Project query
suyash singh
suyashsingh234 at gmail.com
Thu Feb 20 17:56:23 UTC 2020
I found this interesting project
https://devel.rtems.org/ticket/3710
There are no prerequisites given for this one
On Thu, Feb 20, 2020 at 10:31 PM Gedare Bloom <gedare at rtems.org> wrote:
> On Thu, Feb 20, 2020 at 9:43 AM suyash singh <suyashsingh234 at gmail.com>
> wrote:
> > So can I work on x86_64 BSP without hardware with simulator?
> > https://devel.rtems.org/ticket/2898
> > Also out of the prerequisites I only know C programming language but I
> am ready to learn everything else.
> I think it will be too hard to work on a new BSP/port without the
> assembly programming language experience in that architecture.
> I'd suggest you look for projects for which you possess all/most of
> the prerequisites (when explicitly stated).
> Gedare
> > On Thu, Feb 20, 2020 at 9:13 AM Gedare Bloom <gedare at rtems.org> wrote:
> >> On Wed, Feb 19, 2020 at 6:29 PM Joel Sherrill <joel at rtems.org> wrote:
> >> > On Wed, Feb 19, 2020, 6:12 PM John Millard <jmillard at sprynet.com>
> wrote:
> >> >> Greetings:
> >> >> I took Joel’s week-long class in June.
> >> > :) Thanks. Hope you enjoyed it.
> >> >> I’m currently retired and looking for a project, but clearly not a
> GSoC guy. The default list of tickets is mostly old or currently assigned.
> >> > Currently assigned may not mean as much as you think. It is often
> done by someone to direct the ticket to who wrote the code. I know I often
> file tickets where I have looked into who is most likely to fix it and
> assign it to them.
> >> > For example, I need to file a ticket for breakages building
> rtems-examples using waf. And when you build RTEMS using rtems6 tools,
> there are breakages because rtems5 is not replaced with rtems6 is still in
> some places. I reported both I think this week to devel.
> >> >> The “open projects” page looks more relevant. I can buy hardware if
> somewhat reasonably priced. Having actual hardware would be somewhat
> preferred, even if qemu is amazing. I can do assembly (most familiar with
> Intel, but open to learning), low-level C down to the hardware, and have
> experience with OS level programming and drivers, serial and network
> transport, debuggers.
> >> > If that's the direction you want to go in, the x86_64 port and bsp
> are incomplete. There should be plenty of room to get things working. This
> would help ween us off of depending on legacy boot PCs.
> >> +1
> >> And so far few students to work on it, and it is a big area to work on.
> >> There is also an open project to improve legacy x86:
> >> https://devel.rtems.org/ticket/2900
> >> >> Is there some priority on the projects? They are all equal, but some
> are more equal than others. I can guess the scope on some of them.
> >> > For the most part, there isn't much priority. If you ask different
> people, you will likely get different answers.
> >> >> Suggestions welcome.
> >> >> John
> >> >> —where there are tools, a will, and a will to build tools there is a
> way
> >> >> _________________________________
> >> >> devel mailing list
> >> >> devel at rtems.org
> >> >> http://lists.rtems.org/mailman/listinfo/devel
> >> >> _______________________________________________
> >> >> devel mailing list
> >> >> devel at rtems.org
> >> > devel mailing list
> >> > devel at rtems.org
> >> devel mailing list
> >> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200220/c8d110f3/attachment-0001.html>
