Loading RTEMS applications from u-boot on Raspberry Pi 2
Niteesh G. S. niteesh.gs at gmail.com
Tue Feb 18 15:56:02 UTC 2020
Hii,
Regarding loading RTEMS images using U-Boot. It is
necessary that you provide a DTB file.
So, your commands should be
$ mkimage -A arm -O linux -T kernel -a 0x200000 -e 0x200080 -d kernel.img
-C none rtems.img
Can you please let me know if -O rtems works for you. I have tried
using it but got no output.
U-Boot> fatload mmc 0:1 0x200000 rtems.img
U-Boot> fatload mmc 0:1 0x1000 bcm2709-rpi-2-b.dtb or bcm2710-rpi-2-b.dtb
The DTB file should be choosed according to the board version.
U-Boot> bootm 0x200000 - 0x1000
Thanks,
Niteesh.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200218/b835d9f5/attachment-0001.html>
