[PATCH v2 31/44] config: Add <rtems/confdefs/mcpi.h>
Sebastian Huber
Fri Feb 21 10:52:43 UTC 2020
Remove all comments and copyrightable content from the moved content.
Use BSD-2-Clause license for new file.
Update #3053.
Update #3875.
cpukit/headers.am | 1 +
cpukit/include/rtems/confdefs.h | 116 +--------------------------
cpukit/include/rtems/confdefs/mpci.h | 147 +++++++++++++++++++++++++++++++++++
3 files changed, 149 insertions(+), 115 deletions(-)
create mode 100644 cpukit/include/rtems/confdefs/mpci.h
diff --git a/cpukit/headers.am b/cpukit/headers.am
index 84e9523718..20059a7909 100644
--- a/cpukit/headers.am
+++ b/cpukit/headers.am
@@ -188,6 +188,7 @@ include_rtems_confdefs_HEADERS += include/rtems/confdefs/bsp.h
include_rtems_confdefs_HEADERS += include/rtems/confdefs/libio.h
include_rtems_confdefs_HEADERS += include/rtems/confdefs/libpci.h
include_rtems_confdefs_HEADERS += include/rtems/confdefs/malloc.h
+include_rtems_confdefs_HEADERS += include/rtems/confdefs/mpci.h
include_rtems_confdefs_HEADERS += include/rtems/confdefs/obsolete.h
include_rtems_confdefs_HEADERS += include/rtems/confdefs/percpu.h
include_rtems_confdefs_HEADERS += include/rtems/confdefs/scheduler.h
diff --git a/cpukit/include/rtems/confdefs.h b/cpukit/include/rtems/confdefs.h
index 4f1ba45de8..a28e277311 100644
--- a/cpukit/include/rtems/confdefs.h
+++ b/cpukit/include/rtems/confdefs.h
@@ -54,6 +54,7 @@
#include <rtems/confdefs/libio.h>
#include <rtems/confdefs/libpci.h>
#include <rtems/confdefs/malloc.h>
+#include <rtems/confdefs/mpci.h>
#include <rtems/confdefs/percpu.h>
#include <rtems/confdefs/scheduler.h>
@@ -426,108 +427,6 @@ extern "C" {
#endif
/**@}*/ /* end of Device Driver Table Configuration */
- * @defgroup ConfigurationMultiprocessing Multiprocessing Configuration
- * @addtogroup Configuration
- * This module contains the parameters related to the Multiprocessing
- * configuration of RTEMS.
- * In a single processor or SMP configuration, only two parameters are
- * needed and they are defaulted. The user should not have to specify
- * any parameters.
- * This defines the extra stack space required for the MPCI server thread.
-#ifndef CONFIGURE_EXTRA_MPCI_RECEIVE_SERVER_STACK
- #define CONFIGURE_EXTRA_MPCI_RECEIVE_SERVER_STACK 0
-#endif
-#if defined(RTEMS_MULTIPROCESSING)
- * Default Multiprocessing Configuration Table. The defaults are
- * appropriate for most of the RTEMS Multiprocessor Test Suite. Each
- * value may be overridden within each test to customize the environment.
