[PATCH] c-user: Obsolete CONFIGURE_HAS_OWN_INIT_TASK_TABLE
Mon Feb 17 09:17:18 UTC 2020
The CONFIGURE_HAS_OWN_INIT_TASK_TABLE and
CONFIGURE_POSIX_HAS_OWN_INIT_THREAD_TABLE are the last *_HAS_OWN_*
configuration options.  These two options are probably unused, see also:
* https://lists.rtems.org/pipermail/users/2019-April/033129.html
* https://lists.rtems.org/pipermail/users/2019-April/033130.html
Removing them simplifies the configuration. If there is a real user need
which shows up after the removal, we can resurrect them on demand.
Using CONFIGURE_HAS_OWN_INIT_TASK_TABLE would have required the use of
the undocumented CONFIGURE_INIT_TASK_TABLE and
CONFIGURE_INIT_TASK_TABLE_SIZE configuration options.
Close #3873.
 c-user/configuring_a_system.rst | 40 ++++++++++++----------------------------
 1 file changed, 12 insertions(+), 28 deletions(-)
diff --git a/c-user/configuring_a_system.rst b/c-user/configuring_a_system.rst
index bc2b37a..fbcfbfc 100644
--- a/c-user/configuring_a_system.rst
+++ b/c-user/configuring_a_system.rst
@@ -1563,34 +1563,6 @@ DESCRIPTION:
 NOTES:
     None.
-.. index:: CONFIGURE_HAS_OWN_INIT_TASK_TABLE
-.. _CONFIGURE_HAS_OWN_INIT_TASK_TABLE:
-CONFIGURE_HAS_OWN_INIT_TASK_TABLE
-CONSTANT:
-    ``CONFIGURE_HAS_OWN_INIT_TASK_TABLE``
-DATA TYPE:
-    Boolean feature macro.
-RANGE:
-    Defined or undefined.
-DEFAULT VALUE:
-    This is not defined by default.
-DESCRIPTION:
-    ``CONFIGURE_HAS_OWN_INIT_TASK_TABLE`` is defined if the user wishes to
-    define their own Classic API Initialization Tasks Table.  This table should
-    be named ``Initialization_tasks``.
-NOTES:
-    This is a seldom used configuration parameter. The most likely use case is
-    when an application desires to have more than one initialization task.
 POSIX API Configuration
@@ -4813,6 +4785,18 @@ CONFIGURE_HAS_OWN_DEVICE_DRIVER_TABLE
 This configuration option was present in all RTEMS versions since at least 1995
 and is obsolete since RTEMS 5.1.
+.. index:: CONFIGURE_HAS_OWN_INIT_TASK_TABLE
+.. _CONFIGURE_HAS_OWN_INIT_TASK_TABLE:
+CONFIGURE_HAS_OWN_INIT_TASK_TABLE
+This configuration option was present in all RTEMS versions since at least 1995
+and is obsolete since RTEMS 5.1.  If you used this configuration option or you
+think that there should be a way to configure more than one Classic API
+initialization task, then please ask on the :r:list:`users`.
 .. index:: CONFIGURE_HAS_OWN_MOUNT_TABLE
2.16.4
