[PATCH 6/6] config: Remove CONFIGURE_DISABLE_SMP_CONFIGURATION
Joel Sherrill
joel at rtems.org
Sat Feb 15 14:12:44 UTC 2020
Another historical detail for the commit message is that even in SMP
builds, uniprocesor tests used a uniprocesor schedule. It took us a while
to decide that the uniprocesor tests should behave the same with the proper
SMP scheduler.
This is a pretty fundamental realisation and probably is worth capturing as
a guiding principle for our tests.
On Sat, Feb 15, 2020, 6:36 AM Sebastian Huber <
> The CONFIGURE_DISABLE_SMP_CONFIGURATION configuration option and
> rtems_configuration_is_smp_enabled() were added during the SMP support
> development cycle as a workaround to fix some testsuite failures in SMP
> configurations. All use cases were replaced with tests for specific
> conditions. The configuration option and test macro were undocumented.
> Close #3876.
> cpukit/include/rtems/confdefs.h | 19
> cpukit/include/rtems/config.h | 13 -------------
> cpukit/include/rtems/score/smp.h | 13 -------------
> testsuites/ada/support/initimpl.h | 2 --
> testsuites/libtests/block08/system.h | 2 --
> testsuites/libtests/cpuuse/system.h | 2 --
> testsuites/libtests/rtmonuse/system.h | 1 -
> testsuites/libtests/termios05/init.c | 2 --
> testsuites/smptests/smpunsupported01/init.c | 2 --
> testsuites/sptests/sp01/system.h | 2 --
> testsuites/sptests/sp04/system.h | 2 --
> testsuites/sptests/sp07/system.h | 2 --
> testsuites/sptests/sp08/init.c | 2 --
> testsuites/sptests/sp12/system.h | 2 --
> testsuites/sptests/sp13/system.h | 2 --
> testsuites/sptests/sp14/system.h | 2 --
> testsuites/sptests/sp16/system.h | 2 --
> testsuites/sptests/sp20/system.h | 2 --
> testsuites/sptests/sp37/system.h | 2 --
> testsuites/sptests/sp65/sp65impl.h | 2 --
> testsuites/sptests/spcbssched01/system.h | 2 --
> testsuites/sptests/spcbssched02/system.h | 2 --
> testsuites/sptests/spcbssched03/system.h | 2 --
> testsuites/sptests/spedfsched01/system.h | 2 --
> testsuites/sptests/spedfsched02/system.h | 2 --
> testsuites/sptests/spedfsched03/system.h | 2 --
> testsuites/sptests/spfatal29/init.c | 2 --
> testsuites/sptests/spfifo03/init.c | 2 --
> testsuites/sptests/spfifo05/init.c | 2 --
> .../sptests/spintrcritical06/spintrcritical06impl.h | 2 --
> testsuites/sptests/spintrcritical15/init.c | 2 --
> testsuites/sptests/spmrsp01/init.c | 2 --
> testsuites/sptests/spsimplesched02/init.c | 2 --
> testsuites/tmtests/tm04/system.h | 2 --
> testsuites/tmtests/tm08/system.h | 2 --
> testsuites/tmtests/tm15/system.h | 2 --
> testsuites/tmtests/tm20/system.h | 2 --
> testsuites/tmtests/tm22/system.h | 2 --
> testsuites/tmtests/tm24/system.h | 2 --
> 39 files changed, 116 deletions(-)
> diff --git a/cpukit/include/rtems/confdefs.h
> b/cpukit/include/rtems/confdefs.h
> index eb837fd389..d45287591e 100644
> --- a/cpukit/include/rtems/confdefs.h
> +++ b/cpukit/include/rtems/confdefs.h
> @@ -159,18 +159,6 @@ extern "C" {
> #define _CONFIGURE_MAXIMUM_PROCESSORS 1
> #endif
> - * An internal define to indicate that this is an SMP application
> - * configuration.
> -#ifdef RTEMS_SMP
> - #if !defined(CONFIGURE_DISABLE_SMP_CONFIGURATION)
> - #define _CONFIGURE_SMP_APPLICATION
> - #elif _CONFIGURE_MAXIMUM_PROCESSORS > 1
> - #error "CONFIGURE_DISABLE_SMP_CONFIGURATION and
> CONFIGURE_MAXIMUM_PROCESSORS > 1 makes no sense"
> - #endif
> -#endif
> * This sets up the resources for the FIFOs/pipes.
