Ticket #3515: covoar failure while running for full testsuites
Bran S
archsbran at gmail.com
Sun Feb 16 18:38:10 UTC 2020
Hi Guys,
I am trying to understand and solve Ticket #3515.
https://devel.rtems.org/ticket/3515
$ /home/user45/quick-start/rtems/5/share/rtems/tester/bin/covoar -vvvv
-S /home/user45/quick-start/rtems/5/share/rtems/tester/rtems/testing/coverage/leon3-sis-symbols.ini
-O leon3-sis-coverage -E
/home/user45/quick-start/rtems/5/share/rtems/tester/rtems/testing/coverage/Explanations.txt
-p RTEMS-5 /home/user45/quick-start/build/b-leon3/sparc-rtems5/c/leon3/testsuites/fstests/fsclose01.exe
The output of the above command is at:
https://gist.github.com/archsbran/7834a931d52311c7b26842c6325d8d9a
On the last line it can be seen that absence of `wait` symbol causes the error.
I made some changes in ExecutableInfo.cc to print out the symbols
being added into coverageMap.
Added symbols can be seen from line 636 to 7236 at the above link.
In those lines we can see that `wait` is not added into coverageMap.
I am new so the only thing I know about covoar is that it does
coverage analysis.
Any ideas on how to move further into solving this ?
