[PATCH v2] config: Add <rtems/confdefs/obsolete.h>
Sat Feb 15 20:08:07 UTC 2020
Thanks looks good to me.
On Sat, Feb 15, 2020 at 10:58 AM Sebastian Huber <
> Unify handling of obsolete configuration options.  Change license to
> BSD-2-Clause.
> Update #3053.
> Update #3875.
>  cpukit/header-dirs.am                    |   2 +
>  cpukit/headers.am                        |   1 +
>  cpukit/include/rtems/confdefs.h          | 167 +---------------------
>  cpukit/include/rtems/confdefs/obsolete.h | 234
>  4 files changed, 238 insertions(+), 166 deletions(-)
>  create mode 100644 cpukit/include/rtems/confdefs/obsolete.h
> diff --git a/cpukit/header-dirs.am b/cpukit/header-dirs.am
> index 7197f1a29f..d90271be9e 100644
> --- a/cpukit/header-dirs.am
> +++ b/cpukit/header-dirs.am
> @@ -50,6 +50,8 @@ include_rtems_bfindir = $(includedir)/rtems/bfin
>  include_rtems_bfin_HEADERS =
>  include_rtems_bsdnetdir = $(includedir)/rtems/bsdnet
>  include_rtems_bsdnet_HEADERS =
> +include_rtems_confdefsdir = $(includedir)/rtems/confdefs
> +include_rtems_confdefs_HEADERS =
>  include_rtems_debuggerdir = $(includedir)/rtems/debugger
>  include_rtems_debugger_HEADERS =
>  include_rtems_m68kdir = $(includedir)/rtems/m68k
> diff --git a/cpukit/headers.am b/cpukit/headers.am
> index 6e1ab4ccd0..f0c8319dcb 100644
> --- a/cpukit/headers.am
> +++ b/cpukit/headers.am
> @@ -183,6 +183,7 @@ include_rtems_HEADERS += include/rtems/userenv.h
>  include_rtems_HEADERS += include/rtems/version.h
>  include_rtems_HEADERS += include/rtems/vmeintr.h
>  include_rtems_HEADERS += include/rtems/watchdogdrv.h
> +include_rtems_confdefs_HEADERS += include/rtems/confdefs/obsolete.h
>  include_rtems_debugger_HEADERS +=
> include/rtems/debugger/rtems-debugger-bsp.h
> include/rtems/debugger/rtems-debugger-remote.h
> include/rtems/debugger/rtems-debugger-server.h
> diff --git a/cpukit/include/rtems/confdefs.h
> b/cpukit/include/rtems/confdefs.h
> index e0d4a77075..0b3b2af546 100644
> --- a/cpukit/include/rtems/confdefs.h
> +++ b/cpukit/include/rtems/confdefs.h
> @@ -50,6 +50,7 @@
>  #include <rtems/posix/semaphore.h>
>  #include <rtems/posix/shm.h>
>  #include <rtems/posix/timer.h>
> +#include <rtems/confdefs/obsolete.h>
>  #include <limits.h>
> @@ -138,11 +139,6 @@ extern "C" {
>  #endif
>  #endif
> -#ifdef CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS
> -  #warning "CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS has been renamed to
> CONFIGURE_MAXIMUM_FILE_DESCRIPTORS since RTEMS 5.1"
> -  #define CONFIGURE_MAXIMUM_FILE_DESCRIPTORS
> -#endif
>   * This macro defines the number of POSIX file descriptors allocated
>   * and managed by libio.  These are the "integer" file descriptors that
> @@ -167,11 +163,6 @@ extern "C" {
>    const uint32_t rtems_libio_number_iops =
> RTEMS_ARRAY_SIZE(rtems_libio_iops);
>  #endif
> -#ifdef CONFIGURE_SMP_MAXIMUM_PROCESSORS
> -  #warning "CONFIGURE_SMP_MAXIMUM_PROCESSORS has been renamed to
> CONFIGURE_MAXIMUM_PROCESSORS since RTEMS 5.1"
> -  #define CONFIGURE_MAXIMUM_PROCESSORS CONFIGURE_SMP_MAXIMUM_PROCESSORS
> -#endif
>  /* Ensure that _CONFIGURE_MAXIMUM_PROCESSORS > 1 only in SMP
> configurations */
>  #if defined(CONFIGURE_MAXIMUM_PROCESSORS) && defined(RTEMS_SMP)
>    #define _CONFIGURE_MAXIMUM_PROCESSORS CONFIGURE_MAXIMUM_PROCESSORS
> @@ -191,34 +182,10 @@ extern "C" {
>    #endif
>  #endif
> -#ifdef CONFIGURE_SMP_APPLICATION
> -  #warning "CONFIGURE_SMP_APPLICATION is obsolete since RTEMS 5.1"
> -#endif
>   * This sets up the resources for the FIFOs/pipes.
