[PATCH v2 39/44] config: Add <rtems/confdefs/unlimited.h>
Fri Feb 21 10:52:51 UTC 2020
Remove all comments and copyrightable content from the moved content.
Use BSD-2-Clause license for new file.
Update #3053.
Update #3875.
 cpukit/headers.am                         |   1 +
 cpukit/include/rtems/confdefs.h           |  92 ++-----------------
 cpukit/include/rtems/confdefs/unlimited.h | 143 ++++++++++++++++++++++++++++++
 3 files changed, 149 insertions(+), 87 deletions(-)
 create mode 100644 cpukit/include/rtems/confdefs/unlimited.h
diff --git a/cpukit/headers.am b/cpukit/headers.am
index 9f2e06b870..ba6222fd4f 100644
--- a/cpukit/headers.am
+++ b/cpukit/headers.am
@@ -199,6 +199,7 @@ include_rtems_confdefs_HEADERS += include/rtems/confdefs/newlib.h
 include_rtems_confdefs_HEADERS += include/rtems/confdefs/obsolete.h
 include_rtems_confdefs_HEADERS += include/rtems/confdefs/percpu.h
 include_rtems_confdefs_HEADERS += include/rtems/confdefs/scheduler.h
+include_rtems_confdefs_HEADERS += include/rtems/confdefs/unlimited.h
 include_rtems_debugger_HEADERS += include/rtems/debugger/rtems-debugger-bsp.h
 include_rtems_debugger_HEADERS += include/rtems/debugger/rtems-debugger-remote.h
 include_rtems_debugger_HEADERS += include/rtems/debugger/rtems-debugger-server.h
diff --git a/cpukit/include/rtems/confdefs.h b/cpukit/include/rtems/confdefs.h
index e1b23ddaef..c48a2aae81 100644
--- a/cpukit/include/rtems/confdefs.h
+++ b/cpukit/include/rtems/confdefs.h
@@ -61,6 +61,7 @@
 #include <rtems/confdefs/newlib.h>
 #include <rtems/confdefs/percpu.h>
 #include <rtems/confdefs/scheduler.h>
+#include <rtems/confdefs/unlimited.h>
 #include <limits.h>
@@ -146,93 +147,6 @@ extern "C" {
 #endif
- * This macro specifies that the user wants to use unlimited objects for any
- * classic or posix objects that have not already been given resource limits.
-#if defined(CONFIGURE_UNLIMITED_OBJECTS)
-  #if !defined(CONFIGURE_UNIFIED_WORK_AREAS) && \
-     !defined(CONFIGURE_EXECUTIVE_RAM_SIZE) && \
-     !defined(CONFIGURE_MEMORY_OVERHEAD)
-     #error "CONFIGURE_UNLIMITED_OBJECTS requires a unified work area, an executive RAM size, or a defined workspace memory overhead"
-  #endif
-  #if !defined(CONFIGURE_UNLIMITED_ALLOCATION_SIZE)
-   * This macro specifies a default allocation size for when auto-extending
-   * unlimited objects if none was given by the user.
-    #define CONFIGURE_UNLIMITED_ALLOCATION_SIZE 8
-  #endif
-  #if !defined(CONFIGURE_MAXIMUM_TASKS)
-    #define CONFIGURE_MAXIMUM_TASKS \
-      rtems_resource_unlimited(CONFIGURE_UNLIMITED_ALLOCATION_SIZE)
-  #endif
-  #if !defined(CONFIGURE_MAXIMUM_TIMERS)
-    #define CONFIGURE_MAXIMUM_TIMERS \
-  #endif
-  #if !defined(CONFIGURE_MAXIMUM_SEMAPHORES)
-    #define CONFIGURE_MAXIMUM_SEMAPHORES \
-  #endif
-  #if !defined(CONFIGURE_MAXIMUM_MESSAGE_QUEUES)
-    #define CONFIGURE_MAXIMUM_MESSAGE_QUEUES \
-  #endif
-  #if !defined(CONFIGURE_MAXIMUM_PARTITIONS)
-    #define CONFIGURE_MAXIMUM_PARTITIONS \
-  #endif
-  #if !defined(CONFIGURE_MAXIMUM_REGIONS)
-    #define CONFIGURE_MAXIMUM_REGIONS \
-  #endif
-  #if !defined(CONFIGURE_MAXIMUM_PORTS)
-    #define CONFIGURE_MAXIMUM_PORTS \
-  #endif
-  #if !defined(CONFIGURE_MAXIMUM_PERIODS)
-    #define CONFIGURE_MAXIMUM_PERIODS \
-  #endif
-  #if !defined(CONFIGURE_MAXIMUM_BARRIERS)
-    #define CONFIGURE_MAXIMUM_BARRIERS \
-  #endif
-  #if !defined(CONFIGURE_MAXIMUM_POSIX_KEYS)
-    #define CONFIGURE_MAXIMUM_POSIX_KEYS \
-  #endif
-  #if !defined(CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS)
-    #define CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS \
-  #endif
-  #if !defined(CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES)
-    #define CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES \
-  #endif
-  #if !defined(CONFIGURE_MAXIMUM_POSIX_SEMAPHORES)
-    #define CONFIGURE_MAXIMUM_POSIX_SEMAPHORES \
-  #endif
-  #if !defined(CONFIGURE_MAXIMUM_POSIX_SHMS)
-    #define CONFIGURE_MAXIMUM_POSIX_SHMS \
-  #endif
-  #if !defined(CONFIGURE_MAXIMUM_POSIX_THREADS)
-    #define CONFIGURE_MAXIMUM_POSIX_THREADS \
-  #endif
-  #ifdef RTEMS_POSIX_API
-    #if !defined(CONFIGURE_MAXIMUM_POSIX_TIMERS)
-      #define CONFIGURE_MAXIMUM_POSIX_TIMERS \
-    #endif
-  #endif /* RTEMS_POSIX_API */
-#endif /* CONFIGURE_UNLIMITED_OBJECTS */
  * @defgroup ConfigurationClassicAPI Classic API Configuration
@@ -863,6 +777,8 @@ extern "C" {
+#ifdef CONFIGURE_INIT
  *  Make sure a task/thread of some sort is configured.
