SPDX License Identifier Only and Full Copy?
Gedare Bloom
gedare at rtems.org
Fri Feb 21 04:34:18 UTC 2020
On Thu, Feb 20, 2020 at 2:49 PM Chris Johns <chrisj at rtems.org> wrote:
> On 21/2/20 3:20 am, Gedare Bloom wrote:
> > On Thu, Feb 20, 2020 at 12:58 AM Thomas Doerfler
> > <thomas.doerfler at embedded-brains.de> wrote:
> >> Hello,
> >> I just want to speak up here. I talked with Sebastian today and I really
> >> tend to keep the license text in each file.
> >> Rational:
> >> - With the BSD license, anyone can pick any file from the RTEMS repo and
> >> use/modify it in any project (and this is fine). The original authors
> >> (and their copyright) are listed in the file, but the only pointer to
> >> the legal part is the "SPDX identifier". I am not sure whether this is a
> >> legally binding "tag" and whether this tag is clear to any user.
> >> - Strictly seen, it is not even forbidden to remove the "SPDX
> >> identifier", because it is not part of the BSD-2-clause-license, it's
> >> just a pointer to it. In the end we might result in code drifting around
> >> without license information, which we all do not want to see.
> > This is a valid point. I also have no desire to be a lawyer.
> > My intuition here is that, even without any licensing information at
> > all in individual files, one can still apply a single license to an
> > entire repository, e.g., BSD or GPL. For historical reasons, and
> > similar arguments as you've made, BSD-style licenses have tended to be
> > copy-pasted to individual files to make them easier to excerpt. We
> > don't have license uniformity, so we do need to individually specify
> > which license(s) apply to each file.
> This makes sense. The simplified BSD license states ...
> 1. Redistributions of source code must retain the above copyright
> notice, this list of conditions and the following disclaimer.
> I do not see how we can centralise this and have the "above copyright" work?
> Also the SPDX site here ...
> https://spdx.org/ids-how
> ... under the heading "Standard license headers" states ...
> When a license defines a recommended notice to attach to files
> under that license (sometimes called a "standard header"), the SPDX
> project recommends that the standard header be included in the files,
> in addition to an SPDX ID.
> My reading of this means we should include the license in the source.
> We need to consider compliance and machine auditing of the source. The SPDX tag
> is important. Maybe ...
> * SPDX tag suff
> * Copyright stuff
> * 2-Clause BSD license
This is a good point. Probably it is good to follow the SPDX advice on
usage, and keep the "standard header" boilerplate intact.
> > Linux follows a similar philosophy as Sebastian suggests. I think we
> > can also follow Linux in this regards.
> > https://www.kernel.org/doc/html/latest/process/license-rules.html
> > I would suggest we follow their approach to self-document the licenses
> > centrally. I suspect the risk of someone using code without adhering
> > to the license is no greater. Probably they have a higher risk
> > exposure than we do!
> I agree with the comments in the Linux license rules text about license text in
> files making it harder to check for compliance.
> Chris
> >> As you all know I am not a lawyer (and don't want to be), but my gut
> >> say's the extra lines in the top of each file are worth their storage.
> >> And anybody opening a RTEMS source file (even when it has been taken to
> >> a different project) should see what he has.
> >> If you have different reasons to replace the header and just leave the
> >> identifier I a will go with it and it's fine for me. But my tendency
> >> is... leave it in.
> >> Kind regards,
> >> Thomas.
> >> Am 20.02.20 um 08:30 schrieb Sebastian Huber:
> >>> Hello,
> >>> On 18/02/2020 16:58, Gedare Bloom wrote:
> >>>>>>> I suggest to use a master COPYING file and use file headers without
> >>>>>>> the
> >>>>>>> full license text.
> >>>>>>> https://lists.rtems.org/pipermail/devel/2018-December/024198.html
> >>>>>> It would be nice to get some feedback here.
> >>>>> I'm generally ok with just the spdx and copyright statements.
> >>>> I'm also fine with the master COPYING, spdx-tag, and individual
> >>>> copyrights in files.
> >>>> I should make a note to take a pass over "my" files to relicense them.
> >>>> Does anyone have any script/tools for making that easy?
> >>> I talked with Thomas and he is not in favour of a removal of the licence
> >>> text. Not everyone knows what an SPDX-Licence-Identifier is and that
> >>> this means the file is covered by the reference license. The
> >>> BSD-2-Clause license text is quite clear and not long. For us it is
> >>> important that it is very clear that our contributions are without
> >>> warranties and so on. This information should be also clear if files are
> >>> transferred out of the RTEMS context to other projects.
> >> embedded brains GmbH
> >> Thomas Doerfler
> >> Dornierstr. 4
> >> D-82178 Puchheim
> >> Germany
> >> email: Thomas.Doerfler at embedded-brains.de
> >> Phone: +49-89-18 94 741-12
> >> Fax: +49-89-18 94 741-09
> >> PGP: Public key available on request.
> >> For our privacy statement, see
> >> https://embedded-brains.de/en/data-privacy-statement/
> >> _______________________________________________
> >> devel mailing list
> >> devel at rtems.org
> >> http://lists.rtems.org/mailman/listinfo/devel
> > devel mailing list
> > devel at rtems.org