> - * This is specified to configure the maximum number of POSIX FIFOs.
> -#ifdef CONFIGURE_MAXIMUM_FIFOS
> -  #warning "CONFIGURE_MAXIMUM_FIFOS is obsolete since RTEMS 5.1; use
> CONFIGURE_IMFS_ENABLE_MKFIFO instead"
> -  #if CONFIGURE_MAXIMUM_FIFOS > 0
> -    #define CONFIGURE_IMFS_ENABLE_MKFIFO
> -  #endif
> -#endif
> - * This is specified to configure the maximum number of POSIX named pipes.
> -#ifdef CONFIGURE_MAXIMUM_PIPES
> -  #warning "CONFIGURE_MAXIMUM_PIPES is obsolete since RTEMS 5.1; use
> -  #if CONFIGURE_MAXIMUM_PIPES > 0
> -  #endif
> -#endif
>   *  @defgroup ConfigFilesystems Filesystems and Mount Table Configuration
> @@ -617,14 +584,6 @@ extern "C" {
>  #endif
>  /**@}*/ /* end of file system group */
> - *  STACK_CHECKER_ON was still available in 4.9 so give a warning for now.
> -#if defined(STACK_CHECKER_ON)
> -  #define CONFIGURE_STACK_CHECKER_ENABLED
> -  #warning "STACK_CHECKER_ON deprecated -- use
> CONFIGURE_STACK_CHECKER_ENABLED"
> -#endif
>   * This configures the stack checker user extension.
> @@ -702,21 +661,6 @@ extern "C" {
>   *    - CONFIGURE_SCHEDULER_USER_PER_THREAD
> -#ifdef CONFIGURE_SCHEDULER_CONTEXT
> -  #warning "CONFIGURE_SCHEDULER_CONTEXT has been renamed to
> CONFIGURE_SCHEDULER since RTEMS 5.1"
> -  #define CONFIGURE_SCHEDULER CONFIGURE_SCHEDULER_CONTEXT
> -#endif
> -#ifdef CONFIGURE_SCHEDULER_CONTROLS
> -  #warning "CONFIGURE_SCHEDULER_CONTROLS has been renamed to
> CONFIGURE_SCHEDULER_TABLE_ENTRIES since RTEMS 5.1"
> -  #define CONFIGURE_SCHEDULER_TABLE_ENTRIES CONFIGURE_SCHEDULER_CONTROLS
> -#endif
> -#ifdef CONFIGURE_SMP_SCHEDULER_ASSIGNMENTS
> -  #warning "CONFIGURE_SMP_SCHEDULER_ASSIGNMENTS has been renamed to
> CONFIGURE_SCHEDULER_ASSIGNMENTS since RTEMS 5.1"
> -  #define CONFIGURE_SCHEDULER_ASSIGNMENTS
> -#endif
>  #if !defined(CONFIGURE_SCHEDULER_USER) && \
>      !defined(CONFIGURE_SCHEDULER_PRIORITY) && \
>      !defined(CONFIGURE_SCHEDULER_PRIORITY_SMP) && \
> @@ -1665,12 +1609,6 @@ const Thread_Idle_body _Thread_Idle_body =
> CONFIGURE_IDLE_TASK_BODY;
>      (_CONFIGURE_LIBBLOCK_TASKS * \
>      (CONFIGURE_BDBUF_TASK_STACK_SIZE <= CONFIGURE_MINIMUM_TASK_STACK_SIZE
>      0 : CONFIGURE_BDBUF_TASK_STACK_SIZE -
> CONFIGURE_MINIMUM_TASK_STACK_SIZE))
> -  #if defined(CONFIGURE_HAS_OWN_BDBUF_TABLE) || \
> -      defined(CONFIGURE_BDBUF_BUFFER_SIZE) || \
> -      defined(CONFIGURE_BDBUF_BUFFER_COUNT)
> -    #error BDBUF Cache does not use a buffer configuration table. Please
> remove.
