef RTEMS_SMP
-    const bool _SMP_Is_enabled =
-      #ifdef _CONFIGURE_SMP_APPLICATION
-        true;
-      #else
-        false;
-      #endif
     const uint32_t _SMP_Processor_configured_maximum =
       _CONFIGURE_MAXIMUM_PROCESSORS;
   #endif
diff --git a/cpukit/include/rtems/config.h b/cpukit/include/rtems/config.h
index 4811d0e704..e82c7abf11 100644
--- a/cpukit/include/rtems/config.h
+++ b/cpukit/include/rtems/config.h
@@ -150,19 +150,6 @@ uint32_t rtems_configuration_get_maximum_extensions( void );
     NULL
 #endif
- * @brief Returns true if the SMP mode of operation is enabled, and false
- * otherwise.
- * In uni-processor configurations this is a compile-time constant which
- * evaluates to false.
- * @retval true SMP mode of operation is enabled.
- * @retval false Otherwise.
-#define rtems_configuration_is_smp_enabled() \
-      (_SMP_Is_enabled)
  * @brief Returns the configured maximum count of processors.
diff --git a/cpukit/include/rtems/score/smp.h b/cpukit/include/rtems/score/smp.h
index 36cfd981ab..2722fbdcee 100644
--- a/cpukit/include/rtems/score/smp.h
+++ b/cpukit/include/rtems/score/smp.h
@@ -36,19 +36,6 @@ extern "C" {
- * @brief Indicates if SMP is enabled.
- * In SMP configurations, this constant is defined by the application
- * configuration via <rtems/confdefs.h>, otherwise it is a compile-time
- * constant with the value false.
-#if defined(RTEMS_SMP)
-  extern const bool _SMP_Is_enabled;
-#else
-  #define _SMP_Is_enabled false
-#endif
  * @brief The configured processor maximum.
diff --git a/testsuites/ada/support/initimpl.h b/testsuites/ada/support/initimpl.h
index 4d4165a83d..8076194ff1 100644
--- a/testsuites/ada/support/initimpl.h
+++ b/testsuites/ada/support/initimpl.h
@@ -49,8 +49,6 @@ void check_type(long type, long size, long alignment);
 #define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
-#define CONFIGURE_DISABLE_SMP_CONFIGURATION
 #include <rtems/confdefs.h>
 const char rtems_test_name[] = ADA_TEST_NAME;
diff --git a/testsuites/libtests/block08/system.h b/testsuites/libtests/block08/system.h
index 287ad38bc6..646de6da48 100644
--- a/testsuites/libtests/block08/system.h
+++ b/testsuites/libtests/block08/system.h
@@ -49,8 +49,6 @@ rtems_task Init(
 #define CONFIGURE_EXTRA_TASK_STACKS         (13 * RTEMS_MINIMUM_STACK_SIZE)
 /* end of include file */
diff --git a/testsuites/libtests/cpuuse/system.h b/testsuites/libtests/cpuuse/system.h
index ebf79e5005..28a6e56510 100644
--- a/testsuites/libtests/cpuuse/system.h
+++ b/testsuites/libtests/cpuuse/system.h
@@ -50,8 +50,6 @@ void Task_switch(
 #define CONFIGURE_RTEMS_INIT_TASKS_TABLE
 /* global variables */
diff --git a/testsuites/libtests/rtmonuse/system.h b/testsuites/libtests/rtmonuse/system.h
index 468c28693d..7f344a47e3 100644
--- a/testsuites/libtests/rtmonuse/system.h
+++ b/testsuites/libtests/rtmonuse/system.h
@@ -48,7 +48,6 @@ void Get_all_counters( void );
 #define CONFIGURE_EXTRA_TASK_STACKS           (20 * RTEMS_MINIMUM_STACK_SIZE)