- #ifdef CONFIGURE_MP_APPLICATION
- #ifndef CONFIGURE_MP_NODE_NUMBER
- #define CONFIGURE_MP_NODE_NUMBER NODE_NUMBER
- #endif
- #ifndef CONFIGURE_MP_MAXIMUM_NODES
- #define CONFIGURE_MP_MAXIMUM_NODES 2
- #endif
- #ifndef CONFIGURE_MP_MAXIMUM_GLOBAL_OBJECTS
- #define CONFIGURE_MP_MAXIMUM_GLOBAL_OBJECTS 32
- #endif
- #ifndef CONFIGURE_MP_MAXIMUM_PROXIES
- #define CONFIGURE_MP_MAXIMUM_PROXIES 32
- #endif
- #ifndef CONFIGURE_MP_MPCI_TABLE_POINTER
- #include <mpci.h>
- #define CONFIGURE_MP_MPCI_TABLE_POINTER &MPCI_table
- #endif
- #ifdef CONFIGURE_INIT
- #if CONFIGURE_MP_NODE_NUMBER < 1
- #error "CONFIGURE_MP_NODE_NUMBER must be greater than or equal to one"
- #endif
- #if CONFIGURE_MP_NODE_NUMBER > CONFIGURE_MP_MAXIMUM_NODES
- #error "CONFIGURE_MP_NODE_NUMBER must be less than or equal to CONFIGURE_MP_MAXIMUM_NODES"
- #endif
- Objects_MP_Control _Objects_MP_Controls[
- CONFIGURE_MP_MAXIMUM_GLOBAL_OBJECTS
- struct Thread_Configured_proxy_control {
- Thread_Proxy_control Control;
- Thread_queue_Configured_heads Heads;
- static Thread_Configured_proxy_control _Thread_MP_Configured_proxies[
- CONFIGURE_MP_MAXIMUM_PROXIES
- Thread_Configured_proxy_control * const _Thread_MP_Proxies =
- &_Thread_MP_Configured_proxies[ 0 ];
- const MPCI_Configuration _MPCI_Configuration = {
- CONFIGURE_MP_NODE_NUMBER, /* local node number */
- CONFIGURE_MP_MAXIMUM_NODES, /* maximum # nodes */
- CONFIGURE_MP_MAXIMUM_GLOBAL_OBJECTS, /* maximum # global objects */
- CONFIGURE_MP_MAXIMUM_PROXIES, /* maximum # proxies */
- CONFIGURE_EXTRA_MPCI_RECEIVE_SERVER_STACK, /* MPCI stack > minimum */
- CONFIGURE_MP_MPCI_TABLE_POINTER /* ptr to MPCI config table */
- char _MPCI_Receive_server_stack[
- CONFIGURE_MINIMUM_TASK_STACK_SIZE
- + CONFIGURE_EXTRA_MPCI_RECEIVE_SERVER_STACK
- + CPU_MPCI_RECEIVE_SERVER_EXTRA_STACK
- + CPU_ALL_TASKS_ARE_FP * CONTEXT_FP_SIZE
- ] RTEMS_ALIGNED( CPU_INTERRUPT_STACK_ALIGNMENT )
- RTEMS_SECTION( ".rtemsstack.mpci" );
- #endif
- #define _CONFIGURE_MPCI_RECEIVE_SERVER_COUNT 1
- #else
- #define _CONFIGURE_MPCI_RECEIVE_SERVER_COUNT 0
- #endif /* CONFIGURE_MP_APPLICATION */
-#else
-#endif /* RTEMS_MULTIPROCESSING */
-/**@}*/ /* end of Multiprocessing Configuration */
* This macro specifies that the user wants to use unlimited objects for any
* classic or posix objects that have not already been given resource limits.
@@ -1090,10 +989,6 @@ struct _reent *__getreent(void)
#define _CONFIGURE_TASKS_STACK 0
#define _CONFIGURE_POSIX_THREADS_STACK 0
-#if CONFIGURE_EXTRA_MPCI_RECEIVE_SERVER_STACK != 0
- #error "CONFIGURE_EXECUTIVE_RAM_SIZE defined with request for CONFIGURE_EXTRA_MPCI_RECEIVE_SERVER_STACK"
-#endif
#if CONFIGURE_EXTRA_TASK_STACKS != 0
#error "CONFIGURE_EXECUTIVE_RAM_SIZE defined with request for CONFIGURE_EXTRA_TASK_STACKS"
#endif
@@ -1524,15 +1419,6 @@ struct _reent *__getreent(void)
#endif
#endif
- * If the user is trying to configure a multiprocessing application and
- * RTEMS was not configured and built multiprocessing, then error out.
-#if defined(CONFIGURE_MP_APPLICATION) && \
- !defined(RTEMS_MULTIPROCESSING)
-#error "CONFIGURATION ERROR: RTEMS not configured for multiprocessing!!"
-#endif
#if !defined(RTEMS_SCHEDSIM)
* You must either explicitly include or exclude the clock driver.
diff --git a/cpukit/include/rtems/confdefs/mpci.h b/cpukit/include/rtems/confdefs/mpci.h
new file mode 100644
index 0000000000..053439bb2e
--- /dev/null
+++ b/cpukit/include/rtems/confdefs/mpci.h
@@ -0,0 +1,147 @@
+ * SPDX-License-Identifier: BSD-2-Clause
+ * Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+ * @file
+ * @ingroup RTEMSApplicationConfiguration
+ * @brief Evaluate MPCI Configuration Options
+ * This header file defines _CONFIGURE_MPCI_RECEIVE_SERVER_COUNT for use by
+ * other configuration header files.
