[PATCH v2 36/44] config: Add <rtems/confdefs/initthread.h>
Sebastian Huber
Fri Feb 21 10:52:48 UTC 2020
Remove all comments and copyrightable content from the moved content.
Use BSD-2-Clause license for new file.
Update #3053.
Update #3875.
cpukit/headers.am | 1 +
cpukit/include/rtems/confdefs.h | 58 +-----------------
cpukit/include/rtems/confdefs/initthread.h | 97 ++++++++++++++++++++++++++++++
3 files changed, 100 insertions(+), 56 deletions(-)
create mode 100644 cpukit/include/rtems/confdefs/initthread.h
diff --git a/cpukit/headers.am b/cpukit/headers.am
index ae235a3f32..7a9cf1adae 100644
--- a/cpukit/headers.am
+++ b/cpukit/headers.am
@@ -188,6 +188,7 @@ include_rtems_confdefs_HEADERS += include/rtems/confdefs/bsp.h
include_rtems_confdefs_HEADERS += include/rtems/confdefs/clock.h
include_rtems_confdefs_HEADERS += include/rtems/confdefs/extensions.h
include_rtems_confdefs_HEADERS += include/rtems/confdefs/inittask.h
+include_rtems_confdefs_HEADERS += include/rtems/confdefs/initthread.h
include_rtems_confdefs_HEADERS += include/rtems/confdefs/libio.h
include_rtems_confdefs_HEADERS += include/rtems/confdefs/libpci.h
include_rtems_confdefs_HEADERS += include/rtems/confdefs/malloc.h
diff --git a/cpukit/include/rtems/confdefs.h b/cpukit/include/rtems/confdefs.h
index d31c125f7e..4ae6580754 100644
--- a/cpukit/include/rtems/confdefs.h
+++ b/cpukit/include/rtems/confdefs.h
@@ -52,6 +52,7 @@
#include <rtems/confdefs/clock.h>
#include <rtems/confdefs/extensions.h>
#include <rtems/confdefs/inittask.h>
+#include <rtems/confdefs/initthread.h>
#include <rtems/confdefs/libio.h>
#include <rtems/confdefs/libpci.h>
#include <rtems/confdefs/malloc.h>
@@ -605,24 +606,6 @@ extern "C" {
#define _CONFIGURE_MEMORY_FOR_POSIX_QUEUED_SIGNALS 0
#endif
-#ifdef CONFIGURE_POSIX_INIT_THREAD_TABLE
- #ifndef CONFIGURE_POSIX_INIT_THREAD_ENTRY_POINT
- #define CONFIGURE_POSIX_INIT_THREAD_ENTRY_POINT POSIX_Init
- #endif
- #ifndef CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE
- #define CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE \
- CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE
- #endif
-#endif /* CONFIGURE_POSIX_INIT_THREAD_TABLE */
- * This configuration parameter specifies the stack size of the
- * POSIX API Initialization thread (if used).
-#ifndef CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE
- #define CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE 0
-#endif
/**@}*/ /* end of POSIX API Configuration */
@@ -700,31 +683,13 @@ extern "C" {
_CONFIGURE_HEAP_HANDLER_OVERHEAD \
- * Now account for any extra memory that initialization tasks or threads
- * may have requested.
- * This accounts for any extra memory required by the POSIX API
- * Initialization Thread.
-#if (CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE > \
- CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE)
- #define _CONFIGURE_INITIALIZATION_THREADS_STACKS_POSIX_PART \
- (CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE - \
-#else
- #define _CONFIGURE_INITIALIZATION_THREADS_STACKS_POSIX_PART 0
-#endif
* This macro provides a summation of the various initialization task
* and thread stack requirements.
#define _CONFIGURE_INITIALIZATION_THREADS_EXTRA_STACKS \
(_CONFIGURE_INIT_TASK_STACK_EXTRA + \
- _CONFIGURE_INITIALIZATION_THREADS_STACKS_POSIX_PART)
+ _CONFIGURE_POSIX_INIT_THREAD_STACK_EXTRA)
* This macro is calculated to specify the memory required for
@@ -1054,25 +1019,6 @@ extern "C" {
#endif
#endif
- * If the user has configured a set of POSIX Initialization Threads,
- * then we need to install the code that runs that loop.
-#ifdef CONFIGURE_INIT
- #if defined(CONFIGURE_POSIX_INIT_THREAD_TABLE)
- const posix_initialization_threads_table _POSIX_Threads_User_thread_table = {
- CONFIGURE_POSIX_INIT_THREAD_ENTRY_POINT,
- CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE
- RTEMS_SYSINIT_ITEM(
- _POSIX_Threads_Initialize_user_thread,
- RTEMS_SYSINIT_POSIX_USER_THREADS,
- RTEMS_SYSINIT_ORDER_MIDDLE
- #endif
-#endif
#ifdef __cplusplus
#endif
diff --git a/cpukit/include/rtems/confdefs/initthread.h b/cpukit/include/rtems/confdefs/initthread.h
new file mode 100644
index 0000000000..9d924d3aea
--- /dev/null
+++ b/cpukit/include/rtems/confdefs/initthread.h
@@ -0,0 +1,97 @@
+ * SPDX-License-Identifier: BSD-2-Clause
+ * Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+ * @file
+ * @ingroup RTEMSApplicationConfiguration
+ * @brief Evaluate POSIX Initialization Thread Configuration Options
+ * This header file defines _CONFIGURE_POSIX_INIT_THREAD_STACK_EXTRA for use by
+ * other configuration header files.
+#ifndef _RTEMS_CONFDEFS_INITTHREAD_H
+#define _RTEMS_CONFDEFS_INITTHREAD_H
+#ifndef __CONFIGURATION_TEMPLATE_h
+#error "Do not include this file directly, use <rtems/confdefs.h> instead"
+#endif
+#ifdef CONFIGURE_INIT
+#ifdef CONFIGURE_POSIX_INIT_THREAD_TABLE
+#include <rtems/confdefs/percpu.h>
+#include <rtems/posix/pthread.h>
+#include <rtems/sysinit.h>
+#ifndef CONFIGURE_POSIX_INIT_THREAD_ENTRY_POINT
+ #define CONFIGURE_POSIX_INIT_THREAD_ENTRY_POINT POSIX_Init
+#endif
+#ifndef CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE
+ #define CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE \
+ CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE
+#endif
+#if CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE \
+ > CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE
+ #define _CONFIGURE_POSIX_INIT_THREAD_STACK_EXTRA \
+ ( CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE - \
+ CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE )
+#endif
+#ifdef __cplusplus
+extern "C" {
+#endif
+const posix_initialization_threads_table _POSIX_Threads_User_thread_table = {
+ CONFIGURE_POSIX_INIT_THREAD_ENTRY_POINT,
+ CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE
+RTEMS_SYSINIT_ITEM(
+ _POSIX_Threads_Initialize_user_thread,
+ RTEMS_SYSINIT_POSIX_USER_THREADS,
+ RTEMS_SYSINIT_ORDER_MIDDLE
+#ifdef __cplusplus
+#endif
+#endif /* CONFIGURE_POSIX_INIT_THREAD_TABLE */
+#ifndef _CONFIGURE_POSIX_INIT_THREAD_STACK_EXTRA
+ #define _CONFIGURE_POSIX_INIT_THREAD_STACK_EXTRA 0
+#endif
+#endif /* CONFIGURE_INIT */
+#endif /* _RTEMS_CONFDEFS_INITTHREAD_H */
2.16.4
