[PATCH v2 23/44] config: Add <rtems/confdefs/obsolete.h>
Sebastian Huber
Fri Feb 21 10:52:35 UTC 2020
Unify handling of obsolete configuration options. Remove comments and
copyrightable content from the moved content. Use BSD-2-Clause license
for new file.
Update #3053.
Update #3875.
cpukit/header-dirs.am | 2 +
cpukit/headers.am | 1 +
cpukit/include/rtems/confdefs.h | 167 +---------------------
cpukit/include/rtems/confdefs/obsolete.h | 234 +++++++++++++++++++++++++++++++
4 files changed, 238 insertions(+), 166 deletions(-)
create mode 100644 cpukit/include/rtems/confdefs/obsolete.h
diff --git a/cpukit/header-dirs.am b/cpukit/header-dirs.am
index 7197f1a29f..d90271be9e 100644
--- a/cpukit/header-dirs.am
+++ b/cpukit/header-dirs.am
@@ -50,6 +50,8 @@ include_rtems_bfindir = $(includedir)/rtems/bfin
include_rtems_bfin_HEADERS =
include_rtems_bsdnetdir = $(includedir)/rtems/bsdnet
include_rtems_bsdnet_HEADERS =
+include_rtems_confdefsdir = $(includedir)/rtems/confdefs
+include_rtems_confdefs_HEADERS =
include_rtems_debuggerdir = $(includedir)/rtems/debugger
include_rtems_debugger_HEADERS =
include_rtems_m68kdir = $(includedir)/rtems/m68k
diff --git a/cpukit/headers.am b/cpukit/headers.am
index 6e1ab4ccd0..f0c8319dcb 100644
--- a/cpukit/headers.am
+++ b/cpukit/headers.am
@@ -183,6 +183,7 @@ include_rtems_HEADERS += include/rtems/userenv.h
include_rtems_HEADERS += include/rtems/version.h
include_rtems_HEADERS += include/rtems/vmeintr.h
include_rtems_HEADERS += include/rtems/watchdogdrv.h
+include_rtems_confdefs_HEADERS += include/rtems/confdefs/obsolete.h
include_rtems_debugger_HEADERS += include/rtems/debugger/rtems-debugger-bsp.h
include_rtems_debugger_HEADERS += include/rtems/debugger/rtems-debugger-remote.h
include_rtems_debugger_HEADERS += include/rtems/debugger/rtems-debugger-server.h
diff --git a/cpukit/include/rtems/confdefs.h b/cpukit/include/rtems/confdefs.h
index a075470b88..1fecfdcbb6 100644
--- a/cpukit/include/rtems/confdefs.h
+++ b/cpukit/include/rtems/confdefs.h
@@ -50,6 +50,7 @@
#include <rtems/posix/semaphore.h>
#include <rtems/posix/shm.h>
#include <rtems/posix/timer.h>
+#include <rtems/confdefs/obsolete.h>
#include <limits.h>
@@ -125,11 +126,6 @@ extern "C" {
#endif
#endif
-#ifdef CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS
- #warning "CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS has been renamed to CONFIGURE_MAXIMUM_FILE_DESCRIPTORS since RTEMS 5.1"
- #define CONFIGURE_MAXIMUM_FILE_DESCRIPTORS CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS
-#endif
* This macro defines the number of POSIX file descriptors allocated
* and managed by libio. These are the "integer" file descriptors that
@@ -149,11 +145,6 @@ extern "C" {
const uint32_t rtems_libio_number_iops = RTEMS_ARRAY_SIZE(rtems_libio_iops);
#endif
-#ifdef CONFIGURE_SMP_MAXIMUM_PROCESSORS
- #warning "CONFIGURE_SMP_MAXIMUM_PROCESSORS has been renamed to CONFIGURE_MAXIMUM_PROCESSORS since RTEMS 5.1"
- #define CONFIGURE_MAXIMUM_PROCESSORS CONFIGURE_SMP_MAXIMUM_PROCESSORS
-#endif
/* Ensure that _CONFIGURE_MAXIMUM_PROCESSORS > 1 only in SMP configurations */
#if defined(CONFIGURE_MAXIMUM_PROCESSORS) && defined(RTEMS_SMP)
#define _CONFIGURE_MAXIMUM_PROCESSORS CONFIGURE_MAXIMUM_PROCESSORS
@@ -161,34 +152,10 @@ extern "C" {
#define _CONFIGURE_MAXIMUM_PROCESSORS 1
#endif
-#ifdef CONFIGURE_SMP_APPLICATION
- #warning "CONFIGURE_SMP_APPLICATION is obsolete since RTEMS 5.1"
-#endif
* This sets up the resources for the FIFOs/pipes.
