[PATCH] c-user: Clarify filesystem configuration
Fri Feb 21 10:09:34 UTC 2020
Update #3875.
 c-user/configuring_a_system.rst | 45 ++++++++++++++++++++++++++++++++++++++---
 1 file changed, 42 insertions(+), 3 deletions(-)
diff --git a/c-user/configuring_a_system.rst b/c-user/configuring_a_system.rst
index 5deabd7..230d6b6 100644
--- a/c-user/configuring_a_system.rst
+++ b/c-user/configuring_a_system.rst
@@ -2124,10 +2124,49 @@ NOTES:
                          500, sizeof(other_message_type) \
-File System Configuration Parameters
+Filesystem Configuration
-This section defines File System related configuration parameters.
+By default, the In-Memory Filesystem (IMFS) is used as the base filesystem (also
+known as root filesystem).  In order to save some memory for your application,
+you can disable the filesystem support with the
+:ref:`CONFIGURE_APPLICATION_DISABLE_FILESYSTEM` configuration option.
+Alternatively, you can strip down the features of the base filesystem with the
+:ref:`CONFIGURE_USE_MINIIMFS_AS_BASE_FILESYSTEM` and
+:ref:`CONFIGURE_USE_DEVFS_AS_BASE_FILESYSTEM` configuration options.  These
+three configuration options are mutually exclusive.  They are intended for an
+advanced application configuration.
+Features of the IMFS can be disabled and enabled with the following
+configuration options:
+* :ref:`CONFIGURE_IMFS_DISABLE_CHMOD`
+* :ref:`CONFIGURE_IMFS_DISABLE_CHOWN`
+* :ref:`CONFIGURE_IMFS_DISABLE_LINK`
+* :ref:`CONFIGURE_IMFS_DISABLE_MKNOD`
+* :ref:`CONFIGURE_IMFS_DISABLE_MKNOD_FILE`
+* :ref:`CONFIGURE_IMFS_DISABLE_MOUNT`
+* :ref:`CONFIGURE_IMFS_DISABLE_READDIR`
+* :ref:`CONFIGURE_IMFS_DISABLE_READLINK`
+* :ref:`CONFIGURE_IMFS_DISABLE_RENAME`
+* :ref:`CONFIGURE_IMFS_DISABLE_RMNOD`
+* :ref:`CONFIGURE_IMFS_DISABLE_SYMLINK`
+* :ref:`CONFIGURE_IMFS_DISABLE_UNMOUNT`
+* :ref:`CONFIGURE_IMFS_DISABLE_UTIME`
+* :ref:`CONFIGURE_IMFS_ENABLE_MKFIFO`
 .. index:: CONFIGURE_USE_DEVFS_AS_BASE_FILESYSTEM
2.16.4
