SPDX License Identifier Only and Full Copy?
Thomas Doerfler thomas.doerfler at embedded-brains.de
Fri Feb 21 14:29:08 UTC 2020
+1 from me.
Am 21.02.20 um 15:26 schrieb Sebastian Huber:
> My main goal is to have a foolproof file template for all our source
> files very soon.
> Linux has the policy to put the SPDX at the first line if possible. The
> only exception are scripts which need an interpreter line for the shell
> (2. Style):
> https://www.kernel.org/doc/html/latest/process/license-rules.html
> Maybe we can use this policy in RTEMS as well (except for third-party
> code of course).
> We can keep the BSD-2-Clause text in the file. We can also keep the
> @file on the top. Example:
> /* SPDX-License-Identifier: BSD-2-Clause */
>  * @file
>  * @ingroup RTEMSApplicationConfiguration
>  * @brief Evaluate Configuration Options
>  * This header file includes a couple of header files which evaluate the
>  * configuration options specified by the application.  The macros and
> defines
>  * used to configure the system are documented in the Configuring a System
>  * chapter of the Classic API User's Guide.
>  * Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
>  * Copyright (C) 1989, 2000 On-Line Applications Research Corporation (OAR)
>  * Redistribution and use in source and binary forms, with or without
>  * modification, are permitted provided that the following conditions
>  * are met:
>  * 1. Redistributions of source code must retain the above copyright
>  *    notice, this list of conditions and the following disclaimer.
>  * 2. Redistributions in binary form must reproduce the above copyright
>  *    notice, this list of conditions and the following disclaimer in the
>  *    documentation and/or other materials provided with the distribution.
>  * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
> "AS IS"
>  * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
> THE
>  * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
> PURPOSE
>  * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
>  * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
>  * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
>  * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
>  * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
>  * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
>  * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED
> OF THE
>  * POSSIBILITY OF SUCH DAMAGE.
Thomas Doerfler
Dornierstr. 4
D-82178 Puchheim
Germany
email: Thomas.Doerfler at embedded-brains.de
Phone: +49-89-18 94 741-12
Fax:   +49-89-18 94 741-09
PGP: Public key available on request.
For our privacy statement, see
https://embedded-brains.de/en/data-privacy-statement/
