Waf Build System Status in RTEMS?
Hesham Almatary heshamelmatary at gmail.com
Fri Feb 21 11:26:12 UTC 2020
On Fri, 21 Feb 2020 at 11:07, Sebastian Huber
> Hello Hesham,
> On 20/02/2020 16:40, Hesham Almatary wrote:
> > Hello,
> > Are there any progress updates to the Waf build system integration in RTEMS?
> > I have pulled [1] and it seems like it hasn't got many updates since
> > December. I wonder what's still remaining/blocking to merge it, or at
> > least push it as a development branch (without re-writing history)
> > that others, including me, can use it and submit patches against.
> > [1] git://git.rtems.org/sebh/rtems.git
> technically, the new build system is ready for integration into the
> master branch. I would need about one day to rebase and test it before
> the push. The integration is currently blocked since Chris and Joel had
> no time to look at it.
Thanks for your input, Sebastian. Is there a recommended branch I
should be based on? I noticed there's "build" and "build-next".
Do you intend to re-write git history in either?
Hesham
