[PATCH v2 22/44] config: Remove _Configure_Max_Objects()
Fri Feb 21 10:52:34 UTC 2020
Use rtems_resource_maximum_per_allocation() directly.  The use of
_Configure_Zero_or_one() was superfluous.
Update #3875.
 cpukit/include/rtems/confdefs.h | 13 +++----------
 1 file changed, 3 insertions(+), 10 deletions(-)
diff --git a/cpukit/include/rtems/confdefs.h b/cpukit/include/rtems/confdefs.h
index 50e4646083..a075470b88 100644
--- a/cpukit/include/rtems/confdefs.h
+++ b/cpukit/include/rtems/confdefs.h
@@ -1255,13 +1255,6 @@ const Thread_Idle_body _Thread_Idle_body = CONFIGURE_IDLE_TASK_BODY;
   #define _Configure_From_stackspace(_stack_size) \
     _Configure_From_workspace(_stack_size + CONTEXT_FP_SIZE)
 #endif
- * Do not use the unlimited bit as part of the multiplication
- * for memory usage.
-#define _Configure_Max_Objects(_max) \
-  (_Configure_Zero_or_One(_max) * rtems_resource_maximum_per_allocation(_max))
@@ -2069,7 +2062,7 @@ struct _reent *__getreent(void)
  * of the object to be duplicated.
 #define _Configure_POSIX_Named_Object_RAM(_number, _size) \
-  (_Configure_Max_Objects(_number) \
+  (rtems_resource_maximum_per_allocation(_number) \
     * _Configure_From_workspace(_POSIX_PATH_MAX + 1))
@@ -2293,7 +2286,7 @@ struct _reent *__getreent(void)
  * the stacks of all tasks.
 #define _CONFIGURE_TASKS_STACK \
-  (_Configure_Max_Objects( _CONFIGURE_TASKS ) * \
+  (rtems_resource_maximum_per_allocation( _CONFIGURE_TASKS ) * \
     _Configure_From_stackspace( CONFIGURE_MINIMUM_TASK_STACK_SIZE ) )
@@ -2301,7 +2294,7 @@ struct _reent *__getreent(void)
  * the stacks of all POSIX threads.
 #define _CONFIGURE_POSIX_THREADS_STACK \
-  (_Configure_Max_Objects( CONFIGURE_MAXIMUM_POSIX_THREADS ) * \
+  (rtems_resource_maximum_per_allocation( CONFIGURE_MAXIMUM_POSIX_THREADS ) * \
     _Configure_From_stackspace( CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE ) )
 #else /* CONFIGURE_EXECUTIVE_RAM_SIZE */
2.16.4
