[PATCH v2 35/44] config: Add <rtems/confdefs/inittask.h>
Fri Feb 21 10:52:47 UTC 2020
Remove all comments and copyrightable content from the moved content.
Use BSD-2-Clause license for new file.
Update #3053.
Update #3875.
 cpukit/headers.am                        |   1 +
 cpukit/include/rtems/confdefs.h          | 130 +-----------------------------
 cpukit/include/rtems/confdefs/inittask.h | 131 +++++++++++++++++++++++++++++++
 3 files changed, 134 insertions(+), 128 deletions(-)
 create mode 100644 cpukit/include/rtems/confdefs/inittask.h
diff --git a/cpukit/headers.am b/cpukit/headers.am
index 7bcc7be6ca..ae235a3f32 100644
--- a/cpukit/headers.am
+++ b/cpukit/headers.am
@@ -187,6 +187,7 @@ include_rtems_confdefs_HEADERS += include/rtems/confdefs/bdbuf.h
 include_rtems_confdefs_HEADERS += include/rtems/confdefs/bsp.h
 include_rtems_confdefs_HEADERS += include/rtems/confdefs/clock.h
 include_rtems_confdefs_HEADERS += include/rtems/confdefs/extensions.h
+include_rtems_confdefs_HEADERS += include/rtems/confdefs/inittask.h
 include_rtems_confdefs_HEADERS += include/rtems/confdefs/libio.h
 include_rtems_confdefs_HEADERS += include/rtems/confdefs/libpci.h
 include_rtems_confdefs_HEADERS += include/rtems/confdefs/malloc.h
diff --git a/cpukit/include/rtems/confdefs.h b/cpukit/include/rtems/confdefs.h
index b0783ae225..d31c125f7e 100644
--- a/cpukit/include/rtems/confdefs.h
+++ b/cpukit/include/rtems/confdefs.h
@@ -51,6 +51,7 @@
 #include <rtems/confdefs/bdbuf.h>
 #include <rtems/confdefs/clock.h>
 #include <rtems/confdefs/extensions.h>
+#include <rtems/confdefs/inittask.h>
 #include <rtems/confdefs/libio.h>
 #include <rtems/confdefs/libpci.h>
 #include <rtems/confdefs/malloc.h>
@@ -143,98 +144,6 @@ extern "C" {
 #endif
- * @defgroup ConfigurationInitTasksTable Initialization Tasks Configuration
- * @addtogroup Configuration
- * This group contains the elements needed to define the Classic API
- * Initialization Tasks Table.
- * Default User Initialization Task Table.  This table guarantees that
- * one user initialization table is defined.
-#if defined(CONFIGURE_RTEMS_INIT_TASKS_TABLE)
- * When using the default Classic API Initialization Tasks Table, this is
- * used to specify the name of the single Classic API task.
-#ifndef CONFIGURE_INIT_TASK_NAME
-  #define CONFIGURE_INIT_TASK_NAME          rtems_build_name('U', 'I', '1', ' ')
-#endif
- * used to specify the stack size of the single Classic API task.
-#ifndef CONFIGURE_INIT_TASK_STACK_SIZE
-  #define CONFIGURE_INIT_TASK_STACK_SIZE    CONFIGURE_MINIMUM_TASK_STACK_SIZE
-#endif
- * used to specify the priority of the single Classic API task.
-#ifndef CONFIGURE_INIT_TASK_PRIORITY
-  #define CONFIGURE_INIT_TASK_PRIORITY      1
-#endif
- * used to specify the attributes size of the single Classic API task.
-#ifndef CONFIGURE_INIT_TASK_ATTRIBUTES
-  #define CONFIGURE_INIT_TASK_ATTRIBUTES    RTEMS_DEFAULT_ATTRIBUTES
-#endif
- * used to specify the entry point of the single Classic API task.
-#ifndef CONFIGURE_INIT_TASK_ENTRY_POINT
-  #ifdef __cplusplus
-  extern "C" {
-  #endif
-    rtems_task Init (rtems_task_argument );
-  #endif
-  #define CONFIGURE_INIT_TASK_ENTRY_POINT   Init
-  extern const char* bsp_boot_cmdline;
-  #define CONFIGURE_INIT_TASK_ARGUMENTS     ((rtems_task_argument) &bsp_boot_cmdline)
-#endif
- * used to specify the initial execution mode of the single Classic API task.
