Waf Build System Status in RTEMS?
Fri Feb 21 12:11:14 UTC 2020
On 21/02/2020 12:26, Hesham Almatary wrote:
> On Fri, 21 Feb 2020 at 11:07, Sebastian Huber
> <sebastian.huber at embedded-brains.de>  wrote:
>> Hello Hesham,
>> On 20/02/2020 16:40, Hesham Almatary wrote:
>>> Hello,
>>> Are there any progress updates to the Waf build system integration in RTEMS?
>>> I have pulled [1] and it seems like it hasn't got many updates since
>>> December. I wonder what's still remaining/blocking to merge it, or at
>>> least push it as a development branch (without re-writing history)
>>> that others, including me, can use it and submit patches against.
>>> [1] git://git.rtems.org/sebh/rtems.git
>> technically, the new build system is ready for integration into the
>> master branch. I would need about one day to rebase and test it before
>> the push. The integration is currently blocked since Chris and Joel had
>> no time to look at it.
> Thanks for your input, Sebastian. Is there a recommended branch I
> should be based on? I noticed there's "build" and "build-next".
The "build" branch contains the state of the first review. I updated
"build-next" a couple of times to integrate the changes on the RTEMS master.
> Do you intend to re-write git history in either?
Yes, when I started with the build system work I didn't expect a more
than two months review period.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