- * This is specified to configure the maximum number of POSIX FIFOs.
-#ifdef CONFIGURE_MAXIMUM_FIFOS
- #warning "CONFIGURE_MAXIMUM_FIFOS is obsolete since RTEMS 5.1; use CONFIGURE_IMFS_ENABLE_MKFIFO instead"
- #if CONFIGURE_MAXIMUM_FIFOS > 0
- #define CONFIGURE_IMFS_ENABLE_MKFIFO
- #endif
-#endif
- * This is specified to configure the maximum number of POSIX named pipes.
-#ifdef CONFIGURE_MAXIMUM_PIPES
- #warning "CONFIGURE_MAXIMUM_PIPES is obsolete since RTEMS 5.1; use CONFIGURE_IMFS_ENABLE_MKFIFO instead"
- #if CONFIGURE_MAXIMUM_PIPES > 0
- #endif
-#endif
* @defgroup ConfigFilesystems Filesystems and Mount Table Configuration
@@ -587,14 +554,6 @@ extern "C" {
#endif
/**@}*/ /* end of file system group */
- * STACK_CHECKER_ON was still available in 4.9 so give a warning for now.
-#if defined(STACK_CHECKER_ON)
- #define CONFIGURE_STACK_CHECKER_ENABLED
- #warning "STACK_CHECKER_ON deprecated -- use CONFIGURE_STACK_CHECKER_ENABLED"
-#endif
* @brief Maximum priority configuration.
@@ -663,21 +622,6 @@ extern "C" {
* - CONFIGURE_SCHEDULER_USER_PER_THREAD
-#ifdef CONFIGURE_SCHEDULER_CONTEXT
- #warning "CONFIGURE_SCHEDULER_CONTEXT has been renamed to CONFIGURE_SCHEDULER since RTEMS 5.1"
- #define CONFIGURE_SCHEDULER CONFIGURE_SCHEDULER_CONTEXT
-#endif
-#ifdef CONFIGURE_SCHEDULER_CONTROLS
- #warning "CONFIGURE_SCHEDULER_CONTROLS has been renamed to CONFIGURE_SCHEDULER_TABLE_ENTRIES since RTEMS 5.1"
- #define CONFIGURE_SCHEDULER_TABLE_ENTRIES CONFIGURE_SCHEDULER_CONTROLS
-#endif
-#ifdef CONFIGURE_SMP_SCHEDULER_ASSIGNMENTS
- #warning "CONFIGURE_SMP_SCHEDULER_ASSIGNMENTS has been renamed to CONFIGURE_SCHEDULER_ASSIGNMENTS since RTEMS 5.1"
- #define CONFIGURE_SCHEDULER_ASSIGNMENTS CONFIGURE_SMP_SCHEDULER_ASSIGNMENTS
-#endif
#if !defined(CONFIGURE_SCHEDULER_USER) && \
!defined(CONFIGURE_SCHEDULER_PRIORITY) && \
!defined(CONFIGURE_SCHEDULER_PRIORITY_SMP) && \
@@ -1618,12 +1562,6 @@ const Thread_Idle_body _Thread_Idle_body = CONFIGURE_IDLE_TASK_BODY;
(_CONFIGURE_LIBBLOCK_TASKS * \
(CONFIGURE_BDBUF_TASK_STACK_SIZE <= CONFIGURE_MINIMUM_TASK_STACK_SIZE ? \
0 : CONFIGURE_BDBUF_TASK_STACK_SIZE - CONFIGURE_MINIMUM_TASK_STACK_SIZE))
- #if defined(CONFIGURE_HAS_OWN_BDBUF_TABLE) || \
- defined(CONFIGURE_BDBUF_BUFFER_SIZE) || \
- defined(CONFIGURE_BDBUF_BUFFER_COUNT)
- #error BDBUF Cache does not use a buffer configuration table. Please remove.
