[PATCH] Fix a minor "suspect" -> "subject" wording error
Chris Johns
chrisj at rtems.org
Sat Feb 22 20:17:14 UTC 2020
Pushed.
Thanks
On 22/2/20 10:17 pm, Martin Erik Werner wrote:
> The word "suspect" here looked like a mistake and I have changed it
> based on this assumption.
> If it is not a mistake, what does "suspect" mean in this context?
> c-user/self_contained_objects.rst | 2 +-
> 1 file changed, 1 insertion(+), 1 deletion(-)
> diff --git a/c-user/self_contained_objects.rst b/c-user/self_contained_objects.rst
> index a581e0e..1c1e664 100644
> --- a/c-user/self_contained_objects.rst
> +++ b/c-user/self_contained_objects.rst
> @@ -29,7 +29,7 @@ has some weaknesses:
> * The object identifier is only known at run-time. This hinders compiler
> optimizations and static analysis.
> -* The objects reside in a table, e.g. they are suspect to false sharing of
> +* The objects reside in a table, e.g. they are subject to false sharing of
> cache lines :cite:`Drepper:2007:Memory`.
> * The object operations use a rich set of options and attributes. For each