> @@ -2576,13 +2564,6 @@ struct _reent *__getreent(void)
> #endif
> #ifdef RTEMS_SMP
> - const bool _SMP_Is_enabled =
> - #ifdef _CONFIGURE_SMP_APPLICATION
> - true;
> - #else
> - false;
> - #endif
> const uint32_t _SMP_Processor_configured_maximum =
> _CONFIGURE_MAXIMUM_PROCESSORS;
> #endif
> diff --git a/cpukit/include/rtems/config.h b/cpukit/include/rtems/config.h
> index 4811d0e704..e82c7abf11 100644
> --- a/cpukit/include/rtems/config.h
> +++ b/cpukit/include/rtems/config.h
> @@ -150,19 +150,6 @@ uint32_t rtems_configuration_get_maximum_extensions(
> void );
> NULL
> #endif
> - * @brief Returns true if the SMP mode of operation is enabled, and false
> - * otherwise.
> - * In uni-processor configurations this is a compile-time constant which
> - * evaluates to false.
> - * @retval true SMP mode of operation is enabled.
> - * @retval false Otherwise.
> -#define rtems_configuration_is_smp_enabled() \
> - (_SMP_Is_enabled)
> * @brief Returns the configured maximum count of processors.
> diff --git a/cpukit/include/rtems/score/smp.h
> b/cpukit/include/rtems/score/smp.h
> index 36cfd981ab..2722fbdcee 100644
> --- a/cpukit/include/rtems/score/smp.h
> +++ b/cpukit/include/rtems/score/smp.h
> @@ -36,19 +36,6 @@ extern "C" {
> - * @brief Indicates if SMP is enabled.
> - * In SMP configurations, this constant is defined by the application
> - * configuration via <rtems/confdefs.h>, otherwise it is a compile-time
> - * constant with the value false.
> -#if defined(RTEMS_SMP)
> - extern const bool _SMP_Is_enabled;
> -#else
> - #define _SMP_Is_enabled false
> -#endif
> * @brief The configured processor maximum.
> diff --git a/testsuites/ada/support/initimpl.h
> b/testsuites/ada/support/initimpl.h
> index 4d4165a83d..8076194ff1 100644
> --- a/testsuites/ada/support/initimpl.h
> +++ b/testsuites/ada/support/initimpl.h
> @@ -49,8 +49,6 @@ void check_type(long type, long size, long alignment);
> #define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
> -#define CONFIGURE_DISABLE_SMP_CONFIGURATION
> #include <rtems/confdefs.h>
> const char rtems_test_name[] = ADA_TEST_NAME;
> diff --git a/testsuites/libtests/block08/system.h
> b/testsuites/libtests/block08/system.h
> index 287ad38bc6..646de6da48 100644
> --- a/testsuites/libtests/block08/system.h
> +++ b/testsuites/libtests/block08/system.h
> @@ -49,8 +49,6 @@ rtems_task Init(
> #define CONFIGURE_EXTRA_TASK_STACKS (13 *
> RTEMS_MINIMUM_STACK_SIZE)
> /* end of include file */
> diff --git a/testsuites/libtests/cpuuse/system.h
> b/testsuites/libtests/cpuuse/system.h
> index ebf79e5005..28a6e56510 100644
> --- a/testsuites/libtests/cpuuse/system.h
> +++ b/testsuites/libtests/cpuuse/system.h
> @@ -50,8 +50,6 @@ void Task_switch(
> #define CONFIGURE_RTEMS_INIT_TASKS_TABLE
> /* global variables */
> diff --git a/testsuites/libtests/rtmonuse/system.h
> b/testsuites/libtests/rtmonuse/system.h
> index 468c28693d..7f344a47e3 100644
> --- a/testsuites/libtests/rtmonuse/system.h
> +++ b/testsuites/libtests/rtmonuse/system.h
> @@ -48,7 +48,6 @@ void Get_all_counters( void );
> #define CONFIGURE_EXTRA_TASK_STACKS (20 *
> diff --git a/testsuites/libtests/termios05/init.c