- #endif
#else
/** This specifies the number of libblock tasks. */
#define _CONFIGURE_LIBBLOCK_TASKS 0
@@ -2842,17 +2780,6 @@ struct _reent *__getreent(void)
#endif
#endif /* !defined(RTEMS_SCHEDSIM) */
- * These names have been obsoleted so make the user application stop compiling
-#if defined(CONFIGURE_TEST_NEEDS_TIMER_DRIVER) || \
- defined(CONFIGURE_TEST_NEEDS_CONSOLE_DRIVER) || \
- defined(CONFIGURE_TEST_NEEDS_CLOCK_DRIVER) || \
- defined(CONFIGURE_TEST_NEEDS_RTC_DRIVER) || \
- defined(CONFIGURE_TEST_NEEDS_STUB_DRIVER)
-#error "CONFIGURATION ERROR: CONFIGURE_TEST_XXX constants are obsolete"
-#endif
* Validate the configured maximum priority
@@ -2870,82 +2797,6 @@ struct _reent *__getreent(void)
#error "Maximum priority configured higher than supported by target."
#endif
-#ifdef CONFIGURE_HAS_OWN_CONFIGURATION_TABLE
- #warning "The CONFIGURE_HAS_OWN_CONFIGURATION_TABLE configuration option is obsolete since RTEMS 5.1"
-#endif
-#ifdef CONFIGURE_HAS_OWN_DEVICE_DRIVER_TABLE
- #warning "The CONFIGURE_HAS_OWN_DEVICE_DRIVER_TABLE configuration option is obsolete since RTEMS 5.1"
-#endif
-#ifdef CONFIGURE_HAS_OWN_FILESYSTEM_TABLE
- #warning "The CONFIGURE_HAS_OWN_FILESYSTEM_TABLE configuration option is obsolete since RTEMS 5.1"
-#endif
-#ifdef CONFIGURE_HAS_OWN_INIT_TABLE
- #warning "The CONFIGURE_HAS_OWN_INIT_TABLE configuration option is obsolete since RTEMS 5.1"
-#endif
-#ifdef CONFIGURE_HAS_OWN_MOUNT_TABLE
- #warning "The CONFIGURE_HAS_OWN_MOUNT_TABLE configuration option is obsolete since RTEMS 5.1"
-#endif
-#ifdef CONFIGURE_HAS_OWN_MULTIPROCESSING_TABLE
-#endif
-#ifdef CONFIGURE_NUMBER_OF_TERMIOS_PORTS
- #warning "The CONFIGURE_NUMBER_OF_TERMIOS_PORTS configuration option is obsolete since RTEMS 5.1"
-#endif
-#ifdef CONFIGURE_MAXIMUM_ADA_TASKS
- #warning "The CONFIGURE_MAXIMUM_ADA_TASKS configuration option is obsolete since RTEMS 5.1"
-#endif
-#ifdef CONFIGURE_MAXIMUM_FAKE_ADA_TASKS
- #warning "The CONFIGURE_MAXIMUM_FAKE_ADA_TASKS configuration option is obsolete since RTEMS 5.1"
-#endif
-#ifdef CONFIGURE_MAXIMUM_MRSP_SEMAPHORES
- #warning "The CONFIGURE_MAXIMUM_MRSP_SEMAPHORES configuration option is obsolete since RTEMS 5.1"
-#endif
-#ifdef CONFIGURE_MAXIMUM_POSIX_BARRIERS
- #warning "The CONFIGURE_MAXIMUM_POSIX_BARRIERS configuration option is obsolete since RTEMS 5.1"
-#endif
-#ifdef CONFIGURE_MAXIMUM_POSIX_CONDITION_VARIABLES
- #warning "The CONFIGURE_MAXIMUM_POSIX_CONDITION_VARIABLES configuration option is obsolete since RTEMS 5.1"
-#endif
-#ifdef CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUE_DESCRIPTORS
- #warning "The CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUE_DESCRIPTORS configuration option is obsolete since RTEMS 5.1"
-#endif
-#ifdef CONFIGURE_MAXIMUM_POSIX_MUTEXES
- #warning "The CONFIGURE_MAXIMUM_POSIX_MUTEXES configuration option is obsolete since RTEMS 5.1"
-#endif
-#ifdef CONFIGURE_MAXIMUM_POSIX_RWLOCKS
- #warning "The CONFIGURE_MAXIMUM_POSIX_RWLOCKS configuration option is obsolete since RTEMS 5.1"
-#endif
-#ifdef CONFIGURE_MAXIMUM_POSIX_SPINLOCKS
- #warning "The CONFIGURE_MAXIMUM_POSIX_SPINLOCKS configuration option is obsolete since RTEMS 5.1"
-#endif
-#ifdef CONFIGURE_MAXIMUM_PTYS
- #warning "The CONFIGURE_MAXIMUM_PTYS configuration option is obsolete since RTEMS 5.1"
-#endif
-#ifdef CONFIGURE_POSIX_HAS_OWN_INIT_THREAD_TABLE
- #warning "The CONFIGURE_POSIX_HAS_OWN_INIT_THREAD_TABLE configuration option is obsolete since RTEMS 5.1"
-#endif
-#ifdef CONFIGURE_TERMIOS_DISABLED
- #warning "The CONFIGURE_TERMIOS_DISABLED configuration option is obsolete since RTEMS 5.1"
-#endif
* POSIX Key pair shouldn't be less than POSIX Key, which is highly
* likely to be error.
