[PATCH] Fix a minor "suspect" -> "subject" wording error
Martin Erik Werner martinerikwerner at gmail.com
Sat Feb 22 11:17:14 UTC 2020
The word "suspect" here looked like a mistake and I have changed it
based on this assumption.
If it is not a mistake, what does "suspect" mean in this context?
 c-user/self_contained_objects.rst | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/c-user/self_contained_objects.rst b/c-user/self_contained_objects.rst
index a581e0e..1c1e664 100644
--- a/c-user/self_contained_objects.rst
+++ b/c-user/self_contained_objects.rst
@@ -29,7 +29,7 @@ has some weaknesses:
 * The object identifier is only known at run-time.  This hinders compiler
   optimizations and static analysis.
-* The objects reside in a table, e.g. they are suspect to false sharing of
+* The objects reside in a table, e.g. they are subject to false sharing of
   cache lines :cite:`Drepper:2007:Memory`.
 * The object operations use a rich set of options and attributes.  For each
2.20.1