> b/testsuites/libtests/termios05/init.c
> index 38b2e13d9e..1cd5c7371d 100644
> --- a/testsuites/libtests/termios05/init.c
> +++ b/testsuites/libtests/termios05/init.c
> @@ -161,8 +161,6 @@ rtems_task Init(
> diff --git a/testsuites/smptests/smpunsupported01/init.c
> b/testsuites/smptests/smpunsupported01/init.c
> index dd9b52a3c5..19c1a1b190 100644
> --- a/testsuites/smptests/smpunsupported01/init.c
> +++ b/testsuites/smptests/smpunsupported01/init.c
> @@ -27,8 +27,6 @@ static void test(void)
> rtems_mode mode;
> rtems_id id;
> - rtems_test_assert(rtems_configuration_is_smp_enabled());
> sc = rtems_task_mode(RTEMS_NO_PREEMPT, RTEMS_PREEMPT_MASK, &mode);
> rtems_test_assert(sc == RTEMS_NOT_IMPLEMENTED);
> diff --git a/testsuites/sptests/sp01/system.h
> b/testsuites/sptests/sp01/system.h
> index 5acd17f83c..bde5328aa9 100644
> --- a/testsuites/sptests/sp01/system.h
> +++ b/testsuites/sptests/sp01/system.h
> @@ -31,8 +31,6 @@ rtems_task Task_1_through_3(
> #define CONFIGURE_EXTRA_TASK_STACKS (4 * RTEMS_MINIMUM_STACK_SIZE)
> #define CONFIGURE_MAXIMUM_TASKS 4
> diff --git a/testsuites/sptests/sp04/system.h
> b/testsuites/sptests/sp04/system.h
> index db7ba4999d..67ed49cba6 100644
> --- a/testsuites/sptests/sp04/system.h
> +++ b/testsuites/sptests/sp04/system.h
> @@ -52,8 +52,6 @@ void Task_switch(
> #define CONFIGURE_MAXIMUM_TIMERS 1
> diff --git a/testsuites/sptests/sp07/system.h
> b/testsuites/sptests/sp07/system.h
> index d171e85ebc..5e319661e1 100644
> --- a/testsuites/sptests/sp07/system.h
> +++ b/testsuites/sptests/sp07/system.h
> @@ -74,8 +74,6 @@ void Task_exit_extension(
> #define CONFIGURE_MAXIMUM_TASKS 5
> diff --git a/testsuites/sptests/sp08/init.c
> b/testsuites/sptests/sp08/init.c
> index 2ed585ddd7..4229feb15c 100644
> --- a/testsuites/sptests/sp08/init.c
> +++ b/testsuites/sptests/sp08/init.c
> @@ -316,8 +316,6 @@ rtems_task Init(
> /* end of file */
> diff --git a/testsuites/sptests/sp12/system.h
> b/testsuites/sptests/sp12/system.h
> index 7651b994b5..107831b3a0 100644
> --- a/testsuites/sptests/sp12/system.h
> +++ b/testsuites/sptests/sp12/system.h
> @@ -65,8 +65,6 @@ rtems_task Task5(
> #define CONFIGURE_EXTRA_TASK_STACKS (6 * RTEMS_MINIMUM_STACK_SIZE)
> diff --git a/testsuites/sptests/sp13/system.h
> b/testsuites/sptests/sp13/system.h
> index 21d769c82b..7a495963f6 100644
> --- a/testsuites/sptests/sp13/system.h
> +++ b/testsuites/sptests/sp13/system.h
> @@ -97,8 +97,6 @@ TEST_EXTERN rtems_name Queue_name[ 4 ]; /* array of
> queue names */
> #define CONFIGURE_EXTRA_TASK_STACKS (3 * RTEMS_MINIMUM_STACK_SIZE)
> diff --git a/testsuites/sptests/sp14/system.h
> b/testsuites/sptests/sp14/system.h
> index 38a84b369a..b0e04a129e 100644
> --- a/testsuites/sptests/sp14/system.h
> +++ b/testsuites/sptests/sp14/system.h
> @@ -51,8 +51,6 @@ rtems_task Task_2(
> #define CONFIGURE_EXTRA_TASK_STACKS (1 * RTEMS_MINIMUM_STACK_SIZE)
> diff --git a/testsuites/sptests/sp16/system.h
> b/testsuites/sptests/sp16/system.h
> index 38a44998fe..8299e7e8ca 100644
> --- a/testsuites/sptests/sp16/system.h
> +++ b/testsuites/sptests/sp16/system.h
> @@ -54,8 +54,6 @@ rtems_task Task5(