@@ -2970,21 +2821,5 @@ struct _reent *__getreent(void)
#error "IMFS Memfile block size must be a power of 2 between 16 and 512"
#endif
-#ifdef CONFIGURE_ENABLE_GO
- #warning "The CONFIGURE_ENABLE_GO configuration option is obsolete since RTEMS 5.1"
-#endif
-#ifdef CONFIGURE_GNAT_RTEMS
- #warning "The CONFIGURE_GNAT_RTEMS configuration option is obsolete since RTEMS 5.1"
-#endif
-#ifdef CONFIGURE_MAXIMUM_GOROUTINES
- #warning "The CONFIGURE_MAXIMUM_GOROUTINES configuration option is obsolete since RTEMS 5.1"
-#endif
-#ifdef CONFIGURE_MAXIMUM_GO_CHANNELS
- #warning "The CONFIGURE_MAXIMUM_GO_CHANNELS configuration option is obsolete since RTEMS 5.1"
-#endif
#endif
/* end of include file */
diff --git a/cpukit/include/rtems/confdefs/obsolete.h b/cpukit/include/rtems/confdefs/obsolete.h
new file mode 100644
index 0000000000..2020f62213
--- /dev/null
+++ b/cpukit/include/rtems/confdefs/obsolete.h
@@ -0,0 +1,234 @@
+ * SPDX-License-Identifier: BSD-2-Clause
+ * Copyright (C) 2017, 2020 embedded brains GmbH (http://www.embedded-brains.de)
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+ * @file
+ * @ingroup RTEMSApplicationConfiguration
+ * @brief Evaluate Obsolete Configuration Options
+#ifndef _RTEMS_CONFDEFS_OBSOLETE_H
+#define _RTEMS_CONFDEFS_OBSOLETE_H
+#ifndef __CONFIGURATION_TEMPLATE_h
+#error "Do not include this file directly, use <rtems/confdefs.h> instead"
+#endif
+#ifdef CONFIGURE_INIT
+ * Please keep the list of obsolete configuration options alphabetically sorted.
+ * Use #warning for renamed options and define the new option accordingly.
+ * Use #warning for obsolete options which are now superfluous, e.g. because
+ * the objects are now self-contained.
+ * Use #error for options which require now a different configuration approach,
+ * e.g. options for an own configuration table.
+ * Mention the RTEMS release which obsoleted the configuration option in the
+ * message.
+#ifdef CONFIGURE_BDBUF_BUFFER_SIZE
+ #error "The CONFIGURE_BDBUF_BUFFER_SIZE configuration option is obsolete since RTEMS 4.10.0"
+#endif
+#ifdef CONFIGURE_BDBUF_BUFFER_COUNT
+ #error "The CONFIGURE_BDBUF_BUFFER_COUNT configuration option is obsolete since RTEMS 4.10.0"
+#endif
+#ifdef CONFIGURE_ENABLE_GO
+ #warning "The CONFIGURE_ENABLE_GO configuration option is obsolete since RTEMS 5.1"
+#endif
+#ifdef CONFIGURE_GNAT_RTEMS
+ #warning "The CONFIGURE_GNAT_RTEMS configuration option is obsolete since RTEMS 5.1"
+#endif
+#ifdef CONFIGURE_HAS_OWN_CONFIGURATION_TABLE
+ #error "The CONFIGURE_HAS_OWN_CONFIGURATION_TABLE configuration option is obsolete since RTEMS 5.1"
+#endif
+#ifdef CONFIGURE_HAS_OWN_BDBUF_TABLE
+ #error "The CONFIGURE_HAS_BDBUF_TABLE configuration option is obsolete since RTEMS 4.10.0"
+#endif
+#ifdef CONFIGURE_HAS_OWN_DEVICE_DRIVER_TABLE
