AW: [PATCH v4 0/3] [rtems-libbsd] Fix compilation for amd64
Jan.Sommer at dlr.de Jan.Sommer at dlr.de
Wed Feb 19 08:23:37 UTC 2020
Hi Chris,
> -----Ursprüngliche Nachricht-----
> Von: Chris Johns [mailto:chrisj at rtems.org]
> Gesendet: Mittwoch, 19. Februar 2020 00:13
> An: Sommer, Jan; devel at rtems.org
> Betreff: Re: [PATCH v4 0/3] [rtems-libbsd] Fix compilation for amd64
> On 18/2/20 9:21 pm, Jan Sommer wrote:
> > Similar to the previous patchset for i386 this one enables compilation for the
> amd64 BSP with the following limitations:
> > - dev_nic_e1000 needs to be off
> > - debugger01.exe does not link because the amd64 bsp has no libdebugger
> support
> But libdebugger has i386 support. What is the issue?
Yes, in the previous patch set, which was related to the i386/pc686 family of BSPs, the linking succeeded.
This patch set is related to the x86_64/amd64 BSP which is only in a rudimentary state and unrelated to the i386 ones.
I don't expect any of the binaries to run given the current state of the amd64 BSP. I used it as a training to get familiar with the rtems-libbsd style of development.
> Chris
