[PATCH v4 0/3] [rtems-libbsd] Fix compilation for amd64
Tue Feb 18 23:13:01 UTC 2020
On 18/2/20 9:21 pm, Jan Sommer wrote:
> Similar to the previous patchset for i386 this one enables compilation for the amd64 BSP with the following limitations:
> - dev_nic_e1000 needs to be off
> - debugger01.exe does not link because the amd64 bsp has no libdebugger support
But libdebugger has i386 support. What is the issue?