> diff --git a/testsuites/sptests/sp20/system.h
> b/testsuites/sptests/sp20/system.h
> index 26e837a45b..4585639fe3 100644
> --- a/testsuites/sptests/sp20/system.h
> +++ b/testsuites/sptests/sp20/system.h
> @@ -49,8 +49,6 @@ void Get_all_counters( void );
> diff --git a/testsuites/sptests/sp37/system.h
> b/testsuites/sptests/sp37/system.h
> index 0b9d888164..d7b98e40f5 100644
> --- a/testsuites/sptests/sp37/system.h
> +++ b/testsuites/sptests/sp37/system.h
> @@ -39,8 +39,6 @@ rtems_task Init(
> #define CONFIGURE_MAXIMUM_TASKS 2
> diff --git a/testsuites/sptests/sp65/sp65impl.h
> b/testsuites/sptests/sp65/sp65impl.h
> index a557ede775..c5644b38b9 100644
> --- a/testsuites/sptests/sp65/sp65impl.h
> +++ b/testsuites/sptests/sp65/sp65impl.h
> @@ -145,8 +145,6 @@ rtems_task Task_1(
> diff --git a/testsuites/sptests/spcbssched01/system.h
> b/testsuites/sptests/spcbssched01/system.h
> index 1f75749a30..0bc64fc501 100644
> --- a/testsuites/sptests/spcbssched01/system.h
> +++ b/testsuites/sptests/spcbssched01/system.h
> @@ -37,8 +37,6 @@ rtems_task Task_1_through_3(
> diff --git a/testsuites/sptests/spcbssched02/system.h
> b/testsuites/sptests/spcbssched02/system.h
> index 007ca96810..fe3bdc7e21 100644
> --- a/testsuites/sptests/spcbssched02/system.h
> +++ b/testsuites/sptests/spcbssched02/system.h
> @@ -43,8 +43,6 @@ rtems_task Task_Periodic(
> #define CONFIGURE_SCHEDULER_CBS
> #include <rtems/rtems/clock.h>
> diff --git a/testsuites/sptests/spcbssched03/system.h
> b/testsuites/sptests/spcbssched03/system.h
> index 1f864b5150..da20c575ca 100644
> --- a/testsuites/sptests/spcbssched03/system.h
> +++ b/testsuites/sptests/spcbssched03/system.h
> @@ -47,8 +47,6 @@ rtems_task Tasks_Aperiodic(
> diff --git a/testsuites/sptests/spedfsched01/system.h
> b/testsuites/sptests/spedfsched01/system.h
> index acf1a8317f..add030ae48 100644
> --- a/testsuites/sptests/spedfsched01/system.h
> +++ b/testsuites/sptests/spedfsched01/system.h
> diff --git a/testsuites/sptests/spedfsched02/system.h
> b/testsuites/sptests/spedfsched02/system.h
> index f3280e400c..71bc96bbe2 100644
> --- a/testsuites/sptests/spedfsched02/system.h
> +++ b/testsuites/sptests/spedfsched02/system.h
> #define CONFIGURE_SCHEDULER_EDF
> diff --git a/testsuites/sptests/spedfsched03/system.h
> b/testsuites/sptests/spedfsched03/system.h
> index 71000be93d..6d6bb3d3be 100644
> --- a/testsuites/sptests/spedfsched03/system.h
> +++ b/testsuites/sptests/spedfsched03/system.h
> diff --git a/testsuites/sptests/spfatal29/init.c
> b/testsuites/sptests/spfatal29/init.c
> index 439eeef7ac..5df872d3d6 100644
> --- a/testsuites/sptests/spfatal29/init.c
> +++ b/testsuites/sptests/spfatal29/init.c
> @@ -25,8 +25,6 @@
> static void timer(rtems_id id, void *arg)
> rtems_task_wake_after(RTEMS_YIELD_PROCESSOR);
> diff --git a/testsuites/sptests/spfifo03/init.c
> b/testsuites/sptests/spfifo03/init.c
> index ec054d2aef..287f899c36 100644
> --- a/testsuites/sptests/spfifo03/init.c
> +++ b/testsuites/sptests/spfifo03/init.c
> @@ -217,8 +217,6 @@ rtems_task Init(
> #define CONFIGURE_IMFS_ENABLE_MKFIFO
> diff --git a/testsuites/sptests/spfifo05/init.c
> b/testsuites/sptests/spfifo05/init.c
