Top of file: licence header or Doxygen comment?
Gedare Bloom
gedare at rtems.org
Wed Feb 19 14:03:53 UTC 2020
On Wed, Feb 19, 2020 at 6:03 AM Sebastian Huber
> On 19/02/2020 13:56, Joel Sherrill wrote:
> > On Wed, Feb 19, 2020, 6:30 AM Sebastian Huber
> > <mailto:sebastian.huber at embedded-brains.de>> wrote:
> > On 19/02/2020 13:01, Joel Sherrill wrote:
> > > On Wed, Feb 19, 2020, 12:21 AM Chris Johns <chrisj at rtems.org
> > <mailto:chrisj at rtems.org>
> > > <mailto:chrisj at rtems.org <mailto:chrisj at rtems.org>>> wrote:
> > > On 19/2/20 5:18 pm, Sebastian Huber wrote:
> > > > I want to add a header and source file header template to the
> > > RTEMS Software
> > > > Engineering manual. What should be on the top of the file? The
> > > license header or
> > > > the Doxygen file comment block?
> > > License header.
> > > I think we have existing guidance that is the opposite of that
> > Yes, should we change it? In other projects, the SPDX License
> > Identifier
> > is usually on top of the file.
> > I don't want to change existing practice unless someone writes a program
> > to verify the order of the first two comment blocks and swap them.
> > Or (less desirable since it delays changing things a long time) we can
> > make a master list of these and make them GCI tasks. But we have trouble
> > getting mentors over the holidays. It still may not finish and it will
> > be at least a year before potential GCI students could make a dent (and
> > likely not fix all).
> > Write a program or leave the order alone.
> I would restrict this task to BSD-2-Clause licensed files with an SDPX
> License Identifier.
> Changing RTEMS licenced files to BSD-2-Clause is a different issue.
I think this is a good compromise. The inconsistency will help to
point out that a different license applies in that file.
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
> devel mailing list
> devel at rtems.org
