[PATCH v2 30/44] config: Add <rtems/confdefs/malloc.h>
Sebastian Huber
Fri Feb 21 10:52:42 UTC 2020
Remove all comments and copyrightable content from the moved content.
Use BSD-2-Clause license for new file.
Move the default configuration to library files so that application
configurations do not include the definitions for the default case.
Update #3053.
Update #3875.
cpukit/Makefile.am | 2 +
cpukit/headers.am | 1 +
cpukit/include/rtems/confdefs.h | 40 +---------------
cpukit/include/rtems/confdefs/malloc.h | 72 ++++++++++++++++++++++++++++
cpukit/libcsupport/src/mallocdirtydefault.c | 34 +++++++++++++
cpukit/libcsupport/src/mallocextenddefault.c | 35 ++++++++++++++
6 files changed, 145 insertions(+), 39 deletions(-)
create mode 100644 cpukit/include/rtems/confdefs/malloc.h
create mode 100644 cpukit/libcsupport/src/mallocdirtydefault.c
create mode 100644 cpukit/libcsupport/src/mallocextenddefault.c
diff --git a/cpukit/Makefile.am b/cpukit/Makefile.am
index 189f525b7d..85b427848a 100644
--- a/cpukit/Makefile.am
+++ b/cpukit/Makefile.am
@@ -171,6 +171,8 @@ librtemscpu_a_SOURCES += libcsupport/src/lstat.c
librtemscpu_a_SOURCES += libcsupport/src/malloc.c
librtemscpu_a_SOURCES += libcsupport/src/malloc_deferred.c
librtemscpu_a_SOURCES += libcsupport/src/malloc_dirtier.c
+librtemscpu_a_SOURCES += libcsupport/src/mallocdirtydefault.c
+librtemscpu_a_SOURCES += libcsupport/src/mallocextenddefault.c
librtemscpu_a_SOURCES += libcsupport/src/mallocfreespace.c
librtemscpu_a_SOURCES += libcsupport/src/mallocgetheapptr.c
librtemscpu_a_SOURCES += libcsupport/src/mallocinfo.c
diff --git a/cpukit/headers.am b/cpukit/headers.am
index 10014ee489..84e9523718 100644
--- a/cpukit/headers.am
+++ b/cpukit/headers.am
@@ -187,6 +187,7 @@ include_rtems_confdefs_HEADERS += include/rtems/confdefs/bdbuf.h
include_rtems_confdefs_HEADERS += include/rtems/confdefs/bsp.h
include_rtems_confdefs_HEADERS += include/rtems/confdefs/libio.h
include_rtems_confdefs_HEADERS += include/rtems/confdefs/libpci.h
+include_rtems_confdefs_HEADERS += include/rtems/confdefs/malloc.h
include_rtems_confdefs_HEADERS += include/rtems/confdefs/obsolete.h
include_rtems_confdefs_HEADERS += include/rtems/confdefs/percpu.h
include_rtems_confdefs_HEADERS += include/rtems/confdefs/scheduler.h
diff --git a/cpukit/include/rtems/confdefs.h b/cpukit/include/rtems/confdefs.h
index 15e921629b..4f1ba45de8 100644
--- a/cpukit/include/rtems/confdefs.h
+++ b/cpukit/include/rtems/confdefs.h
@@ -53,6 +53,7 @@
#include <rtems/confdefs/bdbuf.h>
#include <rtems/confdefs/libio.h>
#include <rtems/confdefs/libpci.h>
+#include <rtems/confdefs/malloc.h>
#include <rtems/confdefs/percpu.h>
#include <rtems/confdefs/scheduler.h>
@@ -103,45 +104,6 @@ extern "C" {
#undef RTEMS_NEWLIB
#endif
- * @defgroup ConfigurationMalloc RTEMS Malloc configuration
- * This module contains parameters related to configuration of the RTEMS
- * Malloc implementation.
-#include <rtems/malloc.h>
-#ifdef CONFIGURE_INIT
- * This configures the sbrk() support for the malloc family.
- * By default it is assumed that the BSP provides all available
- * RAM to the malloc family implementation so sbrk()'ing to get
- * more memory would always fail anyway.
- const rtems_heap_extend_handler rtems_malloc_extend_handler =
- #ifdef CONFIGURE_MALLOC_BSP_SUPPORTS_SBRK
- rtems_heap_extend_via_sbrk;
- #else
- rtems_heap_null_extend;
- #endif
-#endif
- * This configures the malloc family plugin which dirties memory
- * allocated. This is helpful for finding unitialized data structure
- * problems.
- rtems_malloc_dirtier_t rtems_malloc_dirty_helper =
- #if defined(CONFIGURE_MALLOC_DIRTY)
- rtems_malloc_dirty_memory;
- #else
- NULL;
- #endif
-#endif
-/**@}*/ /* end of Malloc Configuration */
* @defgroup ConfigurationHelpers Configuration Helpers
diff --git a/cpukit/include/rtems/confdefs/malloc.h b/cpukit/include/rtems/confdefs/malloc.h
new file mode 100644
index 0000000000..78cca6f3e3
--- /dev/null
+++ b/cpukit/include/rtems/confdefs/malloc.h
@@ -0,0 +1,72 @@
+ * SPDX-License-Identifier: BSD-2-Clause
+ * Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+ * @file
+ * @ingroup RTEMSApplicationConfiguration
+ * @brief Evaluate C Program Heap Configuration Options
+#ifndef _RTEMS_CONFDEFS_MALLOC_H
+#define _RTEMS_CONFDEFS_MALLOC_H
+#ifndef __CONFIGURATION_TEMPLATE_h
+#error "Do not include this file directly, use <rtems/confdefs.h> instead"
+#endif
+#ifdef CONFIGURE_INIT
+#include <rtems/confdefs/bsp.h>
+#if defined(CONFIGURE_MALLOC_BSP_SUPPORTS_SBRK) \
+ || defined(CONFIGURE_MALLOC_DIRTY)
+#include <rtems/malloc.h>
+#endif
+#ifdef __cplusplus
+extern "C" {
+#endif
+#ifdef CONFIGURE_MALLOC_BSP_SUPPORTS_SBRK
+const rtems_heap_extend_handler rtems_malloc_extend_handler =
+ rtems_heap_extend_via_sbrk;
+#endif
+#ifdef CONFIGURE_MALLOC_DIRTY
+rtems_malloc_dirtier_t rtems_malloc_dirty_helper =
+ rtems_malloc_dirty_memory;
+#endif
+#ifdef __cplusplus
+#endif
+#endif /* CONFIGURE_INIT */
+#endif /* _RTEMS_CONFDEFS_MALLOC_H */
diff --git a/cpukit/libcsupport/src/mallocdirtydefault.c b/cpukit/libcsupport/src/mallocdirtydefault.c
index 0000000000..aea2a93edd
--- /dev/null
+++ b/cpukit/libcsupport/src/mallocdirtydefault.c
@@ -0,0 +1,34 @@
+ * are met:
+#if HAVE_CONFIG_H
+#include "config.h"
+#endif
+rtems_malloc_dirtier_t rtems_malloc_dirty_helper = NULL;
diff --git a/cpukit/libcsupport/src/mallocextenddefault.c b/cpukit/libcsupport/src/mallocextenddefault.c
index 0000000000..a6741d834d
--- /dev/null
+++ b/cpukit/libcsupport/src/mallocextenddefault.c
@@ -0,0 +1,35 @@
+ * are met:
+#if HAVE_CONFIG_H
+#endif
+ rtems_heap_null_extend;
2.16.4