+#ifndef _RTEMS_CONFDEFS_MPCI_H
+#define _RTEMS_CONFDEFS_MPCI_H
+#ifndef __CONFIGURATION_TEMPLATE_h
+#error "Do not include this file directly, use <rtems/confdefs.h> instead"
+#endif
+#ifdef CONFIGURE_INIT
+#ifdef RTEMS_MULTIPROCESSING
+#include <mpci.h>
+#ifdef CONFIGURE_MP_APPLICATION
+#ifndef CONFIGURE_EXTRA_MPCI_RECEIVE_SERVER_STACK
+ #define CONFIGURE_EXTRA_MPCI_RECEIVE_SERVER_STACK 0
+#endif
+#ifndef CONFIGURE_MP_NODE_NUMBER
+ #define CONFIGURE_MP_NODE_NUMBER NODE_NUMBER
+#endif
+#ifndef CONFIGURE_MP_MAXIMUM_NODES
+ #define CONFIGURE_MP_MAXIMUM_NODES 2
+#endif
+#ifndef CONFIGURE_MP_MAXIMUM_GLOBAL_OBJECTS
+ #define CONFIGURE_MP_MAXIMUM_GLOBAL_OBJECTS 32
+#endif
+#ifndef CONFIGURE_MP_MAXIMUM_PROXIES
+ #define CONFIGURE_MP_MAXIMUM_PROXIES 32
+#endif
+#ifndef CONFIGURE_MP_MPCI_TABLE_POINTER
+ #define CONFIGURE_MP_MPCI_TABLE_POINTER &MPCI_table
+#endif
+#if CONFIGURE_MP_NODE_NUMBER < 1
+ #error "CONFIGURE_MP_NODE_NUMBER must be greater than or equal to one"
+#endif
+#if CONFIGURE_MP_NODE_NUMBER > CONFIGURE_MP_MAXIMUM_NODES
+ #error "CONFIGURE_MP_NODE_NUMBER must be less than or equal to CONFIGURE_MP_MAXIMUM_NODES"
+#endif
+#define _CONFIGURE_MPCI_RECEIVE_SERVER_COUNT 1
+#ifdef __cplusplus
+extern "C" {
+#endif
+Objects_MP_Control _Objects_MP_Controls[
+ CONFIGURE_MP_MAXIMUM_GLOBAL_OBJECTS
+struct Thread_Configured_proxy_control {
+ Thread_Proxy_control Control;
+ Thread_queue_Configured_heads Heads;
+static Thread_Configured_proxy_control _Thread_MP_Configured_proxies[
+ CONFIGURE_MP_MAXIMUM_PROXIES
+Thread_Configured_proxy_control * const _Thread_MP_Proxies =
+ &_Thread_MP_Configured_proxies[ 0 ];
+const MPCI_Configuration _MPCI_Configuration = {
+ CONFIGURE_MP_NODE_NUMBER,
+ CONFIGURE_MP_MAXIMUM_NODES,
+ CONFIGURE_MP_MAXIMUM_GLOBAL_OBJECTS,
+ CONFIGURE_MP_MAXIMUM_PROXIES,
+ CONFIGURE_EXTRA_MPCI_RECEIVE_SERVER_STACK,
+ CONFIGURE_MP_MPCI_TABLE_POINTER
+char _MPCI_Receive_server_stack[
+ CONFIGURE_MINIMUM_TASK_STACK_SIZE
+ + CONFIGURE_EXTRA_MPCI_RECEIVE_SERVER_STACK
+ + CPU_MPCI_RECEIVE_SERVER_EXTRA_STACK
+ + CPU_ALL_TASKS_ARE_FP * CONTEXT_FP_SIZE
+] RTEMS_ALIGNED( CPU_INTERRUPT_STACK_ALIGNMENT )
+RTEMS_SECTION( ".rtemsstack.mpci" );
+#ifdef __cplusplus
+#endif
+#else /* CONFIGURE_MP_APPLICATION */
+#define _CONFIGURE_MPCI_RECEIVE_SERVER_COUNT 0
+#endif /* CONFIGURE_MP_APPLICATION */
+#else /* RTEMS_MULTIPROCESSING */
+ #error "CONFIGURE_MP_APPLICATION must not be defined if multiprocessing is disabled"
+#endif
+#endif /* RTEMS_MULTIPROCESSING */
+#endif /* CONFIGURE_INIT */
+#endif /* _RTEMS_CONFDEFS_MPCI_H */
2.16.4
