[PATCH] drvmgr: Fix determination of prefix in grlib uart driver
Thu Feb 20 16:34:37 UTC 2020
Yes, I'll push in the next few minutes.
On Thu, Feb 20, 2020 at 1:41 AM <Jan.Sommer at dlr.de> wrote:
> Hello,
> Could someone please push this change?
> There has been a lot of activity on this list recently, and I fear I will lose track at some point.
> Cheers,
>    Jan
> > -----Ursprüngliche Nachricht-----
> > Von: devel [mailto:devel-bounces at rtems.org] Im Auftrag von Jan Sommer
> > Gesendet: Mittwoch, 12. Februar 2020 15:10
> > An: devel at rtems.org
> > Betreff: [PATCH] drvmgr: Fix determination of prefix in grlib uart driver
> > From: Dennis Pfau <dennis.pfau at dlr.de>
> > drvmgr_get_dev_prefix returns 0 if a prefix was found.
> > Therefore the if condition needs to check for 0, i.e. DRVMGR_OK.
> >  bsps/shared/grlib/uart/apbuart_cons.c | 2 +-
> >  1 file changed, 1 insertion(+), 1 deletion(-)
> > diff --git a/bsps/shared/grlib/uart/apbuart_cons.c
> > b/bsps/shared/grlib/uart/apbuart_cons.c
> > index ee635e6944..e4d026a4cc 100644
> > --- a/bsps/shared/grlib/uart/apbuart_cons.c
> > +++ b/bsps/shared/grlib/uart/apbuart_cons.c
> > @@ -321,7 +321,7 @@ int apbuart_init1(struct drvmgr_dev *dev)
> >       priv->condev.fsname = NULL;
> >       /* Get Filesystem name prefix */
> >       prefix[0] = '\0';
> > -     if (drvmgr_get_dev_prefix(dev, prefix)) {
> > +     if (drvmgr_get_dev_prefix(dev, prefix) == DRVMGR_OK) {
> >               /* Got special prefix, this means we have a bus prefix
> >                * And we should use our "bus minor"
> > 2.17.1
> > devel mailing list
> > devel at rtems.org
> devel mailing list
> devel at rtems.org
