[PATCH v2 00/44] Split up confdefs.h
Sebastian Huber
Fri Feb 21 10:52:12 UTC 2020
This patch set splits up confdefs.h into component based header files. See
also:
https://devel.rtems.org/ticket/3875
The goal is to make the 3000 LOC header file confdefs.h easier to review. The
configuration header files are located in <rtems/confdefs/*.h>.
This patch set removes also the configuration options
CONFIGURE_HAS_OWN_INIT_TASK_TABLE, CONFIGURE_POSIX_HAS_OWN_INIT_THREAD_TABLE,
and CONFIGURE_DISABLE_SMP_CONFIGURATION to simplify the configuration.
Please note that staring with the "config: Improve _Configure_From_workspace()"
there are no changes in the test suite.
I changed the license of the contents to BSD-2-Clause (except
<rtems/confdefs/libpci.h>) according to the file history and through a removal
of comments and other copyrightable content.
The new configuration header files are self-contained, e.g. the includes in
confdefs.h can be arbitrarily ordered. They include all dependencies
explicitly. I entangled the evaluation of the configuration options so that
there are no cyclic dependencies.
Sebastian Huber (44):
config: Remove CONFIGURE_HAS_OWN_INIT_TASK_TABLE
config: Simplify initialization task config
rtems: Simplify _RTEMS_tasks_Initialize_user_task()
config: Bring back RTEMS 4.11 configuration table
config: Remove CONFIGURE_POSIX_HAS_OWN_INIT_THREAD_TABLE
config: Add _Watchdog_Microseconds_per_tick
config: Add _Watchdog_Ticks_per_timeslice
config: Add _Thread_Idle_stack_size
config: Add _Thread_Idle_body
config: Add _Workspace_Size
config: Add _Workspace_Is_unified
config: Add _SMP_Processor_configure_maximum
config: Add _SMP_Is_enabled
libio: Add POSIX user environment to TCB
score: Add _SMP_Need_inter_processor_interrupts()
bsps/clock: Use _SMP_Get_processor_maximum()
config: CONFIGURE_INIT_TASK_INITIAL_MODES
score: _Scheduler_Is_non_preempt_mode_supported()
rtems: Change timer server task mode setting
config: Remove CONFIGURE_DISABLE_SMP_CONFIGURATION
config: Remove _Configure_Max_Objects()
config: Add <rtems/confdefs/obsolete.h>
config: Add <rtems/confdefs/libpci.h>
config: Add <rtems/confdefs/bsp.h>
config: Add <rtems/confdefs/percpu.h>
config: Add <rtems/confdefs/libio.h>
config: Add <rtems/confdefs/scheduler.h>
config: Add <rtems/confdefs/bdbuf.h>
config: Add <rtems/confdefs/malloc.h>
config: Add <rtems/confdefs/mcpi.h>
config: Add <rtems/confdefs/clock.h>
config: Add <rtems/confdefs/newlib.h>
config: Add <rtems/confdefs/extensions.h>
config: Add <rtems/confdefs/inittask.h>
config: Add <rtems/confdefs/initthread.h>
config: Add <rtems/confdefs/console.h>
config: Add <rtems/confdefs/iodrivers.h>
config: Add <rtems/confdefs/unlimited.h>
config: Add <rtems/confdefs/threads.h>
config: Add <rtems/confdefs/objectsclassic.h>
config: Add <rtems/confdefs/wkspacesupport.h>
config: Add <rtems/confdefs/objectsposix.h>
config: Add <rtems/confdefs/wkspace.h>
bsps/shared/dev/clock/clockimpl.h | 2 +-
cpukit/Makefile.am | 7 +
cpukit/header-dirs.am | 2 +
cpukit/headers.am | 25 +-
cpukit/include/rtems/confdefs.h | 3120 +-------------------
cpukit/include/rtems/confdefs/bdbuf.h | 161 +
cpukit/include/rtems/confdefs/bsp.h | 60 +
cpukit/include/rtems/confdefs/clock.h | 109 +
cpukit/include/rtems/confdefs/console.h | 85 +
cpukit/include/rtems/confdefs/extensions.h | 158 +
cpukit/include/rtems/confdefs/inittask.h | 131 +
cpukit/include/rtems/confdefs/initthread.h | 97 +
cpukit/include/rtems/confdefs/iodrivers.h | 166 ++
cpukit/include/rtems/confdefs/libio.h | 410 +++
cpukit/include/rtems/confdefs/libpci.h | 70 +
