Loading RTEMS applications from u-boot on Raspberry Pi 2
Cláudio Maia clrrm at isep.ipp.pt
Mon Feb 17 20:18:55 UTC 2020
I am currently experimenting with RTEMS and Raspberry Pi 2 with the goal of exploring RTEMS-SMP properties (mainly scheduling and memory behaviour).
Currently, I am able to load an .img file when the default kernel.img file that comes with Raspbian is replaced by the RTEMS aplication .img file in the boot partition (let's call this approach #1).
However, I cannot execute any RTEMS application directly from u-boot (let's call this approach #2). The result is that when an .img is loaded using u-boot there is no output afterwards.
Can someone help me in detecting what is the issue?
I use the following settings to build the samples for the target:
$ $RTEMS/rtems/configure --prefix=$RTEMS/rtems/5 --target=arm-rtems5 --enable-rtemsbsp=raspberrypi2 --enable-tests=samples
$ make install
For approach #1, the .img file is generated using the following command:
$ arm-rtems5-objcopy -O binary ticker.exe kernel.img
Then, I replace kernel.img in the boot partition and add the following lines to the config.txt file:
kernel_address=0x200000
kernel=kernel.img
The code executes without issues.
For approach #2, I do the following:
$ arm-rtems5-objcopy -R -S -O binary hello.exe hello.bin
$ mkimage -A arm -O rtems -T kernel -C none -a 0x200000 -e 0x200080 -d hello.bin hello-rtems.img
Image Name:
Created:      Mon Feb 17 13:59:50 2020
Image Type:   ARM RTEMS Kernel Image (uncompressed)
Data Size:    1055340 Bytes = 1030.61 kB = 1.01 MB
Load Address: 00200000
Entry Point:  00200080
Then, after u-boot loads on the target, I do the following:
U-Boot> fatload mmc 0:1 0x200000 hello-rtems.img
reading hello-rtems.img
1055404 bytes read in 103 ms (9.8 MiB/s)
U-Boot> iminfo
## Checking Image at 00200000 ...
   Legacy image found
   Image Name:
   Data Size:    1055340 Bytes = 1 MiB
   Verifying Checksum ... OK
U-Boot> bootm 0x200000
## Booting kernel from Legacy Image at 00200000 ...
   Image Name:
   Loading Kernel Image ... OK
## Transferring control to RTEMS (at address 00200080) ...
After this point, nothing happens on the board.
Thank you in advance. Regards
Cláudio Maia