@@ -900,5 +816,7 @@ extern "C" {
   #endif
 #endif
+#endif /* CONFIGURE_INIT */
 #endif
 /* end of include file */
diff --git a/cpukit/include/rtems/confdefs/unlimited.h b/cpukit/include/rtems/confdefs/unlimited.h
new file mode 100644
index 0000000000..4437d4a175
--- /dev/null
+++ b/cpukit/include/rtems/confdefs/unlimited.h
@@ -0,0 +1,143 @@
+ * SPDX-License-Identifier: BSD-2-Clause
+ * Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
+ * are met:
+ * @file
+ * @ingroup RTEMSApplicationConfiguration
+ * @brief Evaluate Unlimited Objects Configuration Options
+#ifndef _RTEMS_CONFDEFS_UNLIMITED_H
+#define _RTEMS_CONFDEFS_UNLIMITED_H
+#ifndef __CONFIGURATION_TEMPLATE_h
+#error "Do not include this file directly, use <rtems/confdefs.h> instead"
+#endif
+#ifdef CONFIGURE_UNLIMITED_OBJECTS
+#include <rtems/config.h>
+#if !defined(CONFIGURE_UNIFIED_WORK_AREAS) \
+  && !defined(CONFIGURE_EXECUTIVE_RAM_SIZE) \
+  && !defined(CONFIGURE_MEMORY_OVERHEAD)
+  #error "CONFIGURE_UNLIMITED_OBJECTS requires one of CONFIGURE_UNIFIED_WORK_AREAS, CONFIGURE_EXECUTIVE_RAM_SIZE, and CONFIGURE_MEMORY_OVERHEAD"
+#endif
+#ifndef CONFIGURE_UNLIMITED_ALLOCATION_SIZE
+  #define CONFIGURE_UNLIMITED_ALLOCATION_SIZE 8
+#endif
+#ifndef CONFIGURE_MAXIMUM_TASKS
+  #define CONFIGURE_MAXIMUM_TASKS \
+    rtems_resource_unlimited( CONFIGURE_UNLIMITED_ALLOCATION_SIZE )
+#endif
+#ifndef CONFIGURE_MAXIMUM_TIMERS
+  #define CONFIGURE_MAXIMUM_TIMERS \
+#endif
+#ifndef CONFIGURE_MAXIMUM_SEMAPHORES
+  #define CONFIGURE_MAXIMUM_SEMAPHORES \
+#endif
+#ifndef CONFIGURE_MAXIMUM_MESSAGE_QUEUES
+  #define CONFIGURE_MAXIMUM_MESSAGE_QUEUES \
+#endif
+#ifndef CONFIGURE_MAXIMUM_PARTITIONS
+  #define CONFIGURE_MAXIMUM_PARTITIONS \
+#endif
+#ifndef CONFIGURE_MAXIMUM_REGIONS
+  #define CONFIGURE_MAXIMUM_REGIONS \
+#endif
+#ifndef CONFIGURE_MAXIMUM_PORTS
+  #define CONFIGURE_MAXIMUM_PORTS \
+#endif
+#ifndef CONFIGURE_MAXIMUM_PERIODS
+  #define CONFIGURE_MAXIMUM_PERIODS \
+#endif
+#ifndef CONFIGURE_MAXIMUM_BARRIERS
+  #define CONFIGURE_MAXIMUM_BARRIERS \
+#endif
+#ifndef CONFIGURE_MAXIMUM_POSIX_KEYS
+  #define CONFIGURE_MAXIMUM_POSIX_KEYS \
+#endif
+#ifndef CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS
+  #define CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS \
+#endif
+#ifndef CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES
+  #define CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES \
+#endif
+#ifndef CONFIGURE_MAXIMUM_POSIX_SEMAPHORES
+  #define CONFIGURE_MAXIMUM_POSIX_SEMAPHORES \
+#endif
+#ifndef CONFIGURE_MAXIMUM_POSIX_SHMS
+  #define CONFIGURE_MAXIMUM_POSIX_SHMS \
+#endif
+#ifndef CONFIGURE_MAXIMUM_POSIX_THREADS
+  #define CONFIGURE_MAXIMUM_POSIX_THREADS \
+#endif
+#if defined(RTEMS_POSIX_API) && !defined(CONFIGURE_MAXIMUM_POSIX_TIMERS)
+  #define CONFIGURE_MAXIMUM_POSIX_TIMERS \
+#endif
+#endif /* CONFIGURE_UNLIMITED_OBJECTS */
+#endif /* _RTEMS_CONFDEFS_UNLIMITED_H */
2.16.4