cpukit/include/rtems/confdefs/malloc.h | 72 +
cpukit/include/rtems/confdefs/mpci.h | 147 +
cpukit/include/rtems/confdefs/newlib.h | 72 +
cpukit/include/rtems/confdefs/objectsclassic.h | 127 +
cpukit/include/rtems/confdefs/objectsposix.h | 197 ++
cpukit/include/rtems/confdefs/obsolete.h | 234 ++
cpukit/include/rtems/confdefs/percpu.h | 158 +
cpukit/include/rtems/confdefs/scheduler.h | 370 +++
cpukit/include/rtems/confdefs/threads.h | 234 ++
cpukit/include/rtems/confdefs/unlimited.h | 143 +
cpukit/include/rtems/confdefs/wkspace.h | 182 ++
cpukit/include/rtems/confdefs/wkspacesupport.h | 64 +
cpukit/include/rtems/config.h | 111 +-
cpukit/include/rtems/libio_.h | 4 -
cpukit/include/rtems/posix/config.h | 60 -
cpukit/include/rtems/posix/pthread.h | 25 +-
cpukit/include/rtems/posix/pthreadimpl.h | 1 -
cpukit/include/rtems/rtems/config.h | 74 +-
cpukit/include/rtems/rtems/tasksdata.h | 19 +-
cpukit/include/rtems/scheduler.h | 16 +
cpukit/include/rtems/score/interr.h | 2 +-
cpukit/include/rtems/score/scheduler.h | 8 +
cpukit/include/rtems/score/schedulerimpl.h | 18 +
cpukit/include/rtems/score/smp.h | 13 +
cpukit/include/rtems/score/smpimpl.h | 15 +
cpukit/include/rtems/score/thread.h | 7 +
cpukit/include/rtems/score/threadidledata.h | 78 +
cpukit/include/rtems/score/watchdogticks.h | 21 +
cpukit/include/rtems/score/wkspacedata.h | 74 +
cpukit/include/rtems/sysinit.h | 1 +
cpukit/include/rtems/userenv.h | 6 +-
cpukit/libcsupport/src/__usrenv.c | 14 +-
cpukit/libcsupport/src/libio_init.c | 11 -
cpukit/libcsupport/src/mallocdirtydefault.c | 34 +
cpukit/libcsupport/src/mallocextenddefault.c | 35 +
cpukit/libcsupport/src/privateenv.c | 67 +-
cpukit/libmisc/monitor/mon-config.c | 4 +-
cpukit/libmisc/monitor/mon-itask.c | 8 +-
cpukit/posix/src/pthread.c | 2 +
cpukit/posix/src/pthreadinitthreads.c | 75 +-
cpukit/rtems/src/getapiconfig.c | 64 +
cpukit/rtems/src/taskinitdefault.c | 34 +
cpukit/rtems/src/taskinitusers.c | 103 +-
cpukit/rtems/src/taskmode.c | 12 +-
cpukit/rtems/src/timerserver.c | 12 +-
cpukit/sapi/src/sysinitverbose.c | 10 +-
cpukit/score/src/threadcreateidle.c | 6 +-
cpukit/score/src/threaddispatch.c | 2 +-
cpukit/score/src/threadidledefault.c | 35 +
cpukit/score/src/threadinitialize.c | 7 +-
cpukit/score/src/watchdogtimeslicedefault.c | 35 +
cpukit/score/src/wkspaceisunifieddefault.c | 34 +
testsuites/ada/support/initimpl.h | 2 -
testsuites/fstests/fsdosfsname01/init.c | 1 -
testsuites/fstests/imfs_support/fs_support.c | 1 -
testsuites/fstests/jffs2_support/fs_support.c | 2 -
testsuites/fstests/mdosfs_support/fs_support.c | 1 -
testsuites/fstests/mimfs_support/fs_support.c | 1 -
testsuites/fstests/mrfs_support/fs_support.c | 1 -
testsuites/libtests/block08/system.h | 2 -
testsuites/libtests/cpuuse/system.h | 2 -
testsuites/libtests/ftp01/init.c | 2 -
testsuites/libtests/rtmonuse/system.h | 1 -
testsuites/libtests/termios05/init.c | 2 -
testsuites/psxtests/psxchroot01/main.c | 2 -
testsuites/psxtests/psxconfig01/init.c | 2 +-
testsuites/psxtests/psxfatal01/init.c | 22 +-
testsuites/psxtests/psxfatal02/init.c | 40 +-
testsuites/psxtests/psxmount/main.c | 2 -
testsuites/smptests/smpunsupported01/init.c | 2 -
testsuites/sptests/Makefile.am | 9 -
testsuites/sptests/configure.ac | 1 -
testsuites/sptests/sp01/system.h | 2 -
testsuites/sptests/sp04/system.h | 2 -
testsuites/sptests/sp07/system.h | 2 -
testsuites/sptests/sp08/init.c | 2 -
testsuites/sptests/sp12/system.h | 2 -
testsuites/sptests/sp13/system.h | 2 -
testsuites/sptests/sp14/system.h | 2 -
testsuites/sptests/sp16/system.h | 2 -
testsuites/sptests/sp20/system.h | 2 -
