[PATCH v2 41/44] config: Add <rtems/confdefs/objectsclassic.h>
Fri Feb 21 10:52:53 UTC 2020
Remove all comments and copyrightable content from the moved content.
Use BSD-2-Clause license for new file.
Update #3053.
Update #3875.
 cpukit/headers.am                              |   1 +
 cpukit/include/rtems/confdefs.h                | 114 +---------------------
 cpukit/include/rtems/confdefs/objectsclassic.h | 127 +++++++++++++++++++++++++
 3 files changed, 129 insertions(+), 113 deletions(-)
 create mode 100644 cpukit/include/rtems/confdefs/objectsclassic.h
diff --git a/cpukit/headers.am b/cpukit/headers.am
index 2a7e5a8116..d057c6e7d2 100644
--- a/cpukit/headers.am
+++ b/cpukit/headers.am
@@ -196,6 +196,7 @@ include_rtems_confdefs_HEADERS += include/rtems/confdefs/libpci.h
 include_rtems_confdefs_HEADERS += include/rtems/confdefs/malloc.h
 include_rtems_confdefs_HEADERS += include/rtems/confdefs/mpci.h
 include_rtems_confdefs_HEADERS += include/rtems/confdefs/newlib.h
+include_rtems_confdefs_HEADERS += include/rtems/confdefs/objectsclassic.h
 include_rtems_confdefs_HEADERS += include/rtems/confdefs/obsolete.h
 include_rtems_confdefs_HEADERS += include/rtems/confdefs/percpu.h
 include_rtems_confdefs_HEADERS += include/rtems/confdefs/scheduler.h
diff --git a/cpukit/include/rtems/confdefs.h b/cpukit/include/rtems/confdefs.h
index 82b6f11774..ef1200419b 100644
--- a/cpukit/include/rtems/confdefs.h
+++ b/cpukit/include/rtems/confdefs.h
@@ -30,14 +30,6 @@
 #include <rtems/score/apimutex.h>
 #include <rtems/score/context.h>
-#include <rtems/rtems/barrierdata.h>
-#include <rtems/rtems/dpmemdata.h>
-#include <rtems/rtems/messagedata.h>
-#include <rtems/rtems/partdata.h>
-#include <rtems/rtems/ratemondata.h>
-#include <rtems/rtems/regiondata.h>
-#include <rtems/rtems/semdata.h>
-#include <rtems/rtems/timerdata.h>
 #include <rtems/posix/key.h>
 #include <rtems/posix/mqueue.h>
 #include <rtems/posix/psignal.h>
@@ -58,6 +50,7 @@
 #include <rtems/confdefs/malloc.h>
 #include <rtems/confdefs/mpci.h>
 #include <rtems/confdefs/newlib.h>
+#include <rtems/confdefs/objectsclassic.h>
 #include <rtems/confdefs/percpu.h>
 #include <rtems/confdefs/scheduler.h>
 #include <rtems/confdefs/threads.h>
@@ -146,76 +139,6 @@ extern "C" {
 #endif
- * @defgroup ConfigurationClassicAPI Classic API Configuration
- * @ingroup Configuration
- * This module contains the parameters related to configuration
- * of the Classic API services.
-#ifndef CONFIGURE_MAXIMUM_TIMERS
-  /** This specifies the maximum number of Classic API timers. */
-  #define CONFIGURE_MAXIMUM_TIMERS             0
-#endif
-#ifndef CONFIGURE_MAXIMUM_SEMAPHORES
-  /** This specifies the maximum number of Classic API semaphores. */
-  #define CONFIGURE_MAXIMUM_SEMAPHORES                 0
-#endif
-#ifndef CONFIGURE_MAXIMUM_MESSAGE_QUEUES
-   * This configuration parameter specifies the maximum number of
-   * Classic API Message Queues.
-  #define CONFIGURE_MAXIMUM_MESSAGE_QUEUES             0
-#endif
-#ifndef CONFIGURE_MAXIMUM_PARTITIONS
-   * Classic API Partitions.
-  #define CONFIGURE_MAXIMUM_PARTITIONS                 0
-#endif
-#ifndef CONFIGURE_MAXIMUM_REGIONS
-   * Classic API Regions.
-  #define CONFIGURE_MAXIMUM_REGIONS              0
-#endif
-#ifndef CONFIGURE_MAXIMUM_PORTS
-   * Classic API Dual-Ported Memory Ports.
-  #define CONFIGURE_MAXIMUM_PORTS            0
-#endif
-#ifndef CONFIGURE_MAXIMUM_PERIODS
-   * Classic API Rate Monotonic Periods.
-  #define CONFIGURE_MAXIMUM_PERIODS              0
-#endif
- * Classic API Barriers.
