[PATCH v2 38/44] config: Add <rtems/confdefs/iodrivers.h>
Fri Feb 21 10:52:50 UTC 2020
Remove all comments and copyrightable content from the moved content.
Use BSD-2-Clause license for new file.
Update #3053.
Update #3875.
 cpukit/headers.am                         |   1 +
 cpukit/include/rtems/confdefs.h           | 148 +-------------------------
 cpukit/include/rtems/confdefs/iodrivers.h | 166 ++++++++++++++++++++++++++++++
 3 files changed, 168 insertions(+), 147 deletions(-)
 create mode 100644 cpukit/include/rtems/confdefs/iodrivers.h
diff --git a/cpukit/headers.am b/cpukit/headers.am
index 2456c42f94..9f2e06b870 100644
--- a/cpukit/headers.am
+++ b/cpukit/headers.am
@@ -190,6 +190,7 @@ include_rtems_confdefs_HEADERS += include/rtems/confdefs/console.h
 include_rtems_confdefs_HEADERS += include/rtems/confdefs/extensions.h
 include_rtems_confdefs_HEADERS += include/rtems/confdefs/inittask.h
 include_rtems_confdefs_HEADERS += include/rtems/confdefs/initthread.h
+include_rtems_confdefs_HEADERS += include/rtems/confdefs/iodrivers.h
 include_rtems_confdefs_HEADERS += include/rtems/confdefs/libio.h
 include_rtems_confdefs_HEADERS += include/rtems/confdefs/libpci.h
 include_rtems_confdefs_HEADERS += include/rtems/confdefs/malloc.h
diff --git a/cpukit/include/rtems/confdefs.h b/cpukit/include/rtems/confdefs.h
index 052f958b1a..e1b23ddaef 100644
--- a/cpukit/include/rtems/confdefs.h
+++ b/cpukit/include/rtems/confdefs.h
@@ -26,7 +26,6 @@
  * Include the executive's configuration
-#include <rtems/ioimpl.h>
 #include <rtems/sysinit.h>
 #include <rtems/score/apimutex.h>
 #include <rtems/score/context.h>
@@ -54,6 +53,7 @@
 #include <rtems/confdefs/extensions.h>
 #include <rtems/confdefs/inittask.h>
 #include <rtems/confdefs/initthread.h>
+#include <rtems/confdefs/iodrivers.h>
 #include <rtems/confdefs/libio.h>
 #include <rtems/confdefs/libpci.h>
 #include <rtems/confdefs/malloc.h>
@@ -146,151 +146,6 @@ extern "C" {
 #endif
- * @defgroup ConfigurationDriverTable Device Driver Table Configuration
- * @addtogroup Configuration
- * This group contains parameters related to generating a Device Driver
- * Table.
- * Default Device Driver Table.  Each driver needed by the test is explicitly
- * chosen by the application.  There is always a null driver entry.
- * This is an empty device driver slot.
-#define NULL_DRIVER_TABLE_ENTRY \
- { NULL, NULL, NULL, NULL, NULL, NULL }
-#if (defined(CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER) && \
-    defined(CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER)) || \
-  (defined(CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER) && \
-    defined(CONFIGURE_APPLICATION_NEEDS_SIMPLE_TASK_CONSOLE_DRIVER)) || \
-  (defined(CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER) && \
-#error "CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER, CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER, and CONFIGURE_APPLICATION_NEEDS_SIMPLE_TASK_CONSOLE_DRIVER are mutually exclusive"
-#endif
-#ifdef CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
-  #include <rtems/console.h>
-#endif
-#ifdef CONFIGURE_APPLICATION_NEEDS_TIMER_DRIVER
-  #include <rtems/btimer.h>
-#endif
-#ifdef CONFIGURE_APPLICATION_NEEDS_RTC_DRIVER
-  #include <rtems/rtc.h>
-#endif
-#ifdef CONFIGURE_APPLICATION_NEEDS_WATCHDOG_DRIVER
-  #include <rtems/watchdogdrv.h>
-#endif
-#ifdef CONFIGURE_APPLICATION_NEEDS_FRAME_BUFFER_DRIVER
-  #include <rtems/framebuffer.h>
-#endif
-#ifdef CONFIGURE_APPLICATION_NEEDS_STUB_DRIVER
-  #include <rtems/devnull.h>
-#endif
-#ifdef CONFIGURE_APPLICATION_NEEDS_ZERO_DRIVER
-  #include <rtems/devzero.h>
-#endif
-#ifdef CONFIGURE_APPLICATION_NEEDS_IDE_DRIVER
-  /* the ide driver needs the ATA driver */
-  #ifndef CONFIGURE_APPLICATION_NEEDS_ATA_DRIVER
-    #define CONFIGURE_APPLICATION_NEEDS_ATA_DRIVER
-  #endif
-  #include <libchip/ide_ctrl.h>
-#endif
-#ifdef CONFIGURE_APPLICATION_NEEDS_ATA_DRIVER
-  #include <libchip/ata.h>
-#endif
- * This specifies the maximum number of device drivers that
- * can be installed in the system at one time.  It must account
- * for both the statically and dynamically installed drivers.