+ #error "The CONFIGURE_HAS_OWN_DEVICE_DRIVER_TABLE configuration option is obsolete since RTEMS 5.1"
+#endif
+#ifdef CONFIGURE_HAS_OWN_FILESYSTEM_TABLE
+ #error "The CONFIGURE_HAS_OWN_FILESYSTEM_TABLE configuration option is obsolete since RTEMS 5.1"
+#endif
+#ifdef CONFIGURE_HAS_OWN_INIT_TABLE
+ #error "The CONFIGURE_HAS_OWN_INIT_TABLE configuration option is obsolete since RTEMS 5.1"
+#endif
+#ifdef CONFIGURE_HAS_OWN_MOUNT_TABLE
+ #error "The CONFIGURE_HAS_OWN_MOUNT_TABLE configuration option is obsolete since RTEMS 5.1"
+#endif
+#ifdef CONFIGURE_HAS_OWN_MULTIPROCESSING_TABLE
+#endif
+#ifdef CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS
+ #warning "CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS has been renamed to CONFIGURE_MAXIMUM_FILE_DESCRIPTORS since RTEMS 5.1"
+ #define CONFIGURE_MAXIMUM_FILE_DESCRIPTORS CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS
+#endif
+#ifdef CONFIGURE_MAXIMUM_ADA_TASKS
+ #warning "The CONFIGURE_MAXIMUM_ADA_TASKS configuration option is obsolete since RTEMS 5.1"
+#endif
+#ifdef CONFIGURE_MAXIMUM_FAKE_ADA_TASKS
+ #warning "The CONFIGURE_MAXIMUM_FAKE_ADA_TASKS configuration option is obsolete since RTEMS 5.1"
+#endif
+#ifdef CONFIGURE_MAXIMUM_FIFOS
+ #warning "CONFIGURE_MAXIMUM_FIFOS is obsolete since RTEMS 5.1; use CONFIGURE_IMFS_ENABLE_MKFIFO instead"
+ #if CONFIGURE_MAXIMUM_FIFOS > 0
+ #define CONFIGURE_IMFS_ENABLE_MKFIFO
+ #endif
+#endif
+#ifdef CONFIGURE_MAXIMUM_GOROUTINES
+ #warning "The CONFIGURE_MAXIMUM_GOROUTINES configuration option is obsolete since RTEMS 5.1"
+#endif
+#ifdef CONFIGURE_MAXIMUM_GO_CHANNELS
+ #warning "The CONFIGURE_MAXIMUM_GO_CHANNELS configuration option is obsolete since RTEMS 5.1"
+#endif
+#ifdef CONFIGURE_MAXIMUM_MRSP_SEMAPHORES
+ #warning "The CONFIGURE_MAXIMUM_MRSP_SEMAPHORES configuration option is obsolete since RTEMS 5.1"
+#endif
+#ifdef CONFIGURE_MAXIMUM_PIPES
+ #warning "CONFIGURE_MAXIMUM_PIPES is obsolete since RTEMS 5.1; use CONFIGURE_IMFS_ENABLE_MKFIFO instead"
+ #if CONFIGURE_MAXIMUM_PIPES > 0
+ #endif
+#endif
+#ifdef CONFIGURE_MAXIMUM_POSIX_BARRIERS
+ #warning "The CONFIGURE_MAXIMUM_POSIX_BARRIERS configuration option is obsolete since RTEMS 5.1"
+#endif
+#ifdef CONFIGURE_MAXIMUM_POSIX_CONDITION_VARIABLES
+ #warning "The CONFIGURE_MAXIMUM_POSIX_CONDITION_VARIABLES configuration option is obsolete since RTEMS 5.1"
+#endif
+#ifdef CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUE_DESCRIPTORS
+ #warning "The CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUE_DESCRIPTORS configuration option is obsolete since RTEMS 5.1"
+#endif
+#ifdef CONFIGURE_MAXIMUM_POSIX_MUTEXES
+ #warning "The CONFIGURE_MAXIMUM_POSIX_MUTEXES configuration option is obsolete since RTEMS 5.1"
+#endif
+#ifdef CONFIGURE_MAXIMUM_POSIX_RWLOCKS
+ #warning "The CONFIGURE_MAXIMUM_POSIX_RWLOCKS configuration option is obsolete since RTEMS 5.1"
