[PATCH] bsps/arm: Initialize priorities of PPIs
Sebastian Huber
Fri Feb 21 13:19:26 UTC 2020
From: "sebastian.huber" <sebastian.huber at ad346e48-6743-2946-b04c-964484d2d4e6>
At least on GICv1 the interrupts 0 up to including 31 are so called
Peripheral Private Interrupts (PPIs). We have to initialize the
priority of the PPIs on secondary processors.
bsps/arm/shared/irq/irq-gic.c | 6 ++++++
1 file changed, 6 insertions(+)
diff --git a/bsps/arm/shared/irq/irq-gic.c b/bsps/arm/shared/irq/irq-gic.c
index 7cf469d0f7..42ae6c4d7d 100644
--- a/bsps/arm/shared/irq/irq-gic.c
+++ b/bsps/arm/shared/irq/irq-gic.c
@@ -152,6 +152,7 @@ BSP_START_TEXT_SECTION void arm_gic_irq_initialize_secondary_cpu(void)
volatile gic_cpuif *cpuif = GIC_CPUIF;
volatile gic_dist *dist = ARM_GIC_DIST;
+ uint32_t id;
while ((dist->icddcr & GIC_DIST_ICDDCR_ENABLE) == 0) {
/* Wait */
@@ -161,6 +162,11 @@ BSP_START_TEXT_SECTION void arm_gic_irq_initialize_secondary_cpu(void)
dist->icdigr[0] = 0xffffffff;
#endif
+ /* Initialize Peripheral Private Interrupts (PPIs) */
+ for (id = 0; id < 32; ++id) {
+ gic_id_set_priority(dist, id, PRIORITY_DEFAULT);
cpuif->iccpmr = GIC_CPUIF_ICCPMR_PRIORITY(0xff);
cpuif->iccbpr = GIC_CPUIF_ICCBPR_BINARY_POINT(0x0);
cpuif->iccicr = CPUIF_ICCICR;
2.16.4