diff --git a/testsuites/libtests/termios05/init.c b/testsuites/libtests/termios05/init.c
index 38b2e13d9e..1cd5c7371d 100644
--- a/testsuites/libtests/termios05/init.c
+++ b/testsuites/libtests/termios05/init.c
@@ -161,8 +161,6 @@ rtems_task Init(
diff --git a/testsuites/smptests/smpunsupported01/init.c b/testsuites/smptests/smpunsupported01/init.c
index dd9b52a3c5..19c1a1b190 100644
--- a/testsuites/smptests/smpunsupported01/init.c
+++ b/testsuites/smptests/smpunsupported01/init.c
@@ -27,8 +27,6 @@ static void test(void)
   rtems_mode mode;
   rtems_id id;
-  rtems_test_assert(rtems_configuration_is_smp_enabled());
   sc = rtems_task_mode(RTEMS_NO_PREEMPT, RTEMS_PREEMPT_MASK, &mode);
   rtems_test_assert(sc == RTEMS_NOT_IMPLEMENTED);
diff --git a/testsuites/sptests/sp01/system.h b/testsuites/sptests/sp01/system.h
index 5acd17f83c..bde5328aa9 100644
--- a/testsuites/sptests/sp01/system.h
+++ b/testsuites/sptests/sp01/system.h
@@ -31,8 +31,6 @@ rtems_task Task_1_through_3(
 #define CONFIGURE_EXTRA_TASK_STACKS         (4 * RTEMS_MINIMUM_STACK_SIZE)
 #define CONFIGURE_MAXIMUM_TASKS             4
diff --git a/testsuites/sptests/sp04/system.h b/testsuites/sptests/sp04/system.h
index db7ba4999d..67ed49cba6 100644
--- a/testsuites/sptests/sp04/system.h
+++ b/testsuites/sptests/sp04/system.h
@@ -52,8 +52,6 @@ void Task_switch(
 #define CONFIGURE_MAXIMUM_TIMERS            1
diff --git a/testsuites/sptests/sp07/system.h b/testsuites/sptests/sp07/system.h
index d171e85ebc..5e319661e1 100644
--- a/testsuites/sptests/sp07/system.h
+++ b/testsuites/sptests/sp07/system.h
@@ -74,8 +74,6 @@ void Task_exit_extension(
 #define CONFIGURE_MAXIMUM_TASKS             5
diff --git a/testsuites/sptests/sp08/init.c b/testsuites/sptests/sp08/init.c
index 2ed585ddd7..4229feb15c 100644
--- a/testsuites/sptests/sp08/init.c
+++ b/testsuites/sptests/sp08/init.c
@@ -316,8 +316,6 @@ rtems_task Init(
 /* end of file */
diff --git a/testsuites/sptests/sp12/system.h b/testsuites/sptests/sp12/system.h
index 7651b994b5..107831b3a0 100644
--- a/testsuites/sptests/sp12/system.h
+++ b/testsuites/sptests/sp12/system.h
@@ -65,8 +65,6 @@ rtems_task Task5(
 #define CONFIGURE_EXTRA_TASK_STACKS         (6 * RTEMS_MINIMUM_STACK_SIZE)
diff --git a/testsuites/sptests/sp13/system.h b/testsuites/sptests/sp13/system.h
index 21d769c82b..7a495963f6 100644
--- a/testsuites/sptests/sp13/system.h
+++ b/testsuites/sptests/sp13/system.h
@@ -97,8 +97,6 @@ TEST_EXTERN rtems_name Queue_name[ 4 ];      /* array of queue names */
 #define CONFIGURE_EXTRA_TASK_STACKS         (3 * RTEMS_MINIMUM_STACK_SIZE)
diff --git a/testsuites/sptests/sp14/system.h b/testsuites/sptests/sp14/system.h
index 38a84b369a..b0e04a129e 100644
--- a/testsuites/sptests/sp14/system.h
+++ b/testsuites/sptests/sp14/system.h
@@ -51,8 +51,6 @@ rtems_task Task_2(
 #define CONFIGURE_EXTRA_TASK_STACKS         (1 * RTEMS_MINIMUM_STACK_SIZE)
diff --git a/testsuites/sptests/sp16/system.h b/testsuites/sptests/sp16/system.h
index 38a44998fe..8299e7e8ca 100644
--- a/testsuites/sptests/sp16/system.h