-#ifndef CONFIGURE_MAXIMUM_DRIVERS
-  #define CONFIGURE_MAXIMUM_DRIVERS
-#endif
-#ifdef CONFIGURE_INIT
-  rtems_driver_address_table
-    _IO_Driver_address_table[ CONFIGURE_MAXIMUM_DRIVERS ] = {
-    #ifdef CONFIGURE_BSP_PREREQUISITE_DRIVERS
-      CONFIGURE_BSP_PREREQUISITE_DRIVERS,
-    #endif
-    #ifdef CONFIGURE_APPLICATION_PREREQUISITE_DRIVERS
-      CONFIGURE_APPLICATION_PREREQUISITE_DRIVERS,
-    #endif
-    #ifdef CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
-      CONSOLE_DRIVER_TABLE_ENTRY,
-    #endif
-    #ifdef CONFIGURE_APPLICATION_NEEDS_RTC_DRIVER
-      RTC_DRIVER_TABLE_ENTRY,
-    #endif
-    #ifdef CONFIGURE_APPLICATION_NEEDS_WATCHDOG_DRIVER
-      WATCHDOG_DRIVER_TABLE_ENTRY,
-    #endif
-    #ifdef CONFIGURE_APPLICATION_NEEDS_STUB_DRIVER
-      DEVNULL_DRIVER_TABLE_ENTRY,
-    #endif
-    #ifdef CONFIGURE_APPLICATION_NEEDS_ZERO_DRIVER
-      DEVZERO_DRIVER_TABLE_ENTRY,
-    #endif
-    #ifdef CONFIGURE_APPLICATION_NEEDS_IDE_DRIVER
-      IDE_CONTROLLER_DRIVER_TABLE_ENTRY,
-    #endif
-    #ifdef CONFIGURE_APPLICATION_NEEDS_ATA_DRIVER
-      ATA_DRIVER_TABLE_ENTRY,
-    #endif
-    #ifdef CONFIGURE_APPLICATION_NEEDS_FRAME_BUFFER_DRIVER
-      FRAME_BUFFER_DRIVER_TABLE_ENTRY,
-    #endif
-    #ifdef CONFIGURE_APPLICATION_EXTRA_DRIVERS
-      CONFIGURE_APPLICATION_EXTRA_DRIVERS,
-    #endif
-    #ifdef CONFIGURE_APPLICATION_NEEDS_NULL_DRIVER
-      NULL_DRIVER_TABLE_ENTRY
-    #elif !defined(CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER) && \
-        !defined(CONFIGURE_APPLICATION_NEEDS_RTC_DRIVER) && \
-        !defined(CONFIGURE_APPLICATION_NEEDS_STUB_DRIVER) && \
-        !defined(CONFIGURE_APPLICATION_NEEDS_ZERO_DRIVER) && \
-        !defined(CONFIGURE_APPLICATION_NEEDS_IDE_DRIVER) && \
-        !defined(CONFIGURE_APPLICATION_NEEDS_ATA_DRIVER) && \
-        !defined(CONFIGURE_APPLICATION_NEEDS_FRAME_BUFFER_DRIVER) && \
-        !defined(CONFIGURE_APPLICATION_EXTRA_DRIVERS)
-    #endif
-  const size_t _IO_Number_of_drivers =
-    RTEMS_ARRAY_SIZE( _IO_Driver_address_table );
-#endif
-   * configure the priority of the ATA driver task
-  #ifndef CONFIGURE_ATA_DRIVER_TASK_PRIORITY
-    #define CONFIGURE_ATA_DRIVER_TASK_PRIORITY ATA_DRIVER_TASK_DEFAULT_PRIORITY
-  #endif
-  #ifdef CONFIGURE_INIT
-    rtems_task_priority rtems_ata_driver_task_priority
-      = CONFIGURE_ATA_DRIVER_TASK_PRIORITY;
-  #endif /* CONFIGURE_INIT */
-#endif
-/**@}*/ /* end of Device Driver Table Configuration */
  * This macro specifies that the user wants to use unlimited objects for any
  * classic or posix objects that have not already been given resource limits.