> -  #endif
>  #else
>    /** This specifies the number of libblock tasks. */
>    #define _CONFIGURE_LIBBLOCK_TASKS 0
> @@ -2904,17 +2842,6 @@ struct _reent *__getreent(void)
>  #endif
>  #endif   /* !defined(RTEMS_SCHEDSIM) */
> - *  These names have been obsoleted so make the user application stop
> compiling
> -#if defined(CONFIGURE_TEST_NEEDS_TIMER_DRIVER) || \
> -    defined(CONFIGURE_TEST_NEEDS_CONSOLE_DRIVER) || \
> -    defined(CONFIGURE_TEST_NEEDS_CLOCK_DRIVER) || \
> -    defined(CONFIGURE_TEST_NEEDS_RTC_DRIVER) || \
> -    defined(CONFIGURE_TEST_NEEDS_STUB_DRIVER)
> -#error "CONFIGURATION ERROR: CONFIGURE_TEST_XXX constants are obsolete"
> -#endif
>   *  Validate the configured maximum priority
> @@ -2932,82 +2859,6 @@ struct _reent *__getreent(void)
>    #error "Maximum priority configured higher than supported by target."
>  #endif
> -#ifdef CONFIGURE_HAS_OWN_CONFIGURATION_TABLE
> -  #warning "The CONFIGURE_HAS_OWN_CONFIGURATION_TABLE configuration
> option is obsolete since RTEMS 5.1"
> -#endif
> -#ifdef CONFIGURE_HAS_OWN_DEVICE_DRIVER_TABLE
> -  #warning "The CONFIGURE_HAS_OWN_DEVICE_DRIVER_TABLE configuration
> -#endif
> -#ifdef CONFIGURE_HAS_OWN_FILESYSTEM_TABLE
> -  #warning "The CONFIGURE_HAS_OWN_FILESYSTEM_TABLE configuration option
> -#endif
> -#ifdef CONFIGURE_HAS_OWN_INIT_TABLE
> -  #warning "The CONFIGURE_HAS_OWN_INIT_TABLE configuration option is
> -#endif
> -#ifdef CONFIGURE_HAS_OWN_MOUNT_TABLE
> -  #warning "The CONFIGURE_HAS_OWN_MOUNT_TABLE configuration option is
> -#endif
> -#ifdef CONFIGURE_HAS_OWN_MULTIPROCESSING_TABLE
> -#endif
> -#ifdef CONFIGURE_NUMBER_OF_TERMIOS_PORTS
> -  #warning "The CONFIGURE_NUMBER_OF_TERMIOS_PORTS configuration option is
> -#endif
> -#ifdef CONFIGURE_MAXIMUM_ADA_TASKS
> -  #warning "The CONFIGURE_MAXIMUM_ADA_TASKS configuration option is
> -#endif
> -#ifdef CONFIGURE_MAXIMUM_FAKE_ADA_TASKS
> -  #warning "The CONFIGURE_MAXIMUM_FAKE_ADA_TASKS configuration option is
> -#endif
> -#ifdef CONFIGURE_MAXIMUM_MRSP_SEMAPHORES
> -  #warning "The CONFIGURE_MAXIMUM_MRSP_SEMAPHORES configuration option is
> -#endif
> -#ifdef CONFIGURE_MAXIMUM_POSIX_BARRIERS
> -  #warning "The CONFIGURE_MAXIMUM_POSIX_BARRIERS configuration option is
> -#endif
> -#ifdef CONFIGURE_MAXIMUM_POSIX_CONDITION_VARIABLES
> -  #warning "The CONFIGURE_MAXIMUM_POSIX_CONDITION_VARIABLES configuration
> -#endif
> -#ifdef CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUE_DESCRIPTORS
> -  #warning "The CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUE_DESCRIPTORS
> configuration option is obsolete since RTEMS 5.1"
> -#endif
> -#ifdef CONFIGURE_MAXIMUM_POSIX_MUTEXES
> -  #warning "The CONFIGURE_MAXIMUM_POSIX_MUTEXES configuration option is
> -#endif
> -#ifdef CONFIGURE_MAXIMUM_POSIX_RWLOCKS
> -  #warning "The CONFIGURE_MAXIMUM_POSIX_RWLOCKS configuration option is
> -#endif
> -#ifdef CONFIGURE_MAXIMUM_POSIX_SPINLOCKS
> -  #warning "The CONFIGURE_MAXIMUM_POSIX_SPINLOCKS configuration option is
> -#endif
> -#ifdef CONFIGURE_MAXIMUM_PTYS
> -  #warning "The CONFIGURE_MAXIMUM_PTYS configuration option is obsolete
> since RTEMS 5.1"
> -#endif
> -#ifdef CONFIGURE_POSIX_HAS_OWN_INIT_THREAD_TABLE
> -  #warning "The CONFIGURE_POSIX_HAS_OWN_INIT_THREAD_TABLE configuration
> -#endif
> -#ifdef CONFIGURE_TERMIOS_DISABLED
> -  #warning "The CONFIGURE_TERMIOS_DISABLED configuration option is
> -#endif
>   * POSIX Key pair shouldn't be less than POSIX Key, which is highly
>   * likely to be error.