-#ifndef CONFIGURE_MAXIMUM_BARRIERS
-  #define CONFIGURE_MAXIMUM_BARRIERS               0
-#endif
-/**@}*/ /* end of Classic API Configuration */
  * @defgroup ConfigurationPOSIXAPI POSIX API Configuration Parameters
@@ -458,41 +381,6 @@ extern "C" {
 #ifdef CONFIGURE_INIT
-  #if CONFIGURE_MAXIMUM_BARRIERS > 0
-    BARRIER_INFORMATION_DEFINE( CONFIGURE_MAXIMUM_BARRIERS );
-  #endif
-  #if CONFIGURE_MAXIMUM_MESSAGE_QUEUES > 0
-    MESSAGE_QUEUE_INFORMATION_DEFINE( CONFIGURE_MAXIMUM_MESSAGE_QUEUES );
-  #endif
-  #if CONFIGURE_MAXIMUM_PARTITIONS > 0
-    PARTITION_INFORMATION_DEFINE( CONFIGURE_MAXIMUM_PARTITIONS );
-  #endif
-  #if CONFIGURE_MAXIMUM_PERIODS > 0
-    RATE_MONOTONIC_INFORMATION_DEFINE( CONFIGURE_MAXIMUM_PERIODS );
-  #endif
-  #if CONFIGURE_MAXIMUM_PORTS > 0
-    DUAL_PORTED_MEMORY_INFORMATION_DEFINE( CONFIGURE_MAXIMUM_PORTS );
-  #endif
-  #if CONFIGURE_MAXIMUM_REGIONS > 0
-    REGION_INFORMATION_DEFINE( CONFIGURE_MAXIMUM_REGIONS );
-  #endif
-  #if CONFIGURE_MAXIMUM_SEMAPHORES > 0
-    SEMAPHORE_INFORMATION_DEFINE(
-      CONFIGURE_MAXIMUM_SEMAPHORES,
-      _CONFIGURE_SCHEDULER_COUNT
-  #endif
-  #if CONFIGURE_MAXIMUM_TIMERS > 0
-    TIMER_INFORMATION_DEFINE( CONFIGURE_MAXIMUM_TIMERS );
-  #endif
   #if CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS > 0
     POSIX_Keys_Key_value_pair _POSIX_Keys_Key_value_pairs[
       rtems_resource_maximum_per_allocation(
diff --git a/cpukit/include/rtems/confdefs/objectsclassic.h b/cpukit/include/rtems/confdefs/objectsclassic.h
new file mode 100644
index 0000000000..4b14fd2c5f
--- /dev/null
+++ b/cpukit/include/rtems/confdefs/objectsclassic.h
@@ -0,0 +1,127 @@
+ * SPDX-License-Identifier: BSD-2-Clause
+ * Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
+ * are met:
+ * @file
+ * @ingroup RTEMSApplicationConfiguration
+ * @brief Evaluate Classic API Objects Configuration Options
+ * For the task objects configuration see <rtems/confdefs/threads.h>.
+#ifndef _RTEMS_CONFDEFS_OBJECTSCLASSIC_H
+#define _RTEMS_CONFDEFS_OBJECTSCLASSIC_H
+#ifndef __CONFIGURATION_TEMPLATE_h
+#error "Do not include this file directly, use <rtems/confdefs.h> instead"
+#endif
+#ifdef CONFIGURE_INIT
+#include <rtems/confdefs/unlimited.h>
+#if CONFIGURE_MAXIMUM_BARRIERS > 0
+  #include <rtems/rtems/barrierdata.h>
+#endif
+#if CONFIGURE_MAXIMUM_PORTS > 0
+  #include <rtems/rtems/dpmemdata.h>
+#endif
+#if CONFIGURE_MAXIMUM_MESSAGE_QUEUES > 0
+  #include <rtems/rtems/messagedata.h>
+#endif
+#if CONFIGURE_MAXIMUM_PARTITIONS > 0
+  #include <rtems/rtems/partdata.h>
+#endif
+#if CONFIGURE_MAXIMUM_PERIODS > 0
+  #include <rtems/rtems/ratemondata.h>
+#endif
+#if CONFIGURE_MAXIMUM_REGIONS > 0
+  #include <rtems/rtems/regiondata.h>
+#endif
+#if CONFIGURE_MAXIMUM_SEMAPHORES > 0
+  #include <rtems/confdefs/scheduler.h>
+  #include <rtems/rtems/semdata.h>
+#endif
+#if CONFIGURE_MAXIMUM_TIMERS > 0
+  #include <rtems/rtems/timerdata.h>
+#endif
+#ifdef __cplusplus
+extern "C" {
+#endif
+  BARRIER_INFORMATION_DEFINE( CONFIGURE_MAXIMUM_BARRIERS );
+#endif
+  MESSAGE_QUEUE_INFORMATION_DEFINE( CONFIGURE_MAXIMUM_MESSAGE_QUEUES );
+#endif
+  PARTITION_INFORMATION_DEFINE( CONFIGURE_MAXIMUM_PARTITIONS );
+#endif
+  RATE_MONOTONIC_INFORMATION_DEFINE( CONFIGURE_MAXIMUM_PERIODS );
+#endif
+  DUAL_PORTED_MEMORY_INFORMATION_DEFINE( CONFIGURE_MAXIMUM_PORTS );
+#endif
+  REGION_INFORMATION_DEFINE( CONFIGURE_MAXIMUM_REGIONS );
+#endif
+  SEMAPHORE_INFORMATION_DEFINE(
+    CONFIGURE_MAXIMUM_SEMAPHORES,
+    _CONFIGURE_SCHEDULER_COUNT
+#endif
+  TIMER_INFORMATION_DEFINE( CONFIGURE_MAXIMUM_TIMERS );
+#endif
+#ifdef __cplusplus
+#endif
+#endif /* CONFIGURE_INIT */
+#endif /* _RTEMS_CONFDEFS_OBJECTSCLASSIC_H */
2.16.4