@@ -378,7 +233,6 @@ extern "C" {
   #endif /* RTEMS_POSIX_API */
 #endif /* CONFIGURE_UNLIMITED_OBJECTS */
  * @defgroup ConfigurationClassicAPI Classic API Configuration
diff --git a/cpukit/include/rtems/confdefs/iodrivers.h b/cpukit/include/rtems/confdefs/iodrivers.h
new file mode 100644
index 0000000000..f6649f7994
--- /dev/null
+++ b/cpukit/include/rtems/confdefs/iodrivers.h
@@ -0,0 +1,166 @@
+ * SPDX-License-Identifier: BSD-2-Clause
+ * Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
+ * are met:
+ * @file
+ * @ingroup RTEMSApplicationConfiguration
+ * @brief Evaluate IO Driver Configuration Options
+#ifndef _RTEMS_CONFDEFS_IODRIVERS_H
+#define _RTEMS_CONFDEFS_IODRIVERS_H
+#ifndef __CONFIGURATION_TEMPLATE_h
+#error "Do not include this file directly, use <rtems/confdefs.h> instead"
+#endif
+#ifdef CONFIGURE_INIT
+#include <rtems/ioimpl.h>
+#ifdef CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
+  #if defined(CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER) \
+    || defined(CONFIGURE_APPLICATION_NEEDS_SIMPLE_TASK_CONSOLE_DRIVER)
+    #error "CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER, CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER, and CONFIGURE_APPLICATION_NEEDS_SIMPLE_TASK_CONSOLE_DRIVER are mutually exclusive"
+  #endif
+  #include <rtems/console.h>
+#endif
+#ifdef CONFIGURE_APPLICATION_NEEDS_TIMER_DRIVER
+  #include <rtems/btimer.h>
+#endif
+#ifdef CONFIGURE_APPLICATION_NEEDS_RTC_DRIVER
+  #include <rtems/rtc.h>
+#endif
+#ifdef CONFIGURE_APPLICATION_NEEDS_WATCHDOG_DRIVER
+  #include <rtems/watchdogdrv.h>
+#endif
+#ifdef CONFIGURE_APPLICATION_NEEDS_FRAME_BUFFER_DRIVER
+  #include <rtems/framebuffer.h>
+#endif
+#ifdef CONFIGURE_APPLICATION_NEEDS_STUB_DRIVER
+  #include <rtems/devnull.h>
+#endif
+#ifdef CONFIGURE_APPLICATION_NEEDS_ZERO_DRIVER
+  #include <rtems/devzero.h>
+#endif
+#ifdef CONFIGURE_APPLICATION_NEEDS_IDE_DRIVER
+  #ifndef CONFIGURE_APPLICATION_NEEDS_ATA_DRIVER
+    #define CONFIGURE_APPLICATION_NEEDS_ATA_DRIVER
+  #endif
+  #include <libchip/ide_ctrl.h>
+#endif
+#ifdef CONFIGURE_APPLICATION_NEEDS_ATA_DRIVER
+  #include <libchip/ata.h>
+#endif
+#ifndef CONFIGURE_MAXIMUM_DRIVERS
+  #define CONFIGURE_MAXIMUM_DRIVERS
+#endif
+#ifdef __cplusplus