> @@ -3032,21 +2883,5 @@ struct _reent *__getreent(void)
>    #error "IMFS Memfile block size must be a power of 2 between 16 and 512"
>  #endif
> -#ifdef CONFIGURE_ENABLE_GO
> -  #warning "The CONFIGURE_ENABLE_GO configuration option is obsolete
> since RTEMS 5.1"
> -#endif
> -#ifdef CONFIGURE_GNAT_RTEMS
> -  #warning "The CONFIGURE_GNAT_RTEMS configuration option is obsolete
> since RTEMS 5.1"
> -#endif
> -#ifdef CONFIGURE_MAXIMUM_GOROUTINES
> -  #warning "The CONFIGURE_MAXIMUM_GOROUTINES configuration option is
> -#endif
> -#ifdef CONFIGURE_MAXIMUM_GO_CHANNELS
> -  #warning "The CONFIGURE_MAXIMUM_GO_CHANNELS configuration option is
> -#endif
>  #endif
>  /* end of include file */
> diff --git a/cpukit/include/rtems/confdefs/obsolete.h
> b/cpukit/include/rtems/confdefs/obsolete.h
> new file mode 100644
> index 0000000000..6321810c43
> --- /dev/null
> +++ b/cpukit/include/rtems/confdefs/obsolete.h
> @@ -0,0 +1,234 @@
> + * @file
> + * @ingroup RTEMSApplicationConfiguration
> + * @brief This header file deals with obsolete configuration options.
> + * SPDX-License-Identifier: BSD-2-Clause
> + * Copyright (C) 2017, 2020 embedded brains GmbH
> + * Redistribution and use in source and binary forms, with or without
> + * modification, are permitted provided that the following conditions
> + * are met:
> + * 1. Redistributions of source code must retain the above copyright
> + *    notice, this list of conditions and the following disclaimer.
> + * 2. Redistributions in binary form must reproduce the above copyright
> + *    notice, this list of conditions and the following disclaimer in the
> + *    documentation and/or other materials provided with the distribution.
> + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
> "AS IS"
> + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
> THE
> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
> PURPOSE
> + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS
> BE
> + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
> BUSINESS
> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF
> THE
> + * POSSIBILITY OF SUCH DAMAGE.
> +#ifndef _RTEMS_CONFDEFS_OBSOLETE_H
> +#define _RTEMS_CONFDEFS_OBSOLETE_H
> +#ifndef __CONFIGURATION_TEMPLATE_h
> +#error "Do not include this file directly, use <rtems/confdefs.h> instead"
> +#endif
> +#ifdef CONFIGURE_INIT
> + * Please keep the list of obsolete configuration options alphabetically
> sorted.
> + * Use #warning for renamed options and define the new option accordingly.
> + * Use #warning for obsolete options which are now superfluous, e.g.
> because
> + * the objects are now self-contained.
> + * Use #error for options which require now a different configuration
> approach,
> + * e.g. options for an own configuration table.
> + * Mention the RTEMS release which obsoleted the configuration option in
> the
> + * message.