+#endif
+#ifdef CONFIGURE_MAXIMUM_POSIX_SPINLOCKS
+ #warning "The CONFIGURE_MAXIMUM_POSIX_SPINLOCKS configuration option is obsolete since RTEMS 5.1"
+#endif
+#ifdef CONFIGURE_MAXIMUM_PTYS
+ #warning "The CONFIGURE_MAXIMUM_PTYS configuration option is obsolete since RTEMS 5.1"
+#endif
+#ifdef CONFIGURE_NUMBER_OF_TERMIOS_PORTS
+ #warning "The CONFIGURE_NUMBER_OF_TERMIOS_PORTS configuration option is obsolete since RTEMS 5.1"
+#endif
+#ifdef CONFIGURE_POSIX_HAS_OWN_INIT_THREAD_TABLE
+ #error "The CONFIGURE_POSIX_HAS_OWN_INIT_THREAD_TABLE configuration option is obsolete since RTEMS 5.1"
+#endif
+#ifdef CONFIGURE_SCHEDULER_CONTEXT
+ #warning "CONFIGURE_SCHEDULER_CONTEXT has been renamed to CONFIGURE_SCHEDULER since RTEMS 5.1"
+ #define CONFIGURE_SCHEDULER CONFIGURE_SCHEDULER_CONTEXT
+#endif
+#ifdef CONFIGURE_SCHEDULER_CONTROLS
+ #warning "CONFIGURE_SCHEDULER_CONTROLS has been renamed to CONFIGURE_SCHEDULER_TABLE_ENTRIES since RTEMS 5.1"
+ #define CONFIGURE_SCHEDULER_TABLE_ENTRIES CONFIGURE_SCHEDULER_CONTROLS
+#endif
+#ifdef CONFIGURE_SMP_APPLICATION
+ #warning "CONFIGURE_SMP_APPLICATION is obsolete since RTEMS 5.1"
+#endif
+#ifdef CONFIGURE_SMP_MAXIMUM_PROCESSORS
+ #warning "CONFIGURE_SMP_MAXIMUM_PROCESSORS has been renamed to CONFIGURE_MAXIMUM_PROCESSORS since RTEMS 5.1"
+ #define CONFIGURE_MAXIMUM_PROCESSORS CONFIGURE_SMP_MAXIMUM_PROCESSORS
+#endif
+#ifdef CONFIGURE_SMP_SCHEDULER_ASSIGNMENTS
+ #warning "CONFIGURE_SMP_SCHEDULER_ASSIGNMENTS has been renamed to CONFIGURE_SCHEDULER_ASSIGNMENTS since RTEMS 5.1"
+ #define CONFIGURE_SCHEDULER_ASSIGNMENTS CONFIGURE_SMP_SCHEDULER_ASSIGNMENTS
+#endif
+#ifdef CONFIGURE_TERMIOS_DISABLED
+ #warning "The CONFIGURE_TERMIOS_DISABLED configuration option is obsolete since RTEMS 5.1"
+#endif
+#ifdef CONFIGURE_TEST_NEEDS_CLOCK_DRIVER
+ #error "The CONFIGURE_TEST_NEEDS_CLOCK_DRIVER configuration option is obsolete since at least RTEMS 4.5.0"
+#endif
+#ifdef CONFIGURE_TEST_NEEDS_CONSOLE_DRIVER
+ #error "The CONFIGURE_TEST_NEEDS_CONSOLE_DRIVER configuration option is obsolete at least RTEMS 4.5.0"
+#endif
+#ifdef CONFIGURE_TEST_NEEDS_RTC_DRIVER
+ #error "The CONFIGURE_TEST_NEEDS_RTC_DRIVER configuration option is obsolete at least RTEMS 4.5.0"
+#endif
+#ifdef CONFIGURE_TEST_NEEDS_STUB_DRIVER
+ #error "The CONFIGURE_TEST_NEEDS_STUB_DRIVER configuration option is obsolete at least RTEMS 4.5.0"
+#endif
+#ifdef CONFIGURE_TEST_NEEDS_TIMER_DRIVER
+ #error "The CONFIGURE_TEST_NEEDS_TIMER_DRIVER configuration option is obsolete at least RTEMS 4.5.0"
+#endif
+#ifdef STACK_CHECKER_ON
+ #warning "STACK_CHECKER_ON has been renamed to CONFIGURE_STACK_CHECKER_ENABLED since RTEMS 4.10.0"
+ #define CONFIGURE_STACK_CHECKER_ENABLED
+#endif
+#endif /* CONFIGURE_INIT */
+#endif /* _RTEMS_CONFDEFS_OBSOLETE_H */
2.16.4