-#ifndef CONFIGURE_INIT_TASK_INITIAL_MODES
-  #ifdef RTEMS_SMP
-    #define CONFIGURE_INIT_TASK_INITIAL_MODES RTEMS_DEFAULT_MODES
-  #else
-    #define CONFIGURE_INIT_TASK_INITIAL_MODES RTEMS_NO_PREEMPT
-  #endif
-#endif
- * used to specify the initial argument to the single Classic API task.
-#ifndef CONFIGURE_INIT_TASK_ARGUMENTS
-  #define CONFIGURE_INIT_TASK_ARGUMENTS     0
-#endif
-#else     /* CONFIGURE_RTEMS_INIT_TASKS_TABLE */
- * This is the stack size of the Initialization Task when none is configured.
-#define CONFIGURE_INIT_TASK_STACK_SIZE 0
-#endif
-/**@}*/  /* end of Classic API Initialization Tasks Table */
  * @defgroup ConfigurationDriverTable Device Driver Table Configuration
@@ -796,17 +705,6 @@ extern "C" {
  *  may have requested.
- * This accounts for any extra memory required by the Classic API
- * Initialization Task.
-#if (CONFIGURE_INIT_TASK_STACK_SIZE > CONFIGURE_MINIMUM_TASK_STACK_SIZE)
-  #define _CONFIGURE_INITIALIZATION_THREADS_STACKS_CLASSIC_PART \
-      (CONFIGURE_INIT_TASK_STACK_SIZE - CONFIGURE_MINIMUM_TASK_STACK_SIZE)
-#else
-  #define _CONFIGURE_INITIALIZATION_THREADS_STACKS_CLASSIC_PART 0
-#endif
  * This accounts for any extra memory required by the POSIX API
  * Initialization Thread.
@@ -825,7 +723,7 @@ extern "C" {
  * and thread stack requirements.
 #define _CONFIGURE_INITIALIZATION_THREADS_EXTRA_STACKS \
-    (_CONFIGURE_INITIALIZATION_THREADS_STACKS_CLASSIC_PART + \
+    (_CONFIGURE_INIT_TASK_STACK_EXTRA + \
     _CONFIGURE_INITIALIZATION_THREADS_STACKS_POSIX_PART)
@@ -1156,30 +1054,6 @@ extern "C" {
   #endif
 #endif
- *  If the user has configured a set of Classic API Initialization Tasks,
- *  then we need to install the code that runs that loop.
-#ifdef CONFIGURE_INIT
-  #if defined(CONFIGURE_RTEMS_INIT_TASKS_TABLE)
-    const rtems_initialization_tasks_table _RTEMS_tasks_User_task_table = {
-      CONFIGURE_INIT_TASK_NAME,
-      CONFIGURE_INIT_TASK_STACK_SIZE,
-      CONFIGURE_INIT_TASK_PRIORITY,
-      CONFIGURE_INIT_TASK_ATTRIBUTES,
-      CONFIGURE_INIT_TASK_ENTRY_POINT,
-      CONFIGURE_INIT_TASK_INITIAL_MODES,
-      CONFIGURE_INIT_TASK_ARGUMENTS
-    RTEMS_SYSINIT_ITEM(
-      _RTEMS_tasks_Initialize_user_task,
-      RTEMS_SYSINIT_CLASSIC_USER_TASKS,
-      RTEMS_SYSINIT_ORDER_MIDDLE
-  #endif
-#endif
  *  If the user has configured a set of POSIX Initialization Threads,
diff --git a/cpukit/include/rtems/confdefs/inittask.h b/cpukit/include/rtems/confdefs/inittask.h
new file mode 100644
index 0000000000..8705d962c7
--- /dev/null
+++ b/cpukit/include/rtems/confdefs/inittask.h
@@ -0,0 +1,131 @@
+ * SPDX-License-Identifier: BSD-2-Clause
+ * Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
+ * are met:
+ * @file
+ * @ingroup RTEMSApplicationConfiguration
+ * @brief Evaluate User Initialization Task Configuration Options
+ * This header file defines _CONFIGURE_INIT_TASK_STACK_EXTRA for use by other
+ * configuration header files.
