SPDX License Identifier Only and Full Copy?
Andrew Butterfield
Andrew.Butterfield at scss.tcd.ie
Fri Feb 21 14:38:13 UTC 2020
I like this because,
1. It tells me it is a BSD license (which the BSD license at the bottom doesn't)
2 . Then the stuff that tells me if the file is interesting (as per Joel's comment)
3. Then the license
Just my thruppence worth ;-)
Andrew
> On 21 Feb 2020, at 14:26, Sebastian Huber <sebastian.huber at embedded-brains.de> wrote:
> We can keep the BSD-2-Clause text in the file. We can also keep the @file on the top. Example:
> /* SPDX-License-Identifier: BSD-2-Clause */
> * @file
> * @ingroup RTEMSApplicationConfiguration
> * @brief Evaluate Configuration Options
> * This header file includes a couple of header files which evaluate the
> * configuration options specified by the application. The macros and defines
> * used to configure the system are documented in the Configuring a System
> * chapter of the Classic API User's Guide.
> * Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
> * Copyright (C) 1989, 2000 On-Line Applications Research Corporation (OAR)
> * Redistribution and use in source and binary forms, with or without
> * modification, are permitted provided that the following conditions
> * are met:
> * 1. Redistributions of source code must retain the above copyright
> * notice, this list of conditions and the following disclaimer.
> * 2. Redistributions in binary form must reproduce the above copyright
> * notice, this list of conditions and the following disclaimer in the
> * documentation and/or other materials provided with the distribution.
> * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
> * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
> * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
> * POSSIBILITY OF SUCH DAMAGE.
Andrew Butterfield Tel: +353-1-896-2517 Fax: +353-1-677-2204
Lero at TCD, Head of Software Foundations & Verification Research Group
School of Computer Science and Statistics,
Room G.39, O'Reilly Institute, Trinity College, University of Dublin
http://www.scss.tcd.ie/Andrew.Butterfield/
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200221/5b7d07de/attachment.html>