+extern "C" {
+#endif
+rtems_driver_address_table
+_IO_Driver_address_table[ CONFIGURE_MAXIMUM_DRIVERS ] = {
+  #ifdef CONFIGURE_BSP_PREREQUISITE_DRIVERS
+    CONFIGURE_BSP_PREREQUISITE_DRIVERS,
+  #endif
+  #ifdef CONFIGURE_APPLICATION_PREREQUISITE_DRIVERS
+    CONFIGURE_APPLICATION_PREREQUISITE_DRIVERS,
+  #endif
+  #ifdef CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
+    CONSOLE_DRIVER_TABLE_ENTRY,
+  #endif
+  #ifdef CONFIGURE_APPLICATION_NEEDS_RTC_DRIVER
+    RTC_DRIVER_TABLE_ENTRY,
+  #endif
+  #ifdef CONFIGURE_APPLICATION_NEEDS_WATCHDOG_DRIVER
+    WATCHDOG_DRIVER_TABLE_ENTRY,
+  #endif
+  #ifdef CONFIGURE_APPLICATION_NEEDS_STUB_DRIVER
+    DEVNULL_DRIVER_TABLE_ENTRY,
+  #endif
+  #ifdef CONFIGURE_APPLICATION_NEEDS_ZERO_DRIVER
+    DEVZERO_DRIVER_TABLE_ENTRY,
+  #endif
+  #ifdef CONFIGURE_APPLICATION_NEEDS_IDE_DRIVER
+    IDE_CONTROLLER_DRIVER_TABLE_ENTRY,
+  #endif
+  #ifdef CONFIGURE_APPLICATION_NEEDS_ATA_DRIVER
+    ATA_DRIVER_TABLE_ENTRY,
+  #endif
+  #ifdef CONFIGURE_APPLICATION_NEEDS_FRAME_BUFFER_DRIVER
+    FRAME_BUFFER_DRIVER_TABLE_ENTRY,
+  #endif
+  #ifdef CONFIGURE_APPLICATION_EXTRA_DRIVERS
+    CONFIGURE_APPLICATION_EXTRA_DRIVERS,
+  #endif
+  #if defined(CONFIGURE_APPLICATION_NEEDS_NULL_DRIVER) \
+    || ( !defined(CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER) \
+      && !defined(CONFIGURE_APPLICATION_NEEDS_RTC_DRIVER) \
+      && !defined(CONFIGURE_APPLICATION_NEEDS_STUB_DRIVER) \
+      && !defined(CONFIGURE_APPLICATION_NEEDS_ZERO_DRIVER) \
+      && !defined(CONFIGURE_APPLICATION_NEEDS_IDE_DRIVER) \
+      && !defined(CONFIGURE_APPLICATION_NEEDS_ATA_DRIVER) \
+      && !defined(CONFIGURE_APPLICATION_NEEDS_FRAME_BUFFER_DRIVER) \
+      && !defined(CONFIGURE_APPLICATION_EXTRA_DRIVERS) )
+    { NULL, NULL, NULL, NULL, NULL, NULL }
+  #endif
+const size_t _IO_Number_of_drivers =
+  RTEMS_ARRAY_SIZE( _IO_Driver_address_table );
+  #ifndef CONFIGURE_ATA_DRIVER_TASK_PRIORITY
+    #define CONFIGURE_ATA_DRIVER_TASK_PRIORITY ATA_DRIVER_TASK_DEFAULT_PRIORITY
+  #endif
+  rtems_task_priority rtems_ata_driver_task_priority
+    = CONFIGURE_ATA_DRIVER_TASK_PRIORITY;
+#endif
+#ifdef __cplusplus
+#endif
+#endif /* CONFIGURE_INIT */
+#endif /* _RTEMS_CONFDEFS_IODRIVERS_H */
2.16.4