+#ifndef _RTEMS_CONFDEFS_INITTASK_H
+#define _RTEMS_CONFDEFS_INITTASK_H
+#ifndef __CONFIGURATION_TEMPLATE_h
+#error "Do not include this file directly, use <rtems/confdefs.h> instead"
+#endif
+#ifdef CONFIGURE_INIT
+#ifdef CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#include <rtems/confdefs/percpu.h>
+#include <rtems/rtems/object.h>
+#include <rtems/rtems/tasksdata.h>
+#include <rtems/sysinit.h>
+#ifndef CONFIGURE_INIT_TASK_NAME
+  #define CONFIGURE_INIT_TASK_NAME rtems_build_name( 'U', 'I', '1', ' ' )
+#endif
+#ifndef CONFIGURE_INIT_TASK_STACK_SIZE
+  #define CONFIGURE_INIT_TASK_STACK_SIZE CONFIGURE_MINIMUM_TASK_STACK_SIZE
+#endif
+#if CONFIGURE_INIT_TASK_STACK_SIZE > CONFIGURE_MINIMUM_TASK_STACK_SIZE
+  #define _CONFIGURE_INIT_TASK_STACK_EXTRA \
+    ( CONFIGURE_INIT_TASK_STACK_SIZE - CONFIGURE_MINIMUM_TASK_STACK_SIZE )
+#endif
+#ifndef CONFIGURE_INIT_TASK_PRIORITY
+  #define CONFIGURE_INIT_TASK_PRIORITY 1
+#endif
+#ifndef CONFIGURE_INIT_TASK_ATTRIBUTES
+  #define CONFIGURE_INIT_TASK_ATTRIBUTES RTEMS_DEFAULT_ATTRIBUTES
+#endif
+#ifndef CONFIGURE_INIT_TASK_INITIAL_MODES
+  #ifdef RTEMS_SMP
+    #define CONFIGURE_INIT_TASK_INITIAL_MODES RTEMS_DEFAULT_MODES
+  #else
+    #define CONFIGURE_INIT_TASK_INITIAL_MODES RTEMS_NO_PREEMPT
+  #endif
+#endif
+#ifdef __cplusplus
+extern "C" {
+#endif
+#ifndef CONFIGURE_INIT_TASK_ENTRY_POINT
+  rtems_task Init( rtems_task_argument );
+  #define CONFIGURE_INIT_TASK_ENTRY_POINT Init
+  #ifndef CONFIGURE_INIT_TASK_ARGUMENTS
+    extern const char *bsp_boot_cmdline;
+    #define CONFIGURE_INIT_TASK_ARGUMENTS \
+      ( (rtems_task_argument) &bsp_boot_cmdline )
+  #endif
+#endif
+#ifndef CONFIGURE_INIT_TASK_ARGUMENTS
+  #define CONFIGURE_INIT_TASK_ARGUMENTS 0
+#endif
+const rtems_initialization_tasks_table _RTEMS_tasks_User_task_table = {
+  CONFIGURE_INIT_TASK_NAME,
+  CONFIGURE_INIT_TASK_STACK_SIZE,
+  CONFIGURE_INIT_TASK_PRIORITY,
+  CONFIGURE_INIT_TASK_ATTRIBUTES,
+  CONFIGURE_INIT_TASK_ENTRY_POINT,
+  CONFIGURE_INIT_TASK_INITIAL_MODES,
+  CONFIGURE_INIT_TASK_ARGUMENTS
+RTEMS_SYSINIT_ITEM(
+  _RTEMS_tasks_Initialize_user_task,
+  RTEMS_SYSINIT_CLASSIC_USER_TASKS,
+  RTEMS_SYSINIT_ORDER_MIDDLE
+#ifdef __cplusplus
+#endif
+#endif /* CONFIGURE_RTEMS_INIT_TASKS_TABLE */
+#ifndef _CONFIGURE_INIT_TASK_STACK_EXTRA
+  #define _CONFIGURE_INIT_TASK_STACK_EXTRA 0
+#endif
+#endif /* CONFIGURE_INIT */
+#endif /* _RTEMS_CONFDEFS_INITTASK_H */
2.16.4