+++ b/testsuites/sptests/sp16/system.h
@@ -54,8 +54,6 @@ rtems_task Task5(
diff --git a/testsuites/sptests/sp20/system.h b/testsuites/sptests/sp20/system.h
index 26e837a45b..4585639fe3 100644
--- a/testsuites/sptests/sp20/system.h
+++ b/testsuites/sptests/sp20/system.h
@@ -49,8 +49,6 @@ void Get_all_counters( void );
diff --git a/testsuites/sptests/sp37/system.h b/testsuites/sptests/sp37/system.h
index 0b9d888164..d7b98e40f5 100644
--- a/testsuites/sptests/sp37/system.h
+++ b/testsuites/sptests/sp37/system.h
@@ -39,8 +39,6 @@ rtems_task Init(
 #define CONFIGURE_MAXIMUM_TASKS             2
diff --git a/testsuites/sptests/sp65/sp65impl.h b/testsuites/sptests/sp65/sp65impl.h
index a557ede775..c5644b38b9 100644
--- a/testsuites/sptests/sp65/sp65impl.h
+++ b/testsuites/sptests/sp65/sp65impl.h
@@ -145,8 +145,6 @@ rtems_task Task_1(
diff --git a/testsuites/sptests/spcbssched01/system.h b/testsuites/sptests/spcbssched01/system.h
index 1f75749a30..0bc64fc501 100644
--- a/testsuites/sptests/spcbssched01/system.h
+++ b/testsuites/sptests/spcbssched01/system.h
@@ -37,8 +37,6 @@ rtems_task Task_1_through_3(
diff --git a/testsuites/sptests/spcbssched02/system.h b/testsuites/sptests/spcbssched02/system.h
index 007ca96810..fe3bdc7e21 100644
--- a/testsuites/sptests/spcbssched02/system.h
+++ b/testsuites/sptests/spcbssched02/system.h
@@ -43,8 +43,6 @@ rtems_task Task_Periodic(
 #define CONFIGURE_SCHEDULER_CBS
 #include <rtems/rtems/clock.h>
diff --git a/testsuites/sptests/spcbssched03/system.h b/testsuites/sptests/spcbssched03/system.h
index 1f864b5150..da20c575ca 100644
--- a/testsuites/sptests/spcbssched03/system.h
+++ b/testsuites/sptests/spcbssched03/system.h
@@ -47,8 +47,6 @@ rtems_task Tasks_Aperiodic(
diff --git a/testsuites/sptests/spedfsched01/system.h b/testsuites/sptests/spedfsched01/system.h
index acf1a8317f..add030ae48 100644
--- a/testsuites/sptests/spedfsched01/system.h
+++ b/testsuites/sptests/spedfsched01/system.h
diff --git a/testsuites/sptests/spedfsched02/system.h b/testsuites/sptests/spedfsched02/system.h
index f3280e400c..71bc96bbe2 100644
--- a/testsuites/sptests/spedfsched02/system.h
+++ b/testsuites/sptests/spedfsched02/system.h
 #define CONFIGURE_SCHEDULER_EDF
diff --git a/testsuites/sptests/spedfsched03/system.h b/testsuites/sptests/spedfsched03/system.h
index 71000be93d..6d6bb3d3be 100644
--- a/testsuites/sptests/spedfsched03/system.h
+++ b/testsuites/sptests/spedfsched03/system.h
diff --git a/testsuites/sptests/spfatal29/init.c b/testsuites/sptests/spfatal29/init.c
index 439eeef7ac..5df872d3d6 100644
--- a/testsuites/sptests/spfatal29/init.c
+++ b/testsuites/sptests/spfatal29/init.c
@@ -25,8 +25,6 @@
 static void timer(rtems_id id, void *arg)
   rtems_task_wake_after(RTEMS_YIELD_PROCESSOR);
diff --git a/testsuites/sptests/spfifo03/init.c b/testsuites/sptests/spfifo03/init.c
index ec054d2aef..287f899c36 100644
--- a/testsuites/sptests/spfifo03/init.c
+++ b/testsuites/sptests/spfifo03/init.c
@@ -217,8 +217,6 @@ rtems_task Init(
 #define CONFIGURE_IMFS_ENABLE_MKFIFO