> index c9ae0505c6..21021650b7 100644
> --- a/testsuites/sptests/spfifo05/init.c
> +++ b/testsuites/sptests/spfifo05/init.c
> @@ -273,8 +273,6 @@ rtems_task Init(
> diff --git a/testsuites/sptests/spintrcritical06/spintrcritical06impl.h
> b/testsuites/sptests/spintrcritical06/spintrcritical06impl.h
> index 161f0502de..f0424e3dc8 100644
> --- a/testsuites/sptests/spintrcritical06/spintrcritical06impl.h
> +++ b/testsuites/sptests/spintrcritical06/spintrcritical06impl.h
> @@ -139,8 +139,6 @@ rtems_task Init(
> diff --git a/testsuites/sptests/spintrcritical15/init.c
> b/testsuites/sptests/spintrcritical15/init.c
> index 6f2548ff6f..9de33b3cfb 100644
> --- a/testsuites/sptests/spintrcritical15/init.c
> +++ b/testsuites/sptests/spintrcritical15/init.c
> @@ -111,8 +111,6 @@ rtems_task Init(
> diff --git a/testsuites/sptests/spmrsp01/init.c
> b/testsuites/sptests/spmrsp01/init.c
> index 0d03f1dc83..4539fcc919 100644
> --- a/testsuites/sptests/spmrsp01/init.c
> +++ b/testsuites/sptests/spmrsp01/init.c
> @@ -334,8 +334,6 @@ static void Init(rtems_task_argument arg)
> diff --git a/testsuites/sptests/spsimplesched02/init.c
> b/testsuites/sptests/spsimplesched02/init.c
> index 4a08a6c8ac..27e2f6577c 100644
> --- a/testsuites/sptests/spsimplesched02/init.c
> +++ b/testsuites/sptests/spsimplesched02/init.c
> @@ -158,8 +158,6 @@ rtems_task Init(
> #define CONFIGURE_INIT_TASK_INITIAL_MODES RTEMS_NO_PREEMPT
> #define CONFIGURE_INIT_TASK_PRIORITY 4
> diff --git a/testsuites/tmtests/tm04/system.h
> b/testsuites/tmtests/tm04/system.h
> index 764b979416..bca9c4e081 100644
> --- a/testsuites/tmtests/tm04/system.h
> +++ b/testsuites/tmtests/tm04/system.h
> @@ -32,8 +32,6 @@ rtems_task Init(
> diff --git a/testsuites/tmtests/tm08/system.h
> b/testsuites/tmtests/tm08/system.h
> index ff756e4443..77eb08b602 100644
> --- a/testsuites/tmtests/tm08/system.h
> +++ b/testsuites/tmtests/tm08/system.h
> @@ -31,8 +31,6 @@ rtems_task Init(
> diff --git a/testsuites/tmtests/tm15/system.h
> b/testsuites/tmtests/tm15/system.h
> index efb00325e0..8d98f096ab 100644
> --- a/testsuites/tmtests/tm15/system.h
> +++ b/testsuites/tmtests/tm15/system.h
> @@ -33,8 +33,6 @@ rtems_id Task_id[ OPERATION_COUNT+1 ]; /* array of
> task ids */
> diff --git a/testsuites/tmtests/tm20/system.h
> b/testsuites/tmtests/tm20/system.h
> index c12e34dfb0..9a73f4b2c5 100644
> --- a/testsuites/tmtests/tm20/system.h
> +++ b/testsuites/tmtests/tm20/system.h
> @@ -36,8 +36,6 @@ rtems_id Task_id[ OPERATION_COUNT+1 ]; /* array of
> task ids */
> diff --git a/testsuites/tmtests/tm22/system.h
> b/testsuites/tmtests/tm22/system.h
> index 9bc2f310be..a54c2ec3f0 100644
> --- a/testsuites/tmtests/tm22/system.h
> +++ b/testsuites/tmtests/tm22/system.h
> @@ -37,8 +37,6 @@ rtems_task Init(
> CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE(100, MESSAGE_SIZE )
> diff --git a/testsuites/tmtests/tm24/system.h
> b/testsuites/tmtests/tm24/system.h
> index 8ab708e49f..d56e17903a 100644
> --- a/testsuites/tmtests/tm24/system.h
> +++ b/testsuites/tmtests/tm24/system.h
> 2.16.4
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200215/a132bd61/attachment-0001.html>
