[PATCH] c-user: Obsolete CONFIGURE_POSIX_HAS_OWN_INIT_THREAD_TABLE
Mon Feb 17 09:17:26 UTC 2020
The CONFIGURE_HAS_OWN_INIT_TASK_TABLE and
CONFIGURE_POSIX_HAS_OWN_INIT_THREAD_TABLE are the last *_HAS_OWN_*
configuration options.  These two options are probably unused, see also:
* https://lists.rtems.org/pipermail/users/2019-April/033129.html
* https://lists.rtems.org/pipermail/users/2019-April/033130.html
Removing them simplifies the configuration. If there is a real user need
which shows up after the removal, we can resurrect them on demand.
Using CONFIGURE_POSIX_HAS_OWN_INIT_THREAD_TABLE would have required the
use of the undocumented CONFIGURE_POSIX_INIT_THREAD_TABLE_NAME and
CONFIGURE_POSIX_INIT_THREAD_TABLE_SIZE configuration options.
Close #3874.
 c-user/configuring_a_system.rst | 48 ++++++++++++++---------------------------
 1 file changed, 16 insertions(+), 32 deletions(-)
diff --git a/c-user/configuring_a_system.rst b/c-user/configuring_a_system.rst
index fbcfbfc..d6d9411 100644
--- a/c-user/configuring_a_system.rst
+++ b/c-user/configuring_a_system.rst
@@ -1913,34 +1913,6 @@ NOTES:
     Task/Thread Stack Memory Above Minimum` for more information about
     ``CONFIGURE_EXTRA_TASK_STACKS``.
-.. index:: CONFIGURE_POSIX_HAS_OWN_INIT_THREAD_TABLE
-.. _CONFIGURE_POSIX_HAS_OWN_INIT_THREAD_TABLE:
-CONFIGURE_POSIX_HAS_OWN_INIT_THREAD_TABLE
-CONSTANT:
-    ``CONFIGURE_POSIX_HAS_OWN_INIT_THREAD_TABLE``
-DATA TYPE:
-    Boolean feature macro.
-RANGE:
-    Defined or undefined.
-DEFAULT VALUE:
-    This is not defined by default.
-DESCRIPTION:
-    ``CONFIGURE_POSIX_HAS_OWN_INIT_THREAD_TABLE`` is defined if the user wishes
-    to define their own POSIX API Initialization Threads Table.  This table
-    should be named ``POSIX_Initialization_threads``.
-NOTES:
-    This is a seldom used configuration parameter. The most likely use case is
-    when an application desires to have more than one initialization task.
 Configuring Custom Task Stack Allocation
@@ -4906,12 +4878,17 @@ CONFIGURE_MAXIMUM_POSIX_SPINLOCKS
 This configuration option is obsolete since RTEMS 5.1.
-.. index:: CONFIGURE_TERMIOS_DISABLED
+.. index:: CONFIGURE_POSIX_HAS_OWN_INIT_THREAD_TABLE
-CONFIGURE_TERMIOS_DISABLED
+.. _CONFIGURE_POSIX_HAS_OWN_INIT_THREAD_TABLE:
-This configuration option is obsolete since RTEMS 5.1.
+CONFIGURE_POSIX_HAS_OWN_INIT_THREAD_TABLE
+This configuration option was present in all RTEMS versions since at least 1995
+and is obsolete since RTEMS 5.1.  If you used this configuration option or you
+think that there should be a way to configure more than one POSIX initialization
+thread, then please ask on the  :r:list:`users`.
 .. index:: CONFIGURE_SMP_APPLICATION
@@ -4928,3 +4905,10 @@ CONFIGURE_SMP_MAXIMUM_PROCESSORS
 This configuration option was introduced in RTEMS 4.11.0 and is obsolete since
 RTEMS 5.1.  See also :ref:`CONFIGURE_MAXIMUM_PROCESSORS`.
+.. index:: CONFIGURE_TERMIOS_DISABLED
+CONFIGURE_TERMIOS_DISABLED
+This configuration option is obsolete since RTEMS 5.1.
2.16.4