> +#ifdef CONFIGURE_BDBUF_BUFFER_SIZE
> +  #error "The CONFIGURE_BDBUF_BUFFER_SIZE configuration option is
> obsolete since RTEMS 4.10.0"
> +#endif
> +#ifdef CONFIGURE_BDBUF_BUFFER_COUNT
> +  #error "The CONFIGURE_BDBUF_BUFFER_COUNT configuration option is
> +#endif
> +#ifdef CONFIGURE_ENABLE_GO
> +  #warning "The CONFIGURE_ENABLE_GO configuration option is obsolete
> since RTEMS 5.1"
> +#endif
> +#ifdef CONFIGURE_GNAT_RTEMS
> +  #warning "The CONFIGURE_GNAT_RTEMS configuration option is obsolete
> since RTEMS 5.1"
> +#endif
> +#ifdef CONFIGURE_HAS_OWN_CONFIGURATION_TABLE
> +  #error "The CONFIGURE_HAS_OWN_CONFIGURATION_TABLE configuration option
> +#endif
> +#ifdef CONFIGURE_HAS_OWN_BDBUF_TABLE
> +  #error "The CONFIGURE_HAS_BDBUF_TABLE configuration option is obsolete
> since RTEMS 4.10.0"
> +#endif
> +#ifdef CONFIGURE_HAS_OWN_DEVICE_DRIVER_TABLE
> +  #error "The CONFIGURE_HAS_OWN_DEVICE_DRIVER_TABLE configuration option
> +#endif
> +#ifdef CONFIGURE_HAS_OWN_FILESYSTEM_TABLE
> +  #error "The CONFIGURE_HAS_OWN_FILESYSTEM_TABLE configuration option is
> +#endif
> +#ifdef CONFIGURE_HAS_OWN_INIT_TABLE
> +  #error "The CONFIGURE_HAS_OWN_INIT_TABLE configuration option is
> +#endif
> +#ifdef CONFIGURE_HAS_OWN_MOUNT_TABLE
> +  #error "The CONFIGURE_HAS_OWN_MOUNT_TABLE configuration option is
> +#endif
> +#ifdef CONFIGURE_HAS_OWN_MULTIPROCESSING_TABLE
> +#endif
> +#ifdef CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS
> +  #warning "CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS has been renamed to
> +  #define CONFIGURE_MAXIMUM_FILE_DESCRIPTORS
> +#endif
> +#ifdef CONFIGURE_MAXIMUM_ADA_TASKS
> +  #warning "The CONFIGURE_MAXIMUM_ADA_TASKS configuration option is
> +#endif
> +#ifdef CONFIGURE_MAXIMUM_FAKE_ADA_TASKS
> +  #warning "The CONFIGURE_MAXIMUM_FAKE_ADA_TASKS configuration option is
> +#endif
> +#ifdef CONFIGURE_MAXIMUM_FIFOS
> +  #warning "CONFIGURE_MAXIMUM_FIFOS is obsolete since RTEMS 5.1; use
> +  #if CONFIGURE_MAXIMUM_FIFOS > 0
> +    #define CONFIGURE_IMFS_ENABLE_MKFIFO
> +  #endif
> +#endif
> +#ifdef CONFIGURE_MAXIMUM_GOROUTINES
> +  #warning "The CONFIGURE_MAXIMUM_GOROUTINES configuration option is
> +#endif
> +#ifdef CONFIGURE_MAXIMUM_GO_CHANNELS
> +  #warning "The CONFIGURE_MAXIMUM_GO_CHANNELS configuration option is
> +#endif
> +#ifdef CONFIGURE_MAXIMUM_MRSP_SEMAPHORES
> +  #warning "The CONFIGURE_MAXIMUM_MRSP_SEMAPHORES configuration option is
> +#endif
> +#ifdef CONFIGURE_MAXIMUM_PIPES
> +  #warning "CONFIGURE_MAXIMUM_PIPES is obsolete since RTEMS 5.1; use
> +  #if CONFIGURE_MAXIMUM_PIPES > 0
> +  #endif
> +#endif
> +#ifdef CONFIGURE_MAXIMUM_POSIX_BARRIERS
> +  #warning "The CONFIGURE_MAXIMUM_POSIX_BARRIERS configuration option is
> +#endif
> +#ifdef CONFIGURE_MAXIMUM_POSIX_CONDITION_VARIABLES
> +  #warning "The CONFIGURE_MAXIMUM_POSIX_CONDITION_VARIABLES configuration
> +#endif
> +#ifdef CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUE_DESCRIPTORS
