[PATCH v2 42/44] config: Add <rtems/confdefs/wkspacesupport.h>
Fri Feb 21 10:52:54 UTC 2020
Remove all comments and copyrightable content from the moved content.
Use BSD-2-Clause license for new file.
Update #3053.
Update #3875.
 cpukit/headers.am                              |  1 +
 cpukit/include/rtems/confdefs.h                | 26 +----------
 cpukit/include/rtems/confdefs/wkspacesupport.h | 64 ++++++++++++++++++++++++++
 3 files changed, 66 insertions(+), 25 deletions(-)
 create mode 100644 cpukit/include/rtems/confdefs/wkspacesupport.h
diff --git a/cpukit/headers.am b/cpukit/headers.am
index d057c6e7d2..5b189a6641 100644
--- a/cpukit/headers.am
+++ b/cpukit/headers.am
@@ -202,6 +202,7 @@ include_rtems_confdefs_HEADERS += include/rtems/confdefs/percpu.h
 include_rtems_confdefs_HEADERS += include/rtems/confdefs/scheduler.h
 include_rtems_confdefs_HEADERS += include/rtems/confdefs/threads.h
 include_rtems_confdefs_HEADERS += include/rtems/confdefs/unlimited.h
+include_rtems_confdefs_HEADERS += include/rtems/confdefs/wkspacesupport.h
 include_rtems_debugger_HEADERS += include/rtems/debugger/rtems-debugger-bsp.h
 include_rtems_debugger_HEADERS += include/rtems/debugger/rtems-debugger-remote.h
 include_rtems_debugger_HEADERS += include/rtems/debugger/rtems-debugger-server.h
diff --git a/cpukit/include/rtems/confdefs.h b/cpukit/include/rtems/confdefs.h
index ef1200419b..97e5b6d9fb 100644
--- a/cpukit/include/rtems/confdefs.h
+++ b/cpukit/include/rtems/confdefs.h
@@ -54,6 +54,7 @@
 #include <rtems/confdefs/percpu.h>
 #include <rtems/confdefs/scheduler.h>
 #include <rtems/confdefs/threads.h>
+#include <rtems/confdefs/wkspacesupport.h>
 #include <limits.h>
@@ -100,31 +101,6 @@ extern "C" {
- * Zero of one returns 0 if the parameter is 0 else 1 is returned.
-#define _Configure_Zero_or_One(_number) ((_number) != 0 ? 1 : 0)
- * General helper to align up a value.
-#define _Configure_Align_up(_val, _align) \
-  (((_val) + (_align) - 1) - ((_val) + (_align) - 1) % (_align))
-#define _CONFIGURE_HEAP_MIN_BLOCK_SIZE \
-  _Configure_Align_up(sizeof(Heap_Block), CPU_HEAP_ALIGNMENT)
- * This is a helper macro used in calculations in this file.  It is used
- * to noted when an element is allocated from the RTEMS Workspace and adds
- * a factor to account for heap overhead plus an alignment factor that
- * may be applied.
-#define _Configure_From_workspace(_size) \
-  (uintptr_t) (_Configure_Zero_or_One(_size) * \
-    _Configure_Align_up(_size + HEAP_BLOCK_HEADER_SIZE, \
-      _CONFIGURE_HEAP_MIN_BLOCK_SIZE))
  * This is a helper macro used in stack space calculations in this file.  It
  * may be provided by the application in case a special task stack allocator
diff --git a/cpukit/include/rtems/confdefs/wkspacesupport.h b/cpukit/include/rtems/confdefs/wkspacesupport.h
new file mode 100644
index 0000000000..2a3def5cee
--- /dev/null
+++ b/cpukit/include/rtems/confdefs/wkspacesupport.h
@@ -0,0 +1,64 @@
+ * SPDX-License-Identifier: BSD-2-Clause
+ * Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
+ * are met:
+ * @file
+ * @ingroup RTEMSApplicationConfiguration
+ * @brief Configuration Options Workspace Support Macros
+#ifndef _RTEMS_CONFDEFS_WKSPACESUPPORT_H
+#define _RTEMS_CONFDEFS_WKSPACESUPPORT_H
+#ifndef __CONFIGURATION_TEMPLATE_h
+#error "Do not include this file directly, use <rtems/confdefs.h> instead"
+#endif
+#ifdef CONFIGURE_INIT
+#include <rtems/score/heap.h>
+#define _Configure_Zero_or_one( _number ) ( ( _number ) != 0 ? 1 : 0 )
+#define _Configure_Align_up( _val, _align ) \
+  ( ( ( _val ) + ( _align ) - 1) - ( ( _val ) + ( _align ) - 1 ) % ( _align ) )
+#define _CONFIGURE_HEAP_MIN_BLOCK_SIZE \
+  _Configure_Align_up( sizeof( Heap_Block ), CPU_HEAP_ALIGNMENT )
+#define _Configure_From_workspace( _size ) \
+  ( (uintptr_t) ( _Configure_Zero_or_one( _size ) \
+    * _Configure_Align_up( \
+       _size + HEAP_BLOCK_HEADER_SIZE, \
+      _CONFIGURE_HEAP_MIN_BLOCK_SIZE \
+#endif /* CONFIGURE_INIT */
+#endif /* _RTEMS_CONFDEFS_WKSPACESUPPORT_H */
2.16.4