diff --git a/testsuites/sptests/spfifo05/init.c b/testsuites/sptests/spfifo05/init.c
index c9ae0505c6..21021650b7 100644
--- a/testsuites/sptests/spfifo05/init.c
+++ b/testsuites/sptests/spfifo05/init.c
@@ -273,8 +273,6 @@ rtems_task Init(
diff --git a/testsuites/sptests/spintrcritical06/spintrcritical06impl.h b/testsuites/sptests/spintrcritical06/spintrcritical06impl.h
index 161f0502de..f0424e3dc8 100644
--- a/testsuites/sptests/spintrcritical06/spintrcritical06impl.h
+++ b/testsuites/sptests/spintrcritical06/spintrcritical06impl.h
@@ -139,8 +139,6 @@ rtems_task Init(
diff --git a/testsuites/sptests/spintrcritical15/init.c b/testsuites/sptests/spintrcritical15/init.c
index 6f2548ff6f..9de33b3cfb 100644
--- a/testsuites/sptests/spintrcritical15/init.c
+++ b/testsuites/sptests/spintrcritical15/init.c
@@ -111,8 +111,6 @@ rtems_task Init(
diff --git a/testsuites/sptests/spmrsp01/init.c b/testsuites/sptests/spmrsp01/init.c
index 0d03f1dc83..4539fcc919 100644
--- a/testsuites/sptests/spmrsp01/init.c
+++ b/testsuites/sptests/spmrsp01/init.c
@@ -334,8 +334,6 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/sptests/spsimplesched02/init.c b/testsuites/sptests/spsimplesched02/init.c
index 4a08a6c8ac..27e2f6577c 100644
--- a/testsuites/sptests/spsimplesched02/init.c
+++ b/testsuites/sptests/spsimplesched02/init.c
@@ -158,8 +158,6 @@ rtems_task Init(
 #define CONFIGURE_INIT_TASK_INITIAL_MODES   RTEMS_NO_PREEMPT
 #define CONFIGURE_INIT_TASK_PRIORITY        4
diff --git a/testsuites/tmtests/tm04/system.h b/testsuites/tmtests/tm04/system.h
index 764b979416..bca9c4e081 100644
--- a/testsuites/tmtests/tm04/system.h
+++ b/testsuites/tmtests/tm04/system.h
@@ -32,8 +32,6 @@ rtems_task Init(
diff --git a/testsuites/tmtests/tm08/system.h b/testsuites/tmtests/tm08/system.h
index ff756e4443..77eb08b602 100644
--- a/testsuites/tmtests/tm08/system.h
+++ b/testsuites/tmtests/tm08/system.h
@@ -31,8 +31,6 @@ rtems_task Init(
diff --git a/testsuites/tmtests/tm15/system.h b/testsuites/tmtests/tm15/system.h
index efb00325e0..8d98f096ab 100644
--- a/testsuites/tmtests/tm15/system.h
+++ b/testsuites/tmtests/tm15/system.h
@@ -33,8 +33,6 @@ rtems_id   Task_id[ OPERATION_COUNT+1 ];   /* array of task ids */
diff --git a/testsuites/tmtests/tm20/system.h b/testsuites/tmtests/tm20/system.h
index c12e34dfb0..9a73f4b2c5 100644
--- a/testsuites/tmtests/tm20/system.h
+++ b/testsuites/tmtests/tm20/system.h
@@ -36,8 +36,6 @@ rtems_id   Task_id[ OPERATION_COUNT+1 ];   /* array of task ids */
diff --git a/testsuites/tmtests/tm22/system.h b/testsuites/tmtests/tm22/system.h
index 9bc2f310be..a54c2ec3f0 100644
--- a/testsuites/tmtests/tm22/system.h
+++ b/testsuites/tmtests/tm22/system.h
@@ -37,8 +37,6 @@ rtems_task Init(
   CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE(100, MESSAGE_SIZE )
diff --git a/testsuites/tmtests/tm24/system.h b/testsuites/tmtests/tm24/system.h
index 8ab708e49f..d56e17903a 100644
--- a/testsuites/tmtests/tm24/system.h
+++ b/testsuites/tmtests/tm24/system.h
2.16.4
