SPDX License Identifier Only and Full Copy?
Fri Feb 21 01:15:51 UTC 2020
On 21/2/20 12:11 pm, Joel Sherrill wrote:
> On Thu, Feb 20, 2020, 3:49 PM Chris Johns <chrisj at rtems.org
> <mailto:chrisj at rtems.org>> wrote:
>     On 21/2/20 3:20 am, Gedare Bloom wrote:
>     > On Thu, Feb 20, 2020 at 12:58 AM Thomas Doerfler
>     > <thomas.doerfler at embedded-brains.de
>     <mailto:thomas.doerfler at embedded-brains.de>> wrote:
>     >> Hello,
>     >> I just want to speak up here. I talked with Sebastian today and I really
>     >> tend to keep the license text in each file.
>     >> Rational:
>     >> - With the BSD license, anyone can pick any file from the RTEMS repo and
>     >> use/modify it in any project (and this is fine). The original authors
>     >> (and their copyright) are listed in the file, but the only pointer to
>     >> the legal part is the "SPDX identifier". I am not sure whether this is a
>     >> legally binding "tag" and whether this tag is clear to any user.
>     >> - Strictly seen, it is not even forbidden to remove the "SPDX
>     >> identifier", because it is not part of the BSD-2-clause-license, it's
>     >> just a pointer to it. In the end we might result in code drifting around
>     >> without license information, which we all do not want to see.
>     > This is a valid point. I also have no desire to be a lawyer.
>     > My intuition here is that, even without any licensing information at
>     > all in individual files, one can still apply a single license to an
>     > entire repository, e.g., BSD or GPL. For historical reasons, and
>     > similar arguments as you've made, BSD-style licenses have tended to be
>     > copy-pasted to individual files to make them easier to excerpt. We
>     > don't have license uniformity, so we do need to individually specify
>     > which license(s) apply to each file.
>     This makes sense. The simplified BSD license states ...
>      1. Redistributions of source code must retain the above copyright
>         notice, this list of conditions and the following disclaimer.
>     I do not see how we can centralise this and have the "above copyright" work?
>     Also the SPDX site here ...
>      https://spdx.org/ids-how
>     ... under the heading "Standard license headers" states ...
>      When a license defines a recommended notice to attach to files
>      under that license (sometimes called a "standard header"), the SPDX
>      project recommends that the standard header be included in the files,
>      in addition to an SPDX ID.
>     My reading of this means we should include the license in the source.
>     We need to consider compliance and machine auditing of the source. The SPDX tag
>     is important. Maybe ...
>      * SPDX tag suff
>      * Copyright stuff
>      * 2-Clause BSD license
>     > Linux follows a similar philosophy as Sebastian suggests. I think we
>     > can also follow Linux in this regards.
>     > https://www.kernel.org/doc/html/latest/process/license-rules.html
>     > I would suggest we follow their approach to self-document the licenses
>     > centrally. I suspect the risk of someone using code without adhering
>     > to the license is no greater. Probably they have a higher risk
>     > exposure than we do!
>     I agree with the comments in the Linux license rules text about license text in
>     files making it harder to check for compliance.
> Following Linux is probably a safe approach. I assume there was significant
> legal review of their policy.
Does the Linux kernel rules apply to the 2 clause BSD license we have?