> +  #warning "The CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUE_DESCRIPTORS
> +#endif
> +#ifdef CONFIGURE_MAXIMUM_POSIX_MUTEXES
> +  #warning "The CONFIGURE_MAXIMUM_POSIX_MUTEXES configuration option is
> +#endif
> +#ifdef CONFIGURE_MAXIMUM_POSIX_RWLOCKS
> +  #warning "The CONFIGURE_MAXIMUM_POSIX_RWLOCKS configuration option is
> +#endif
> +#ifdef CONFIGURE_MAXIMUM_POSIX_SPINLOCKS
> +  #warning "The CONFIGURE_MAXIMUM_POSIX_SPINLOCKS configuration option is
> +#endif
> +#ifdef CONFIGURE_MAXIMUM_PTYS
> +  #warning "The CONFIGURE_MAXIMUM_PTYS configuration option is obsolete
> since RTEMS 5.1"
> +#endif
> +#ifdef CONFIGURE_NUMBER_OF_TERMIOS_PORTS
> +  #warning "The CONFIGURE_NUMBER_OF_TERMIOS_PORTS configuration option is
> +#endif
> +#ifdef CONFIGURE_POSIX_HAS_OWN_INIT_THREAD_TABLE
> +  #error "The CONFIGURE_POSIX_HAS_OWN_INIT_THREAD_TABLE configuration
> +#endif
> +#ifdef CONFIGURE_SCHEDULER_CONTEXT
> +  #warning "CONFIGURE_SCHEDULER_CONTEXT has been renamed to
> +  #define CONFIGURE_SCHEDULER CONFIGURE_SCHEDULER_CONTEXT
> +#endif
> +#ifdef CONFIGURE_SCHEDULER_CONTROLS
> +  #warning "CONFIGURE_SCHEDULER_CONTROLS has been renamed to
> +  #define CONFIGURE_SCHEDULER_TABLE_ENTRIES CONFIGURE_SCHEDULER_CONTROLS
> +#endif
> +#ifdef CONFIGURE_SMP_APPLICATION
> +  #warning "CONFIGURE_SMP_APPLICATION is obsolete since RTEMS 5.1"
> +#endif
> +#ifdef CONFIGURE_SMP_MAXIMUM_PROCESSORS
> +  #warning "CONFIGURE_SMP_MAXIMUM_PROCESSORS has been renamed to
> +  #define CONFIGURE_MAXIMUM_PROCESSORS CONFIGURE_SMP_MAXIMUM_PROCESSORS
> +#endif
> +#ifdef CONFIGURE_SMP_SCHEDULER_ASSIGNMENTS
> +  #warning "CONFIGURE_SMP_SCHEDULER_ASSIGNMENTS has been renamed to
> +  #define CONFIGURE_SCHEDULER_ASSIGNMENTS
> +#endif
> +#ifdef CONFIGURE_TERMIOS_DISABLED
> +  #warning "The CONFIGURE_TERMIOS_DISABLED configuration option is
> +#endif
> +#ifdef CONFIGURE_TEST_NEEDS_CLOCK_DRIVER
> +  #error "The CONFIGURE_TEST_NEEDS_CLOCK_DRIVER configuration option is
> obsolete since at least RTEMS 4.5.0"
> +#endif
> +#ifdef CONFIGURE_TEST_NEEDS_CONSOLE_DRIVER
> +  #error "The CONFIGURE_TEST_NEEDS_CONSOLE_DRIVER configuration option is
> obsolete at least RTEMS 4.5.0"
> +#endif
> +#ifdef CONFIGURE_TEST_NEEDS_RTC_DRIVER
> +  #error "The CONFIGURE_TEST_NEEDS_RTC_DRIVER configuration option is
> +#endif
> +#ifdef CONFIGURE_TEST_NEEDS_STUB_DRIVER
> +  #error "The CONFIGURE_TEST_NEEDS_STUB_DRIVER configuration option is
> +#endif
> +#ifdef CONFIGURE_TEST_NEEDS_TIMER_DRIVER
> +  #error "The CONFIGURE_TEST_NEEDS_TIMER_DRIVER configuration option is
> +#endif
> +#ifdef STACK_CHECKER_ON
> +  #warning "STACK_CHECKER_ON has been renamed to
> CONFIGURE_STACK_CHECKER_ENABLED since RTEMS 4.10.0"
> +  #define CONFIGURE_STACK_CHECKER_ENABLED
> +#endif
> +#endif /* CONFIGURE_INIT */
> +#endif /* _RTEMS_CONFDEFS_OBSOLETE_H */
> 2.16.4
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200215/b41b5079/attachment-0001.html>
