Project query
Gedare Bloom
gedare at rtems.org
Thu Feb 20 17:01:08 UTC 2020
On Thu, Feb 20, 2020 at 9:43 AM suyash singh <suyashsingh234 at gmail.com> wrote:
> So can I work on x86_64 BSP without hardware with simulator?
> https://devel.rtems.org/ticket/2898
> Also out of the prerequisites I only know C programming language but I am ready to learn everything else.
I think it will be too hard to work on a new BSP/port without the
assembly programming language experience in that architecture.
I'd suggest you look for projects for which you possess all/most of
the prerequisites (when explicitly stated).
Gedare
> On Thu, Feb 20, 2020 at 9:13 AM Gedare Bloom <gedare at rtems.org> wrote:
>> On Wed, Feb 19, 2020 at 6:29 PM Joel Sherrill <joel at rtems.org> wrote:
>> > On Wed, Feb 19, 2020, 6:12 PM John Millard <jmillard at sprynet.com> wrote:
>> >> Greetings:
>> >> I took Joel’s week-long class in June.
>> > :) Thanks. Hope you enjoyed it.
>> >> I’m currently retired and looking for a project, but clearly not a GSoC guy. The default list of tickets is mostly old or currently assigned.
>> > Currently assigned may not mean as much as you think. It is often done by someone to direct the ticket to who wrote the code. I know I often file tickets where I have looked into who is most likely to fix it and assign it to them.
>> > For example, I need to file a ticket for breakages building rtems-examples using waf. And when you build RTEMS using rtems6 tools, there are breakages because rtems5 is not replaced with rtems6 is still in some places. I reported both I think this week to devel.
>> >> The “open projects” page looks more relevant. I can buy hardware if somewhat reasonably priced. Having actual hardware would be somewhat preferred, even if qemu is amazing. I can do assembly (most familiar with Intel, but open to learning), low-level C down to the hardware, and have experience with OS level programming and drivers, serial and network transport, debuggers.
>> > If that's the direction you want to go in, the x86_64 port and bsp are incomplete. There should be plenty of room to get things working. This would help ween us off of depending on legacy boot PCs.
>> +1
>> And so far few students to work on it, and it is a big area to work on.
>> There is also an open project to improve legacy x86:
>> https://devel.rtems.org/ticket/2900
>> >> Is there some priority on the projects? They are all equal, but some are more equal than others. I can guess the scope on some of them.
>> > For the most part, there isn't much priority. If you ask different people, you will likely get different answers.
>> >> Suggestions welcome.
>> >> John
>> >> —where there are tools, a will, and a will to build tools there is a way
>> >> _________________________________
>> >> devel mailing list
>> >> devel at rtems.org
>> >> http://lists.rtems.org/mailman/listinfo/devel
>> >> _______________________________________________
>> >> devel mailing list
>> >> devel at rtems.org
>> > devel mailing list
>> > devel at rtems.org
>> devel mailing list
>> devel at rtems.org