testsuites/sptests/sp37/system.h | 2 -
testsuites/sptests/sp54/init.c | 26 +-
testsuites/sptests/sp65/sp65impl.h | 2 -
testsuites/sptests/sp66/init.c | 1 +
testsuites/sptests/spcbssched01/system.h | 2 -
testsuites/sptests/spcbssched02/system.h | 2 -
testsuites/sptests/spcbssched03/system.h | 2 -
testsuites/sptests/spedfsched01/system.h | 2 -
testsuites/sptests/spedfsched02/system.h | 2 -
testsuites/sptests/spedfsched03/system.h | 2 -
testsuites/sptests/spfatal01/init.c | 33 +-
testsuites/sptests/spfatal02/init.c | 20 +-
testsuites/sptests/spfatal04/init.c | 20 -
testsuites/sptests/spfatal05/init.c | 20 -
testsuites/sptests/spfatal06/init.c | 24 +-
testsuites/sptests/spfatal27/init.c | 34 -
testsuites/sptests/spfatal27/spfatal27.doc | 23 -
testsuites/sptests/spfatal27/spfatal27.scn | 3 -
testsuites/sptests/spfatal29/init.c | 2 -
testsuites/sptests/spfifo03/init.c | 2 -
testsuites/sptests/spfifo05/init.c | 2 -
.../spintrcritical06/spintrcritical06impl.h | 2 -
testsuites/sptests/spintrcritical15/init.c | 2 -
testsuites/sptests/spmrsp01/init.c | 2 -
testsuites/sptests/spprivenv01/init.c | 3 -
testsuites/sptests/spsimplesched02/init.c | 4 +-
testsuites/sptests/spsysinit01/init.c | 62 +-
testsuites/tmtests/tm04/system.h | 2 -
testsuites/tmtests/tm08/system.h | 2 -
testsuites/tmtests/tm15/system.h | 2 -
testsuites/tmtests/tm20/system.h | 2 -
testsuites/tmtests/tm22/system.h | 2 -
testsuites/tmtests/tm24/system.h | 2 -
129 files changed, 4443 insertions(+), 3746 deletions(-)
create mode 100644 cpukit/include/rtems/confdefs/bdbuf.h
create mode 100644 cpukit/include/rtems/confdefs/bsp.h
create mode 100644 cpukit/include/rtems/confdefs/clock.h
create mode 100644 cpukit/include/rtems/confdefs/console.h
create mode 100644 cpukit/include/rtems/confdefs/extensions.h
create mode 100644 cpukit/include/rtems/confdefs/inittask.h
create mode 100644 cpukit/include/rtems/confdefs/initthread.h
create mode 100644 cpukit/include/rtems/confdefs/iodrivers.h
create mode 100644 cpukit/include/rtems/confdefs/libio.h
create mode 100644 cpukit/include/rtems/confdefs/libpci.h
create mode 100644 cpukit/include/rtems/confdefs/malloc.h
create mode 100644 cpukit/include/rtems/confdefs/mpci.h
create mode 100644 cpukit/include/rtems/confdefs/newlib.h
create mode 100644 cpukit/include/rtems/confdefs/objectsclassic.h
create mode 100644 cpukit/include/rtems/confdefs/objectsposix.h
create mode 100644 cpukit/include/rtems/confdefs/obsolete.h
create mode 100644 cpukit/include/rtems/confdefs/percpu.h
create mode 100644 cpukit/include/rtems/confdefs/scheduler.h
create mode 100644 cpukit/include/rtems/confdefs/threads.h
create mode 100644 cpukit/include/rtems/confdefs/unlimited.h
create mode 100644 cpukit/include/rtems/confdefs/wkspace.h
create mode 100644 cpukit/include/rtems/confdefs/wkspacesupport.h
delete mode 100644 cpukit/include/rtems/posix/config.h
create mode 100644 cpukit/include/rtems/score/threadidledata.h
create mode 100644 cpukit/include/rtems/score/wkspacedata.h
create mode 100644 cpukit/libcsupport/src/mallocdirtydefault.c
create mode 100644 cpukit/libcsupport/src/mallocextenddefault.c
create mode 100644 cpukit/rtems/src/getapiconfig.c
create mode 100644 cpukit/rtems/src/taskinitdefault.c
create mode 100644 cpukit/score/src/threadidledefault.c
create mode 100644 cpukit/score/src/watchdogtimeslicedefault.c
create mode 100644 cpukit/score/src/wkspaceisunifieddefault.c
delete mode 100644 testsuites/sptests/spfatal27/init.c
delete mode 100644 testsuites/sptests/spfatal27/spfatal27.doc
delete mode 100644 testsuites/sptests/spfatal27/spfatal27.scn
2.16.4
